Old Feb 23, 2010, 12:41 AM
dariend is offline
Find More Posts by dariend
Joined Feb 2007
Ultra Micro J3 Cub Mods?
I am looking into buying or making floats for my ultra micro j3 cub. Does anyone know of any out there? Can I make my own?
Also, are there any extra mods or anything? And what are the best upgrades, batteries, motors, etc. that I can get for this plane?
Darien
dariend is offline Find More Posts by dariend
Old Feb 24, 2010, 12:00 PM
canadianufo is offline
Find More Posts by canadianufo
Just gotta mod. it
canadianufo's Avatar
Northern British Columbia
Joined Dec 2006
There are floats out there I just can't remember the name of the plane I got them off of. I'ts a profile rubber band powered beaver that mine came from. It flies great with them on.
canadianufo is offline Find More Posts by canadianufo
Old Feb 26, 2010, 07:44 AM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Maybe you could cut down a pair of the 350mm floats and make lighter mounts.
http://www.atsrcplanes.com/floats.htm
I've cut my own with a hot wire cutter, but they're flat-bottomed.
MR2
minirips2 is offline Find More Posts by minirips2
Old Feb 26, 2010, 12:47 PM
Todd Long is offline
Find More Posts by Todd Long
www.toddsmodels.com
Todd Long's Avatar
North Bend, WA.
Joined Apr 2000
I have been working on a set of floats (Scale Design) for the Micro J3 Cub. While the plane flies and looks great in the air, (really looks good) it will not take off of water. The little plane just does not have enough power to break the surface tension of the water and it is not going fast enough for the step to be of any use. We can land it on water just fine with a little practice. Land on grass just fine.
Any interest out there for floats that look good but you are limited to hand launches?
Todd
www.toddsmodels.com
BTW: We are still working on different designs to see if we can get it to ROW
Todd Long is offline Find More Posts by Todd Long
Old Feb 26, 2010, 02:11 PM
StevenSeim is offline
Find More Posts by StevenSeim
A dream will find you
StevenSeim's Avatar
North Bend Washington
Scale EDO floats for BNF Piper Cub
The prototype floats built for ToddsModels are true to scale, built and carved from EDO drawings. They are very light and the model carries them well. The step is positioned correctly as well.
They do work well and the model sits correctly on the water. The test pilot(s) report very favorable flying characteristics. Landings are shot with some speed, which adds to the scale effect.
The model will not ROW with the floats as they are now. We are testing now with the floats having a flat bottom.
More to come on this.
StevenSeim is offline Find More Posts by StevenSeim
Old Feb 26, 2010, 02:17 PM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
You guys know how to go with design, but I did just find this very informative page, while looking at floats. The dimensions stated can be scaled and adjusted for the model.
http://www.seminolerc.com/EZ-Float-Design.html
Perhaps it'll help other folks who may wish to modify for water fun
Slider2732 is offline Find More Posts by Slider2732
Old Feb 26, 2010, 02:31 PM
StevenSeim's Avatar
Thank you
Nice link. Thank you.
The challenge is to work with the model as it is, and provide an interchangable system of wheels and floats without having to modify the aircraft.
A more powerful motor is the first answer for sure, but the goal is to keep the model stock. The next set of 'Skipping' type floats will be finished today.
More to come.
Old Feb 26, 2010, 03:45 PM
Joined Jan 2007
Getting a full scale J-3 on floats to ROW isn't that easy, either! If the water's smooth, many guys will taxi in a circle, then use their own wake to break the float free of the water. Of course the surface tension is much greater on the UM Cub due to scale. I wonder if a lower pitch prop would do the trick, or maybe larger diameter to move more air?
MR2
Old Feb 26, 2010, 04:30 PM
AlphaWolf is offline
Find More Posts by AlphaWolf
Micro Addict!!!
AlphaWolf's Avatar
Vale of Shadows, Ontario, Canada.
Joined Feb 2008
Have you tried using " RainX " ?
Might help with the surface tesion.
AlphaWolf is offline Find More Posts by AlphaWolf
Old Feb 26, 2010, 05:20 PM
piperjoe is offline
Find More Posts by piperjoe
piperjoe's Avatar
United States, MI, Interlochen
Joined Dec 2009
I do like those floats! Are you selling these now?
Joe
piperjoe is offline Find More Posts by piperjoe
Old Feb 28, 2010, 01:52 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Todd
www.toddsmodels.com
I am definitely interested just for the looks of them. I am not concerned about not being able to take off from the water.
John
JohnM is offline Find More Posts by JohnM
Old Feb 28, 2010, 04:29 PM
PeteSchug is online now
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
I'd like a pair of your floats. If I can't get off the water it doesn't matter much because I don't have anyplace to fly off water except when I go to Vermont, which is only twice a year or so.
I just like the way a J3 looks with floats on and I can use them off snow also. When I was a kid I used to see cubs with floats on overhead all the time. I think I lived half way between City Island, NY and Little Ferry, NJ, both of which had a lot of float planes.
I'd like scale floats, but if the flat bottoms work on water I think I would go for both.
Pete
PeteSchug is online now Find More Posts by PeteSchug
Old Mar 01, 2010, 02:22 AM
StevenSeim's Avatar
floats will be available yes
For those wanting true scale EDO floats willing to hand launch and water land, that can easily be arranged.
The flat bottom floats will be ready for testing by mid week. They will still be somewhat EDO looking, but will have a flat bottom skinned in waxed tape. Hopefully we can ROW with it and still keep the aircraft stock.
Todd has prototyped a laser cut plywood strut kit that looks really spiff.
Here is how the flat bottomed floats will appear.
Contact ToddsModels as you like.
More to come shortly.
Old Mar 01, 2010, 09:39 AM
Just gotta mod. it
Joined Dec 2006
I've taken off snow and water with mine. Flies great..really scale, but water no problem...video to follow in about a week.
Old Mar 01, 2010, 09:47 AM
Just gotta mod. it
Joined Dec 2006
Just a day at the lake ..with some open water.
Discussion Ultra-Micro J-3 Cub: L-4 Grasshopper Conversion Matt Gunn Micro Ready-to-Fly 32 Jun 29, 2010 04:30 AM
Discussion Ultra Micro J3 Cub and P51 dariend Micro Ready-to-Fly 0 Feb 19, 2010 10:46 AM
Discussion PZ Ultra Micro P-51 Mustang Mods wayneabonga Scratchbuilt Indoor and Micro Models 3 Feb 15, 2010 03:04 PM
Discussion New ParkZone J3 Cub Micro? finchkid24 Scratchbuilt Indoor and Micro Models 1 Nov 18, 2009 02:33 PM
