Old May 03, 2010, 05:58 AM
fernandez is offline
Find More Posts by fernandez
Joined May 2009
Wow very nice!!
fernandez is offline Find More Posts by fernandez
Old May 03, 2010, 02:32 PM
guantamanera is offline
Find More Posts by guantamanera
I want to bark at the moon
guantamanera's Avatar
2 weeks in SoCal 2 weeks in WA
Joined Mar 2009
yeah that is cool
guantamanera is offline Find More Posts by guantamanera
Old May 06, 2010, 09:33 AM
bluety is offline
Find More Posts by bluety
Joined Nov 2009
How long will we wait until the Frsky telemetry system is on market?
bluety is offline Find More Posts by bluety
Old May 06, 2010, 01:01 PM
kneedrag is offline
Find More Posts by kneedrag
Joined Apr 2007
It should be ready for us distributors to order in a few days, I am awaiting the mail from FrSky confirming that I can place my order. Then it takes more or less 2 weeks from the Factory to my doorstep.
kneedrag is offline Find More Posts by kneedrag
Old May 07, 2010, 03:21 PM
Joined Mar 2009
buggy post
Old May 09, 2010, 06:18 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
BMP085 Vario
Just a short update. I have the BMP085 barometric sensor and PIC communicating now. I'm working on the conversion of the sensors outputs to temperature/altitude. I'll post some code when I have at least the temperature being correctly calculated. The math is very messy compared to past projects I've done. The altitude is harder than the temp.
I think we should start new 'FrSky 2.4Ghz - XXX' threads as each project actually gets to useful stage.
PLMS is offline Find More Posts by PLMS
Old May 09, 2010, 07:16 PM
Manuel Silva is offline
Find More Posts by Manuel Silva
Oporto Portugal
Joined Sep 2007
Frsky receiver Duplex (Telemetry)
Hi All.
I already put these thread in another forum, but know I think it is here the right place to put it.
I am designing (but I am not an expert) a board based in an Atmega88 to measure the altitude, battery voltage by cell and rpm. I read that the telemetry channel is RS232 3 wires. What type of signals are the 3 wires, Rx what are the other 2. The voltage level I guess is a 3Volts. Am I correct?
I didn't decided yet if I am going to buy the BASCOM AVR compiler or use the C language of the AVR Studio. I do not know either one, but I am going to try to learn doing this project. I think may be the BASCOM AVR is easier than C, but, C is more common and is easy to transfer from one MCU type to another.
I retired last year and start to learn MCU's (AVR'S), I only know to program in assembly, but, to do all the calculations to read the altitude I must learn a high level language, make it in assembler it is very difficult.
Thanks in advance.
Best regards,
Manuel Silva
Manuel Silva is offline Find More Posts by Manuel Silva
Old May 09, 2010, 11:58 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Hi, Manuel !
The 3 serial wires are: Gnd, 5V, Rx.
Rx voltage level is RS232 !
Fortunately, there is another set of contacts, not documented, located in the opposite side of the board. Look for 4 PCB pads, without any connector, with a 1.28mm pitch, so quite not standard. Those 4 contacts carry a full Tx/Rx TTL serial line The square pin is PIN1, the 4 pins signal are: 3.3V Rx Tx Gnd
renatoa is online now Find More Posts by renatoa
Old May 10, 2010, 03:11 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
wich is the transmision power of the receiver?
i just know the transmision power of the radio module
wallaguest1 is offline Find More Posts by wallaguest1
Old May 10, 2010, 04:39 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
i just know the transmission power of the radio module
Now that's an interesting question. I can do that measurement when the new two-way set is out. It will require changing one or both antennas to a pigtail with RP-SMA for testing (which I have).
Maybe somebody knows already ?
Old May 10, 2010, 05:38 AM
Oporto Portugal
Joined Sep 2007
Hi, Renatoa!
Thanks for the information. About the additional contacts, can we transmit data down and receive data from transmitter RS232 input?
Is there a two way transmission between the transmitter and receiver?
thanks and regards,
Manuel Silva
Old May 10, 2010, 05:40 AM
Joined Sep 2007
According to Mr.Chase, yes.
Not tried yet, though, because my module is JR type and my radio Futaba, waiting for the issue of Futaba modules, mid May.
Old May 10, 2010, 06:39 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi guys,
I'd like to buy the 2-way system as well when it is available.
But I have a question concerning the telemetry alarms.
I have read this document:
http://www.frsky-rc.com/download/Ins...0system-aa.pdf
It seems, that there are 3 "channels" for alarm functions available.
2 channels can be used and configured someway by the user, and one channel gives range warnings, in 3 different intensitys.
Is this correct?
The range warning function can not be configured, and is always available?
That would be great, so that there is no chance to mess this function up with wrong user settings and stuff.
Julez
Julez is offline Find More Posts by Julez
Old May 10, 2010, 10:52 AM
Oporto Portugal
Joined Sep 2007
Hi, All!
Renatoa, I apologise to bother you again. I saw in this here http://www.frsky-rc.com/download/Ins...0system-aa.pdf the Duplex manual, and as you said, in the input receiver defenition we can see the 3 Volts and the 5 Volts. These are 3/5 volts inputs or outputs for the peripherals we can install?
Thanks and regards,
Manuel Silva
Old May 10, 2010, 10:59 AM
Joined Sep 2007
Feel free to bother me, will respond if I know
They are outputs to power the sensors. About the 3.3V sources, we were advised by Mr.Chase to not load them too much, but without specs how much is too much.
Because 3.3V I guess could be the internal rail power of the receiver, I wouldn/t connect anything there without clear specs of the allowed consumption, I would better use 5V instead. If you need 3.3V use two diodes
Mini-Review FrSky 2.4ghz - looking good so far! BrumBob Radios 13332 Yesterday 06:44 PM
Discussion New Audio Modem Protocol For FPV Telemetry MelihK FPV Talk 138 Dec 31, 2011 09:24 AM
New Product FrSky 2.4GHz radio system jonathan-FrSky Australia 70 Apr 28, 2011 04:22 PM
Cool TWIN 2.4GHz new RFHSS system from CZ, with or w/o Telemetry alex.guzun Radios 5 Jan 18, 2010 02:24 PM
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
