Yup. The spring for the dampening needs to be very strong though so it doesn't make the unit bottom out on a hard landing. I saw that once with the C21 I modified and it wasn't pretty. I landed very hard (my fault) and the wheel/spring extended like they should but they kept going until the top section of strut hit the grass and bam jet came to a screeching halt. I installed a stronger spring after that and it was fine.
I hope Kin comes through because I've literally got my credit card sitting here hoping to put the charge on it. |
Joined Sep 2007
The Angled back are not important , because we can set the total travelling angle in 90/95/100/105 choice . if we use the 105 angle the wheel will fully go inside even the strut are straight , but we need in test fit it .OK the information are enough ! try to make a scale look one ,But how many space to install the retract mechanic in the fuselage . have the intake tube block the landing gear ,? i want you have a front view inside the intake (mouth) .
Here are more pictures so you can see the ducting. The ducting is on a slight upwards angle from the mouth moving towards the back. |
Joined Sep 2007
. if this modela are bigger size like jet size are possible . but now are diffcult !!
Joined Sep 2007
one idea are make a 1/2 wheel diameter wheeel fairing inside the ducting .let the wheel can (back angle) and 1/2 wheel can goinside the ducting surface .this idea can let the wheel full come inside and if you can make a smooth fairing in will not effect the ducting ! is it possible ??
Yes it would be easily possible to modify the ducting to allow a larger wheel. In fact it would be very easy to do so as the ducting comes out without problem for modifications. It would look like the Fly Eagle Jets F-16 style ducting. As long as the wheel wouldn't impede the airflow too much it would work fine. I wouldn't worry about trying to look scale. All we want is a strut that can replace the wire gear that has some dampening. The best solution is a C21 style trailing strut but sized for this plane because the ones currently around are too long. They fit inside the fuse with the wheel no problem at all. It's just they are 110mm's long when they need to be 88mm's long so people end up having to grind them down too much. Also the risk with the C21 design is that when the plane touches down, the spring can extend TOO MUCH which causes the plane to ground out which is NOT good. If you create something along the lines of the C21 but with your better ability and design then we would all be happy. I am sure you could come up with something similar that would look better than the current one. Hopefully could look like the first picture with shock absorbing springs inside or whatever you think is best. For the pull pull wire you can just tap holes into the side of the C21 to mount the pull pull cables. It would work fine. |
I don't have that piece anymore as I sold it on my first 1/12th F-16 before I bought the next two 1/12th F-16's. All I can tell you is that it's total length including wheel needs to be 88mm's as shown in the dimensions on the first photo I took for you. Can you not use those dimensions to construct this? |
| Thread Tools | |
| Cool Recived my TF model/smartmodel LYNX | DC3_driver | Scale Helicopters | 33 | Jun 29, 2010 04:49 AM |
| Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades | kin | 3D Electric Heli Flying | 4 | Jan 19, 2010 07:42 PM |
| Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades | kin | Electric Heli Talk | 2 | Jan 19, 2010 12:03 PM |
