Old May 23, 2003, 02:43 PM
I FO nut is offline
Find More Posts by I FO nut
Lazy sob
I FO nut's Avatar
Rural retreat, Virginia
Joined Apr 2002
will the mini twin from speedwing.net work with a 4 amp speed control?
Well whats the amp draw on this thing anyway?
Jonn-
I FO nut is offline Find More Posts by I FO nut
Old May 23, 2003, 03:46 PM
gobigdale is offline
Find More Posts by gobigdale
Time To Fly?
gobigdale's Avatar
Gig Harbor, WA
Joined May 2002
I have been using a 2amp GWS with no problems. I dont fly full throttle for very long though
Dale
gobigdale is offline Find More Posts by gobigdale
Old May 27, 2003, 03:22 AM
sam2000pres is offline
Find More Posts by sam2000pres
Nevada City CA
Joined Nov 2001
Mini Twin
Using the stock EDP-50 motors and 3x3 props draws about ~2 amps or a little more, static, and about 17K rpm per motor.
I am sure it unloads quite a bit in flight. Using Qualcom Li-on batteries, two packs (one per motor) gives 20 min WOT flights.
Worst case, the motors overload the ESC and shut down. Most ESC's are rated at continuous current but can handle excess amp peak loads for a short duration okay.
TK
sam2000pres is offline Find More Posts by sam2000pres
Discussion Will servos from the 1980's work with todays RX? MikeSSS Radios 7 Mar 02, 2006 02:53 PM
building of my new mini speed wing from speedwing.net gazza2003au Foamies (Kits) 9 May 18, 2004 08:48 AM
Tough Choices: Dandy sports or mini twin from speedwing.net? someone special Parkflyers 2 May 03, 2003 11:00 AM
My new Mini Twin from Acer Danny Troy Foamies (Kits) 25 Mar 27, 2003 10:12 PM
Anyone flying the Mini-ASW from EAM.net? CheeseWing Electric Sailplanes 1 Jan 03, 2002 12:08 AM
