Old Feb 25, 2010, 05:37 PM
RamboFlier is offline
Find More Posts by RamboFlier
Joined Sep 2008
20C vs. 40C Watts at same discharge rate?
Given three exact batteries except the C rating...
1800mAh 4S Lipo Pack 20C
Constant Discharge: 20C (36A)
Peak Discharge (10sec): 30C (54A)
1800mAh 4S Lipo Pack 30C
Constant Discharge: 30C (54A)
Peak Discharge (10sec): 40C (72A)
1800mAh 4S Lipo Pack 40C
Constant Discharge: 40C (72A)
Peak Discharge (10sec): 50C (90A)
With the same discharge rate of 36Amp for each pack, would the 40C pack hold its Voltage better and offer higher Wattage?
RamboFlier is offline Find More Posts by RamboFlier
Old Feb 25, 2010, 06:44 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Theoretically, yes .
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Feb 25, 2010, 06:59 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Adding to that...Depends a lot on the cells and if they can hold voltage under a load. It could be that a 25C pack that is better made (better cells) can hold higher volts under a load than a cheaper 40C pack...
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Feb 25, 2010, 08:04 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Also if the packs C rating is correct, then the 40C pack won't get as warm as a 20C pack would at the same discharge rate. The 40C battery is supposed to have less internal resistance than a 20C pack.
earlwb is offline Find More Posts by earlwb
Old Feb 25, 2010, 11:28 PM
Himalaya is offline
Find More Posts by Himalaya
Himalaya's Avatar
Joined May 2009
using acurately rated(neither over nor under rating) 40C and 20C packs:
at 20C discharge, you get roughly 5.6% more voltage and 11% more power from the 40C pack.
at 40C bursts, you get 12.5% more voltage and 26.6% more power from the 40C pack.
at 5C mild discharge, you get 1.3% more volts and 2.6% more power from the 40C pack.
Himalaya is offline Find More Posts by Himalaya
Help! Is it possible to charge and discharge a battery at the same time? CoolBudz DIY Electronics 133 Mar 19, 2011 09:10 AM
Discussion Discharge rate of lipo battery Sparken57 Batteries and Chargers 7 Feb 11, 2010 10:18 PM
Question Turnigy 4s 3000 40c VS Flightmax 4s 3000 40c huggett Batteries and Chargers 2 Jan 06, 2010 09:02 AM
Discussion Help..... Do TP packs have the same mAh regardless of the rate you discharge? imxz28 Batteries and Chargers 2 Feb 23, 2008 01:59 PM
Discussion 20C Enerland and CommonSenseRCs, 9 cycles @ Max. Discharge Rate, CBA Graphs RD Blakeslee Batteries and Chargers 17 May 21, 2006 09:55 PM
