Old Feb 26, 2010, 02:52 AM
Rotor spin is offline
Find More Posts by Rotor spin
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
4s LIPO and GEAR for TC4
Can you guys recommend a 4s LIPO 3300mah to 4000mah for my car, I'm tired waiting for TURNIGY.
My price range is at $40 to $80, it's not unlimited but I use to buy top of the line brand LIPO, but lipo has been around for a while others brand should have caught up with technology. There should be Lipo like Turnigy that are cheap but good.
I want to try NEU ENERGY,Enerland or other LIPO that are available here in USCON.
my set up is as follows:
TC4
Mamba PRO
NEU 1509 3600kV
I'm also looking for Gears
32 or 48 pitch
Harden Steel Preferred
Rotor spin is offline Find More Posts by Rotor spin
Old Feb 26, 2010, 07:45 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
A while back when i first got into Lipo i ordered Venom as my first try with them. I use two 3s 4000's in my MMM e-maxx. They have had so-so ratings from folks, but mine have performed flawlessly for a year now. Fully charge every time and provide excellent power............i for one would give them high marks. $64.99 for 4s.
http://www3.towerhobbies.com/cgi-bin...?&I=LXXLM4&P=7
Turnigy has some in stock right now:
http://www.hobbycity.com/hobbyking/s..._20C_Lipo_Pack
scorpion1 is offline Find More Posts by scorpion1
Old Feb 26, 2010, 11:28 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
SCORPION1
THANKS for the reply,
I think I need 30c or better for 4000mah or less.
Old Feb 26, 2010, 03:48 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's a 30c, 96 amps continuous, the 3600 i posted above puts out 90 continuous http://www3.towerhobbies.com/cgi-bin...?&I=LXXLM1&P=7
Old Feb 27, 2010, 02:35 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
SCORPION1
THANKS for the reply again,
I forgot to mention I need a 2s in series with 2s so I can balance them on my car.
Old Feb 27, 2010, 06:33 AM
cbr6fs is offline
Find More Posts by cbr6fs
Athens, Greece
Joined Apr 2007
I'd just buy 2 Turnigy's then.
There is apparently the odd fault cell that gets through, but me and all me RC mates be it planes helicopters or cars are all using Turnigy's.
Between us we're running around 50 batteries of various different sizes and cell layout's.
Not one of us have had a problem yet.
Sounds like your doing speed runs and have a custom chassis, any pics?
Cheers
Mark
cbr6fs is offline Find More Posts by cbr6fs
Old Feb 28, 2010, 05:03 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
Hi cbr6fs
Thanks for the info, I appreciate it.
Yes I'm going for a speed run, it's taking more time than I anticipated but I'm sure it's worth the effort. I still got some work to do. a few more Item on my list.
I have been wanting to take pics but I have not got around to doing it.
Regards
John
Old Mar 01, 2010, 11:51 PM
burnineyes is offline
Find More Posts by burnineyes
United States, FL, Seminole
Joined May 2009
Welcome to the speed addiction. I just sold my TC3 with Mamba Max Pro, Medusa 3300Kv, Turnigy 5s 5000mah. I wish I hadnt, but I really needed the cash and several other cars wre ahead of it on the "keep" list.
The Blue Lipos from hobbypartz have been getting a few good reviews. They look very similar to Turnigys if you ask me. Plus they ship out of Cali.
I get large 48P pinions from AMainhobbies.com
I ran a 47T pinion and 60T spur
Oh and if you have traction, I hope you have the updated driveshaft. The TC3 comes with the carbon fiber shaft, it was bending pretty bad with my MM7700. So when I stepped up the power I went with the original TC4 aluminum shaft, it was a pretzel before I got out of my apartments stairwell. I finally got the newer, thicker driveshaft and never had a problem.
burnineyes is offline Find More Posts by burnineyes
Old Mar 02, 2010, 02:56 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
burnineyes
I will check the site for the pinion and 60T spur.
I just purchase a Flightpower Eonx 30C, not a bad deal so I jump on it.
the only thing is it's 4s if it does work great if not will have to get 2s2p
Regards
John
Old Mar 04, 2010, 02:17 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
burnineyes
I just purchase this items from A MAIN Hobbies, not sure if they will fit.
1 x RRP1341 Robinson Racing "Aluminum Pro" 48P Pinion Gear (41T)
1 x RRP1347 Robinson Racing "Aluminum Pro" 48P Pinion Gear (47T)
1 x RRP1860 Robinson Racing 48P Pro Machined Spur Gear (60T)
Regards
John
Old Mar 04, 2010, 10:08 AM
Joined May 2009
That will do it for you!
Old Mar 09, 2010, 02:15 PM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
burnineyes
I recieved the Item the pinion did not fit, I need 5mm
what ever it is it fit the 5700kV mamba.
Regards
John
Old Mar 09, 2010, 02:30 PM
Joined May 2009
I apologize, I didnt even realize you were using a 5mm shaft motor. Several companies make pinions that will fit, or it is pretty easy to drill the 3.17mm holes in your pinions to 5mm. Just take your time and line everythign up perfectly and you will be good.
Old Mar 10, 2010, 01:36 AM
Rotor spin's Avatar
BAYAREA, california
Joined Sep 2004
burnineyes
It's OK, I can use them on my CC5700kV which I need gear anyway.
I might go to 32P but they are not as smooth as 48 and 64.
I install new spring this weekend, Rear have Hot Pink and Orange on the front.
Regards
John
Wanted looking for lipo charger & balancer ac/dc 3s/4s wattage flyer Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 26, 2010 09:33 PM
Found Balance Adapter for CSRC to TP 4s LiPo pilotfrank Aircraft - Electric - Batteries & Chargers (FS/W) 3 Nov 11, 2009 06:12 AM
Question FMA CellPro 4S Settings for a 3SP 2200 Lipo? Tada Batteries and Chargers 2 Nov 03, 2009 12:19 PM
For Sale PRICED FOR QUICK SALE-LIKE NEW Thunderpower 4S 3300 30C-60C LIPO mechengineer03 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 25, 2009 07:41 PM
Discussion TC3 vs. TC4 vs. TC4 FT for beginner? dstrout On-road Cars 3 May 28, 2006 09:14 AM
