Old Feb 23, 2010, 09:51 PM
dmoores is offline
Find More Posts by dmoores
I Love RC
dmoores's Avatar
Nicholasville, Kentucky
Joined Sep 2004
1/2 Inch Foam At Lowes
I noticed Lowes had some 4X8 sheets of white foam (don't know what kind) and was wondering if this is too thick to build some planes with? It had some type of thin plastic on both sides that looks like it would peel off easy.
dmoores is offline Find More Posts by dmoores
Old Feb 23, 2010, 09:54 PM
$$J3ft$$ is offline
Find More Posts by $$J3ft$$
GO FAST OR GO HOME!!!!!!!
Joined May 2007
its good i bought the blue stuff and it works great on my big f-117
$$J3ft$$ is offline Find More Posts by $$J3ft$$
Old Feb 23, 2010, 09:57 PM
Noteworthy is offline
Find More Posts by Noteworthy
Madison, Alabama
Joined Feb 2010
I bought the blue person size sheet from lowes that's 1/2 in. thick. Once you peel the plastic off both sides it works great.
Noteworthy is offline Find More Posts by Noteworthy
Old Feb 23, 2010, 10:43 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Look for a beat up piece and see if they will discount it. That way you can test it without going too deep into your pockets.
going4speed is offline Find More Posts by going4speed
Old Mar 07, 2010, 05:26 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
The white foam is beadfoam and very fragile. Stick with the blue stuff. 1/4" PBIII FFF is my favorite.
rich smith is offline Find More Posts by rich smith
Old Mar 10, 2010, 06:54 PM
whatala is online now
Find More Posts by whatala
San Jose, CA
Joined Sep 2003
I could not find any blue foam at my local hardware stores such as OSH, Homedepot, Lowes
whatala is online now Find More Posts by whatala
Old Mar 10, 2010, 08:02 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
whatala: guys in CA have a tough time finding the good stuff. I don't know if it's local codes (trying to be "green"), or just not enough market for it. You might try your local dollar store for the white foamcore board and strip the paper off. It makes a good plane material. Also Michaels and other craft stores have similar board, Even Walmart sells Elmers board.
Dmores: if the white foam is crumbly bead board, I'd stay away from it. (granted Cybernaught has made some really nice planes from it, but that's all he can get) There's better stuff readily available that will be lots more easy to work with.
springer is online now Find More Posts by springer
Old Mar 10, 2010, 09:22 PM
RJD1234 is offline
Find More Posts by RJD1234
RJD1234's Avatar
Bakersfield, CA
Joined Apr 2008
Same here.......BluCor is hard to find. I have a 3" thick sheet forever but Iwould like to find a good supply.
RJD1234 is offline Find More Posts by RJD1234
Old Mar 11, 2010, 07:43 AM
dmoores is offline
I Love RC
dmoores's Avatar
Joined Sep 2004
My Lowes only has the green fan fold. Is this any good?
Old Mar 11, 2010, 11:52 AM
treefinder
springer's Avatar
SE MI
I haven't used it, some guys say it's heavier and more brittle than blucor, but a bunch of planes have been built from it, so can't be too bad.
Old Mar 11, 2010, 12:37 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
I don't think there is any consistency in their suppliers. About 6 months ago I saw some white foam there (1/2, 1, and 1.5") and it was clearly extruded (not expanded like beadfoam). It seemed fairly strong based on a casual inspection. At other times, I've seen something that sounds like what you are talking about. Next time I go, I'll check it out. I think their buyers just get what ever is available and cheaper.
I like PBIII too, it's fairly strong and requires a lot less reinforcing than other foams. Though, for bending, skinned dollar tree foam board is a pretty good deal.
philba is offline Find More Posts by philba
Old Mar 11, 2010, 02:27 PM
rich smith's Avatar
Joined Dec 2006
I've seen blue and pink extruded but no white... not so far around here anyway. However foam is like a box of choc..colates, you never know what yer gonna get.
Discussion Cutting to 1 inch foam with a razor knife aerogel Foamies (Scratchbuilt) 0 Nov 24, 2009 04:33 AM
Discussion 1 inch blue foam Terry Glenn Foamies (Scratchbuilt) 3 Sep 23, 2009 06:17 AM
Build Log F-15 175% 1/2 Inch Blue Dow Foam Getti Pusher Prop Jet Models 78 Jul 20, 2007 08:55 PM
Discussion BlueCor foam at lowes sameershah Foamies (Scratchbuilt) 51 Nov 10, 2006 04:22 PM
Found it!! Fan Fold foam for $23.00 For a limited time at Lowes in Pinellas phoneguy Foamies (Kits) 1 Apr 23, 2003 01:11 AM
