I recently made this post in the 8FG thread:
http://www.rcgroups.com/forums/showp...&postcount=453 I had the A9 on backorder for a while until I discovered the 8FG, and I am glad I got the Futaba. Of course everyone who has an A9 will tell you they love it, and I am sure they do. Just be careful looking at the specs and capabilities. The latency (52ms) was also an issue for me. The manual on the T8FG is not great, I will say that. Coming from Spektrum it is a bit of a jump, but I can see the potential. There is just a learning curve, the same as there was with my first TX. |
windsor,ontario,canada
Joined Jun 2001
I would buy the A9. The speed issue will not matter since servo speed and reaction time make a far greater difference. The A9 is far superior in programming and value plus it has amazing stick feel being quad ball bearing (not bushing like the Futaba). That would greatly help you with Heli's. The biggest problem is finding an A9. They are in such high demand that it is dificult to find one. The higher end Futaba 10C is closer to the A9 in specs.
100ms human reaction time 52ms transmitter to receiver latency .12ms servo latency equals 152.12ms total latency for the servo to move to its full travel That 52 ms could be cut down to 10 to 20ms and improve the total response time by up to 28% right (assuming 10ms)? Yes, people will have longer latency than the electronics. But the electronics contribute to the total response time, and in the case of the A9 it could be improved. |
I have an A9 on order, but just looked at the 8FG on Tower. The SD card is, IMHO, a glaring omission in the Aurora. I'm not a heli pilot, so I'm also not familiar with the impact of latency to that degree.
But, would having the ability to do telemetry in the A9 be a plus for you in AP? |
Joined Jun 2001
100ms human reaction time (not a realistic time more like 250ms) 52ms transmitter to receiver latency 120ms or .12seconds servo latency equals 270ms total latency for the servo to move to its full travel total of 270ms for the servo to move to it's full travel. Reduce this be 30ms is about 11% difference in the very best case. An amount not noticeable. |
Romania, Dolj, Craiova
Joined Sep 2007
... fixed
Latest blog entry: JRSky - birth of a dream radio
![]() Aurora 9 can save unlimited models to the PC and has the ability to update it's firmware as well with the HPP-22 interface. Individual models can be transfered to another Aurora either by PC or direct with the trainer cord. So I don't see how an SD card advantage over this. More model memory I guess... but the Aurora already has 30 built in. Mike. |
Cant say much about helicopters, but for planes Hitec seemed more interesting to me and I like it's intuitive GUI and touch screen menu, you can acess things much faster.
Futaba 8FG don't have flight conditions in plane mode, no telemetry, no iddle down as Hitec has (you can set it up at any moment using switch and throttle stick position), no trim adjust function. Of course if you need flight conditions you can set up your plane at sail plane mode using P.MIX for plane features like throttle curve. If you are using smoke pump and not linear Knife edge mix you will not have any one of 5 mixes left after main functions setup. But Futaba have advantages like more 3-pos switches, virtual channels so you can create mixes without using actual channel as second, offset mix (you will have to use one channel for it on A9). Must be some other differences, but I have named the one's I care and know. Probably I should have mentioned Hitec scan mode which are very useful for FPV flying.
There are more functions for sail planes on Futaba 8 (12 preset mixes and the ones I have mentioned before - offset mix and virtual chanels which might be useful for sail plane flyers at some cases), don't know about choppers. |
San Gabriel Valley, CA
Joined Mar 2008
The SD card can be swap between 8FGs at field. So if my 8FG gets wet (knock the wood)during a contest, I can just insert my SD card into my buddy's 8FG, link my receiver and I am ready to go. The ATX Sd-10g has the same feature, but with more expensive proprietary card.
Tai |
USA, CA, Merced
Joined Dec 2007
the A9 has more programming flexibility and will excel in non-standard applications where hand-wrought mixing is important.
if the quadcopter is such an application, then the A9 distinguishes itself. if non-standard mixing isn't an issue, then the 8FG provides more outright performance in terms of latency response, but the A9 provides a more pleasant user interface and the novel telemetry feature. the A9 is probably the better choice for anyone not already invested to FASST and also not overly concerned with latency. the 8FG is still an excellent offering, but unless you're a competition flier I would say the A9's features are more everyday useful and provide for a better purchase. |
| Thread Tools | |
| Article Hitec Aurora 9 Channel 2.4GHz Radio System Review | pda4you | Radios | 333 | Nov 18, 2011 04:14 PM |
| Question Hitec Aurora 9 Transmitter & FPV Head Tracking | WEREE | Radios | 6 | Jan 18, 2010 02:26 PM |
| Sold HiTec Aurora 9 2.4 Ghz with two 7 ch Rx - brand new | Cloud_Catcher | Aircraft - General - Radio Equipment (FS/W) | 5 | Jan 08, 2010 11:04 PM |
| Discussion Aurora 9 or Futaba 10CAG or Airtronics 10SD-10G? | wollins | Radios | 12 | Nov 21, 2009 09:47 PM |
| Discussion 8FG or Aurora 9 | FLY GUY EDDY | Radios | 2 | Nov 06, 2009 09:15 PM |
