Old Feb 23, 2010, 04:18 PM
pdown1231 is offline
Find More Posts by pdown1231
United States, AZ, Eloy
Joined Aug 2008
Testing ESC's?
I have a TP MAG 8 30A ESC that is doing strange things when the motor spins up beyond half throttle. The Ail/Rud/Ele start twitching, then the motor starts cutting out and surging. (Probably explains why my easy star tried to play ground hog.) Can the ESC be tested by other than exchanging with another?
pdown1231 is offline Find More Posts by pdown1231
Old Feb 23, 2010, 05:11 PM
Mayday!Mayday! is offline
Find More Posts by Mayday!Mayday!
Check my blog-updated
Mayday!Mayday!'s Avatar
Columbus,Ohio
Joined Nov 2005
If the surfaces are twitching that could be a radio issue. Bad X-tal, interference, bad connection and so on.
Mayday!Mayday! is offline Find More Posts by Mayday!Mayday!
Old Feb 23, 2010, 05:22 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Unless you are a electronic GURU with specified testing equipement then your going to be limit in testing, swap for another ESC is probably the best and easiest way to find out or iliminate items or problems.
freechip is offline Find More Posts by freechip
Old Feb 23, 2010, 07:02 PM
Joined Aug 2008
Thanks, Mayday and Freechip. I did switch the ESC and all was well... so far I was curious if there was a "simple" test to deternine a fail point in an ESC. I'd hate to scrap a good one because I didn't know if it was a programming issue or just failing. When weather permits, I'll throw it in the air and hope
Mini-Review Testing Air hogs Foxfire's Engines RCmaniacxX Micro Ready-to-Fly 9 Jan 18, 2010 05:23 PM
Discussion Differences between the CC HV ESC's and HV "ICE" ESC's? JEFFRO503 Power Systems 7 Dec 09, 2009 06:26 PM
Discussion QinetiQ’s Solar-Powered UAV Program Resumes Testing Gary Mortimer UAV - Unmanned Aerial Vehicles 7 Dec 06, 2009 01:03 AM
Sold Esc's...esc's...esc's brand new 30amp...40 amp...50 amp...70 amp java8297 Aircraft - Electric - Power Systems (FS/W) 10 Nov 20, 2009 01:36 AM
Discussion Testing no-load rpm's with optical tach? Murman Electric Motor Design and Construction 9 Nov 10, 2009 04:45 PM
