Old Feb 21, 2010, 09:29 PM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
another crash :( F-16 on 4s second flight video
My first flight went well, the second not so good, CG could of been off a little plus, I think either one of the tailerons came off from pulling too many G's, I thought it was the tail when it happend but I recovered the parts and the tail was good, so I suspect the tailerons must of came off.
Phase 3 F-16 crash 4s 900watts (0 min 45 sec)
sherlockshah is offline Find More Posts by sherlockshah
Old Feb 21, 2010, 09:33 PM
Joined Feb 2006
sorry for the horrible video job by my wife!
I just lost the airframe, which was $20bucks, everything else is working. HE clocked it at 89mph but, that was a short distance of 120 feet at wide open throttle. I did it the first time he did not get it, so I was going around. I think its way past 120mph. You guys can hear the motor go and it was only for about 3 seconds and it already clocked 89, if i ran it for about 10 second full it would be much faster.
Old Feb 21, 2010, 09:55 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
did that too!!! twice
sheppard559 is offline Find More Posts by sheppard559
Old Feb 21, 2010, 10:12 PM
Joined Feb 2006
what came off for you?
THis was my first crash with this jet. I think I had way too much power for the airframe, I had to cut alot of foam to get the battery to fit, also the fan area. My first flight was very good but I did not open it up much as I did here. YOu can hear the jet go past us but that run was only 3seconds or so.
Old Feb 21, 2010, 10:19 PM
Joined Mar 2008
my taileron ripped off..it took a piece of the fuse as well..my third one had carbon rod imbedded in the fuse /taileron section and that solved the problem...look in the foam jet fourum for the phase 3 f-16 top speed contest..thats were you will see all the tricks
Old Feb 21, 2010, 10:24 PM
Joined Feb 2006
yea I am going to pass, just going to buy a fiberglass one
THe amount of time spent to glass it and modifiy the structure its just easier to get a ready made fiberglass one, Im looking at the proedf f16 for $170, looks cool and should be fast.
Old Feb 21, 2010, 10:31 PM
Joined Mar 2008
yep ..thats what i did too...bought the het f-16 and crashed it too throwing it! although i did see a guy at the field the other day throw his without a problem
Old Feb 21, 2010, 10:46 PM
Joined Feb 2006
hey do you still have it? or is it crashed bad?
I have a F104 I tried to handlaunch, that was one that can not be done, I tried all kinds of different ways. DID you rebuild??
Old Feb 21, 2010, 10:49 PM
Joined Feb 2006
the trick to hand lauch is this
first hold the plane at the cg spot, if you can not get a grip then palm it. Then wot and then run with the plane and then just gently toss it up like a basket ball lay up, do not throw it, if you have a high power system which I suspet you do it should just by itself. I have done the HET F20 like that on 6s, that was a awsome plane. The F104 is just a design you can not hand launch the other ones are pretty easy to do. You know how they toss the pizza dough in the air thats how you toss the airplane with full throttle run with it and then gently toss it up, then quickly after two seconds pull on the elevator you are good to go.
Old Feb 21, 2010, 11:37 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Lol.....
Sherlock I told you like 50 times to reinforce that tail....
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 22, 2010, 03:36 AM
Joined Feb 2006
pete
I called you yesterday morning to see if you could come out, but you did not answer the phone, So i figured you were in bed.
Old Feb 22, 2010, 04:51 AM
Team White Llama!
You were dead right, I'm on nights this weekend.
Old Feb 22, 2010, 11:34 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the hp f-16 is a great flyer but with anything over 550 watts it needs major mods to stay in one piece,the mod thread is full of mods to make it a great plane
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 23, 2010, 08:04 PM
charlieoneseven is offline
Find More Posts by charlieoneseven
Aircrafting is noisey...what?!
charlieoneseven's Avatar
United States, CA, Long Beach
Joined Dec 2005
Good thing your only spending $20 bucks on an airframe according to the guy on camera you crash a plane every week.
charlieoneseven is offline Find More Posts by charlieoneseven
Old Feb 23, 2010, 08:08 PM
Joined Mar 2008
crashing is a part of flying ..EVERYONE(you too) in this hobby has at one time or another ,from either a mistake or equipment/model failure
Discussion Crash video second attempt F104 sherlockshah Electric Ducted Fan Jet Talk 98 Jul 22, 2011 06:47 PM
Discussion First Flight With FMS Skytrainer 182 (Flight&Crash Video) 729927852 Beginner Training Area (Aircraft-Electric) 4 Jan 20, 2010 06:56 PM
Video T.S.R.2 second flight (Another horror Vid ) pontious Electric Plane Talk 10 Oct 19, 2009 10:20 AM
Video F-16 90mm EDF on board flight video TGoodwin Electric Plane Talk 10 Jul 22, 2007 10:01 AM
