be careful what you choose. My experience with a SE5a was that it was a little too heavy to be practical. But then again my skill at building light are still developing so who's to say.
Looking forward to your next one! Cheers. P.s. I'm kinda partial to the Focke-Wulf 19 kit 502. built one when I was a kid and it flew on the rubber motor. That 250 should be perfect for it. |
1.5 oz. is the airplane and electronics? |
Gotta get a scale. If you were close by, I'd give you my old trusty rusty
postal scale. Worked fine, until I found a newer one in the house. I only finally got a 0-7oz digital scale for component weights for micro building. Set at zero though, I found that weights could be determined from the old postal scale, within 1-2 grams. Not too bad.On the SE5A, mine is certainly not light, but I'm convinced many just don't set the CG far enough forward to get these planes to fly well, along with well set wings, etc. These planes will handle more weight than many seem to think, once properly setup. In general though, they are more difficult to get to fly well at higher weights, but I think they are dismissed at times due to weight, when they actually could fly well. Quote:
can be a useful aid in this process.For all practical intent and purpose, you do need ailerons, but not mandatory. My FW190 flew rud/elev, but admittedly was a test, to see how gently one could be on the controls, and not much fun until adding ailerons. I'm convinced the Spitfire would have flown rud/elev, with the correct thrust angle, but by that time I had already added ailerons to it also. It's never too late to add ailerons, but it is certainly more practical to add them during the initial build. He may still end up doing it, as I did. Here's one method below:
United States, WA, Parkland
Joined Feb 2010
im considering tossing the spitfire off my 3rd floor balcony just to see the glide path...getting annoyed waiting on this battery charger i ordered to show up. wish i would have realized ahead of time that my charger cant do 2s lipos
![]() I lost interest in glide tests and chuck gliders, when I realized that they don't simulate heavier/powered flight well. This is especially true with rudder control. Probably shouldn't have said that, as I don't to turn your thread into a test glide/chuck glider debate, but it's been my experience. I do have respect for rud/elev warbirds having done them, as it forces you to build a straight flying stable plane, where aileron trimming can otherwise make many other planes flyable.
| Thread Tools | |
| Build Log Fun Build 3 - Guillow's Spitfire - She's Finished! | Steve85 | Scale Electric Planes | 95 | Nov 16, 2011 01:30 AM |
| Yippee! Guillow's Spitfire success unmodified!! | lw_hughes | Parkflyers | 81 | Dec 31, 2005 11:32 AM |
| First Guillow's Conversion -- Spitfire! | The Enemy | Scale Electric Planes | 194 | Mar 15, 2004 04:59 PM |
| Help with Guillow's Spitfire.....TIA | ramw5p | Scale Electric Planes | 10 | Aug 30, 2003 01:11 AM |
| Guillow's Spitfire as electric R/C | Clipperkite | Beginner Training Area (Aircraft-Electric) | 23 | Mar 11, 2002 10:39 AM |
