Old Feb 22, 2010, 11:16 AM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
what is the difference between 4 blade and 5 blade
fans?? having an extra blade does that create more thrust? Or having one less fan blade create more speed but less thrust?
sherlockshah is offline Find More Posts by sherlockshah
Old Feb 22, 2010, 12:46 PM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
depends on the fan and how it loads up. there's no right or wrong on this question, really. it's all in the science and manufacture of each individual unit and the work it performs. the manufacturers use fluid dynamics programs and all kinds of technical stuff to design and build a fan and, they are designed to perform their best work in a specific range. the blades and blade number are designed around these specs. so, while one manufacturer uses 5 blades, another uses 3, another uses 7 and so on and so on.
rating one against another by blade count isn't really an accurate way to measure them up against each other though, since it doesn't mean much based on the above paragraph. lets take a hypothetical fan into consideration. it has 5 blades and spins at 30,000 RPM and produces its best thrust numbers in this range. the blades, pitch and count all produce its maximum thrust at that RPM. now, if one were to change the count to 7 blades, the performance would "fall off".............the RPM and thrust would drop and Amps would rise. not really a very efficient way to make power. lots of heat would be the byproduct of wasted energy. so you can see that it's all in how the fan is designed and the conditions it is designed to operate under that is more the answer and not specifically changing the blade count to get better numbers.
I know there are companies that sell rotors with less blades for their units and this apparantly increases RPM and therefore, thrust. less mass will spin faster and get you more output, but there are tradeoffs with everything. there's no free lunch.
Rich
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Old Feb 22, 2010, 01:34 PM
tom bacsanyi is offline
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
In most situations, pitch makes much more difference than blade count. The link below is to my thread discussing 6 and 12 blade scratch built 90 mm fans with equal pitch.
If you look at the numbers, you'll see they perform almost identically.
http://www.rcgroups.com/forums/showt...=125mm+cutlass
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Feb 22, 2010, 01:54 PM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
One
Doug Bateman is offline Find More Posts by Doug Bateman
Old Feb 22, 2010, 03:51 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I agree with Doug, if high efflux is needed. Control line speed freaks used custom single blade props, for yrs w/counterbalances. The theory being the blade does not run in as much prop wash. Or so I have been told.
You want a plane to go fast? Reduce the number of blades and increase pitch, RPM, smaller dia. But you cannot have your cake and eat it too. Then you lose thrust with the smaller dia, unless you can pour in more power. More power is more weight. Like a dogchasing it's tail.
So a compromise is required between thrust, efflux speed, power available, etc. Lot's of blades do sound nice. esp. when getting into the higher numbers.
I went to a drag boat race yrs ago. The really fast ones use single blade. But they took a running start through the timer. Compromise!
Fuzz
St. Martin is offline Find More Posts by St. Martin
Discussion what is the difference between a 2 pole and 4 pole brushless motor ? mortonj69 Dock Talk 7 Oct 19, 2014 10:42 AM
Discussion What is the difference between a 33$ hobbyking and a 180$ Futaba ? vicking Radios 34 Dec 31, 2009 05:18 PM
Question What's the difference between trailing edge and aileron stock? flatland2d The Builders Workshop 5 Oct 05, 2009 08:52 PM
Help! What's the main difference between 5 or 6 blades of one type fan? cola2cool Electric Ducted Fan Jet Talk 9 Sep 10, 2007 01:14 PM
Question Difference between 4/5 SC and SC NiCd? squidbait Batteries and Chargers 3 Mar 26, 2007 03:34 PM
