Old Feb 25, 2010, 11:05 AM
luv2fly is offline
Find More Posts by luv2fly
luv2fly's Avatar
Joined Apr 2001
Parkzone J3-Cub Ultra Micro question......
Is this model only meant to be flown indoors?
luv2fly is offline Find More Posts by luv2fly
Old Feb 26, 2010, 01:43 PM
chief illini is offline
Find More Posts by chief illini
Joined Feb 2006
I suspect you should go over to the micro RTF forum, lots of discussion over there...seems many are flying outside as well.
chief illini is offline Find More Posts by chief illini
Old Feb 26, 2010, 02:00 PM
appleflyer is offline
Find More Posts by appleflyer
Fly DW foamies!
appleflyer's Avatar
longmont, CO
Joined May 2006
you can fly it outside on a calm day with vary little wind.
appleflyer is offline Find More Posts by appleflyer
Old Feb 26, 2010, 04:56 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Nope. You can fly it anywhere there is no wind
Xpress.. is offline Find More Posts by Xpress..
Old May 07, 2010, 10:29 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
J3 Micro outdoors!
In response to whether these can fly outdoors, YES THEY CAN!!
My little J3 is a hoot to fly in my daughter's school yard [allowed apparently].
I did a mod that I feel is worth mentioning to those wishing to fly in up to 5km/h [3mph] wind:
First, I used weldbond white glue diluted to 30% and applied it to the front cowling, behind the prop [threaded off prop first!] in around the under side battery bay to behind the gear [flat point before taper on tail], and then used 50% WG under the wind roots near the fuse, and tail [elevator] section, as well as the wing tips where they round.
I then also added WG full strength about the gear roots near the fuse, and let dry - added very little weight, but added a LOT of strength.
The modified re-inforced cub flies like a champ, can even handle a wingtip stall at 10' [happened today in 3km/h gust that stalled the tip during a sharp turn]. no damage.
The gear holds up to short grass landings, and even nosedives due to lousy pilot error [me!]. Other than the very occasional shaft straightening, I can fly this outdoors like crazy.
I highly recommend this mod for this plane anyway, as it really adds around 3x or more strength to the airframe, yet only a tiny added weight. can fly level at 1/3 throttle easily, very easy to re-trim.
Darren/Skycadet
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old May 08, 2010, 12:32 AM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
I've ONLY flown mine outside. It can handle a fair breeze if it's steady, swirling winds are a little tougher. It's a great little flier.
Belem is offline Find More Posts by Belem
Old May 08, 2010, 09:15 AM
Capt Buddy is offline
Find More Posts by Capt Buddy
Capt Buddy's Avatar
Ft Lauderdale
Joined Mar 2010
Thats a great idea sky cadet. I have only flown mine outdoors, and I know i have had it in 5+ mph wind, its a pain in the a@# but it has survived many nose dives, stalls and any other kinda of crashes with just nicks and scratches and bent prop shafts but ive never had to replace anything yet, just bend back the propshaft, and glue the nose. I love this little plane, i just hope my new Super Cub is half as durable!
Capt Buddy is offline Find More Posts by Capt Buddy
Old May 09, 2010, 01:44 AM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
Agreed! Just stay upwind as a strong draft will push the plane in reverse. It's really cool when you can get a horizontal hover going on.
restlessswind is offline Find More Posts by restlessswind
Article ParkZone Ultra-Micro J-3 Cub BNF & RTF Reviews Michael Heer Micro Ready-to-Fly 111 Mar 01, 2015 03:24 PM
Discussion Ultra Micro J3 Cub Mods? dariend Micro Ready-to-Fly 379 Jan 23, 2015 08:09 PM
Discussion Ultra Micro J3 Cub and P51 dariend Micro Ready-to-Fly 0 Feb 19, 2010 10:46 AM
Discussion Parkzone J3 Cub BL Li-Po charger question cpd32 Batteries and Chargers 1 Feb 06, 2010 04:38 AM
Discussion New ParkZone J3 Cub Micro? finchkid24 Scratchbuilt Indoor and Micro Models 1 Nov 18, 2009 02:33 PM
