Old Jan 15, 2013, 06:36 AM
SWAMPER is offline
Find More Posts by SWAMPER
SWAMPER's Avatar
Joined Feb 2009
ok covering is done now time to install the servos and do the set up can some one post the best way to set up the ailerons ? i'll be using a DX7s radio
SWAMPER is offline Find More Posts by SWAMPER
Old Jan 15, 2013, 08:17 AM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
DX7 Setup
For the DX 7, which happens to be the radio I use, her are my settings.
Lower wing on Y connected to Aileron channel.
Upper wing on Y connected to AUX.
[Wing type]
Flaperon = ON
Under main programming:
[Differential]
Flaperon = 0%
[Flap SYS.]
Norm = 0%
Mid = 0%
Land = 0%
Auto = INH
[Reversing SW]
Ail = REV.
FLAP = REV.
This will give you independent sub trim of upper and lower wings. The trim switch will control both wings.
jkarpy is offline Find More Posts by jkarpy
Old Jan 22, 2013, 06:42 AM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
ok need a little help, After getting everything together it seems the top wing is not parallel to the bottom, the top seems a little twisted the center rods are not glued in but the outer strut rods are glued to the blocks that go into the wing pockets
How can I get the top wing adjusted to be parallel to the bottom ?
Old Jan 22, 2013, 10:34 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
The top wing is not parallel to the bottom. The upper wing will have a slight negative incidence and the lower wing will be slightly positive. Adjust the rear wing mount so the two wings form an arrow. As for the twist, you may need to double check the wing strut lengths. Let me know if you need any parts to correct the problem.
James
Old Jan 22, 2013, 11:01 AM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
it's a twist
Old Jan 22, 2013, 11:24 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
it's a twist
Remove your wings. Check them individually for twist. Check the length of all carbon rods as per the plan sheet. Don't lay them on the plan, measure them. They need to be darn close to exact. +/- .010". Make double sure, all carbon rods are fully seated into their mounts.
James
Old Jan 22, 2013, 07:06 PM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
found out the problem i think .... you have mail for parts i need to fix
Old May 16, 2013, 07:28 PM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
well i'm still at a loss finally fixed the wing pockets on top wing but it's still twisted to the bottom wing and can't figure it out why, all pockets are in same place all struts are the same length i'm about ready to just fly it as it and if it goes in then it goes sure i did something wrong but just cant figure it out
Old May 17, 2013, 10:29 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I need pictures to help you.
James
Old May 17, 2013, 06:50 PM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
see if this helps
Old May 19, 2013, 11:16 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Twist Problem
If you remove the wing struts, is it still twisted?
Old May 19, 2013, 02:01 PM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
i'll double check the way it is now i took the crossed struts out has just front ones
Old May 20, 2013, 06:36 AM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
looks like i can get it straight with out the struts guess i'll be ordering a new set of rods and strut ends and see if that helps, and not glue them till i make sure they are straight and not twisted
Old May 20, 2013, 10:18 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Can I see a close-up of the wing strut sockets? After we figure-out what parts you need, don't worry about it, I will just send them.
James
Old May 21, 2013, 05:50 AM
SWAMPER is offline
SWAMPER's Avatar
Joined Feb 2009
here are shots of the pockets, i'm hoping it's the struts now i must have something off and the struts are twisting the wing when i put them in, if i put the front struts in without the center ones the is twisted and the struts are the same length so i'm guessing something is off and the struts need to be adjusted guess i should of held off gluing them up
Discussion Micro SSX Biplane jkarpy Millennium R/C 176 Mar 31, 2014 11:38 PM
Build Log Micro SSX Biplane Beta build thread hawaiianspork226 Millennium R/C 52 Sep 03, 2009 01:53 PM
Article Millennium RC Micro SSX and Micro SSX Biplane Kits Review Doctor Who Parkflyers 17 Oct 22, 2008 08:11 AM
For Sale NEW!! Millennium R/C Micro SSX ARF and Micro SSX RTF for sale Ron Meloni Aircraft - Electric - Airplanes (FS/W) 5 Aug 13, 2008 05:04 PM
New Product SSX Micro Biplane BOBSHELIGUY Parkflyers 22 Feb 09, 2008 07:12 AM
