Old Feb 24, 2010, 11:38 PM
justind123 is offline
Find More Posts by justind123
Joined Nov 2007
Best Pan Tilt, Best pan tilt servos???
Im trying to see what the best Pan tilt is out there and the best servos to use for it. Ill be using a immersion track R2....
Im asking b/c i finally got my home built one working and the hs 65 mgs that i have on it twitch like crazy even with no video tx turned on..... What is everyone using? PS its on an easy star.......
justind123 is offline Find More Posts by justind123
Old Feb 24, 2010, 11:44 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
HS-65 mg's are a good servo, but it's possible to get a bad *anything*....
I use HS-65 mg's alot and have very little trouble with them, even with a "noisy" 900mhz 500mw vid Tx nearby.
Take that 65 back and get it exchanged.
galaxiex is offline Find More Posts by galaxiex
Old Feb 24, 2010, 11:53 PM
Joined Nov 2007
hmmmm i thought its just twitching alot b/c its digital and the digital servos tend to emit micro noise and jitters?......
Old Feb 25, 2010, 12:51 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
The HS-65's I have are analog.... http://www.hitecrcd.com/servos/show?name=HS-65MG
The Digital version is called 5065.... http://www.hitecrcd.com/servos/show?name=HS-5065MG
Old Feb 25, 2010, 01:03 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Usually when people ask this question they really mean "What are the best really cheap P&T
servos?" but in case you really want the best I think the Hyperion Atlas servos
are the best. I use DS13 for the pan and DS11 for the tilt. Both in metal gear variants.
They're programmable so you can get up to 180 degrees of rotation, can slow em down
a bit and they're very smooth and high resolution. They are unaffected by
noisy 900Mhz video Txs and such.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 25, 2010, 10:11 AM
Joined Nov 2007
Thanks thats exactly the input im looking for.... Is there a really good comparable one in the hitec, JR, Futaba line? what about the pan tilt mechanism?
Old Feb 25, 2010, 10:23 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Just moved one of planes from Hitec 65's to Hyperion digital. Love those servos. Really good.
Smooth and tight. Just how I like them...
Shikra is offline Find More Posts by Shikra
Old Feb 25, 2010, 02:28 PM
Joined Nov 2007
still looking for best Pan Tilt setuo... and good servos in a futaba/ hitech/ jr world
Old Feb 25, 2010, 02:38 PM
aviatordave is offline
Find More Posts by aviatordave
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
Not the best but quite functional. Hitec hs-55 servos with a pan/tilt unit from servocity.
http://www.youtube.com/watch?v=RdjUGSqju-o
aviatordave is offline Find More Posts by aviatordave
Old Feb 25, 2010, 04:17 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
I would get that with the HS 5055 digital metal gear servos.
HS 55's strip too easy.
I have been using a few HS 5055's and so far am impressed. Tough little servo.
Old Feb 25, 2010, 04:35 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Why does it have to be futaba/hitec/jr?
Seriously Hyperion Atlas series are the best for the task, and they're not
that expensive ordered online. They're the highest resolution micro digitals
I've seen so far.
ian
Old Feb 25, 2010, 04:42 PM
chimaera is offline
Find More Posts by chimaera
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
I've seen so far.
ian
I agree!
I think many people spend just as much time and money screwing with addons to slow the servo down or stretch the rotation. Why not just buy the Hyperions with a programmer and do it right. They perform great for this.
chimaera is offline Find More Posts by chimaera
Old Feb 25, 2010, 05:22 PM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
ian
I see 4 different DS13 servos and 3 different DS11 servos. Which ones in particular do you recommend and whats the difference. I cant make sense of their part numbers
http://www.allerc.com/index.php?cPat...er&filter_id=3
ozzi supercub is offline Find More Posts by ozzi supercub
Old Feb 25, 2010, 05:37 PM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
I reckomend the Hyperion too. I tried all the Hitec / Futaba / JR and I've got to say Hyperion are the best value in terms of quality versus price.
You can even get a cheap usb programmer that allows programming the Pan to almost 180deg (about 170) whilst still maintaining very good resolution, perfect for the Pan.
cheers Geoff
garris2 is offline Find More Posts by garris2
Old Feb 25, 2010, 05:42 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The Atlas variants are for things like super fast (heli rotor servos), high torque, carbonite
(or equiv) gears, and metal gears.
I choose the metal gear variant because sometimes the pan/tilt rig takes
direct impacts.
ian
Discussion Best way to wire the Pan and Tilt Tarro FPV Talk 5 Feb 24, 2010 07:19 PM
Alert What not to use for pan/tilt servos kyle7119 FPV Talk 5 Jan 14, 2010 06:40 PM
Discussion Best pan and tilt for a 2 lb. video camera. Joel K. Scholz Aerial Photography 1 Jan 04, 2009 04:40 PM
Discussion Best servos for Pan & Tilt ..smooth, fast, light, etc CATPart FPV Talk 12 May 17, 2008 04:34 PM
Discussion Best Nose Mount T-Rex 600 (Pan & Tilt) KarbonBird Aerial Photography 3 Oct 10, 2007 09:30 PM
