Old Oct 08, 2012, 01:24 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by henke View Post
1/9 is a standard turbine size which already exists. It would never fly on a 90mm EDF setup, not even a 90mm Schüebeler. All deltas need alot of juice and I bet a 1/9 Viggen will weigh in at about 8kg of flying weight. That would require atleast 8kg of thrust, or even better 12kg or so to keep the 1:1 ratio even at flying speed.
Of course fun with a Viggen in any size, but just don't think it will be able to fly on an avarage 90mm EDF setup.
See the photo about this full composite fuselage
The size like than size 2.0m models we are only 6.5-7kg flying weight . we use very light material to do the models , i thinlk the JA -37 can control in 5 kg roughlt .So if a good quality 90mm fan easy to get 4kg thrust . it can fly well !
kin is offline Find More Posts by kin
Old Oct 08, 2012, 02:18 AM
marell01 is offline
Find More Posts by marell01
marell01's Avatar
Sweden
Joined May 2006
Hi,
The absolute best size for JA 37 is 1:10. It is a huge aircraft with a lot of drag...
1:10 scale would be aproximately,
Lenght: 164.3cm
Wingspan: 106cm
Height: 59cm
This is perfect for 90/100mm fan, maybe 120mm but also for the small turbines. I have one already in this size. I'll take some pictures of it. It is beyond repair...
I will try to get you a plastic model of the JA 37.
marell01 is offline Find More Posts by marell01
Old Oct 08, 2012, 02:22 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by marell01 View Post
Hi,
Lenght: 164.3cm
Wingspan: 106cm
Height: 59cm
ok i fix this size now , but the AJ -37 models in hand , so i will let it for refrence and looking for JA version , please try to help me about the models or detail drawing much better !Try to ask the real plan factory if you can !!
Kin
Old Oct 08, 2012, 02:28 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
5kg AUW would mean a kit weight of about 2kg. Well, possible I guess. The Feibao EDF Eurofighter is Viggen 1/10 sized and weighs in at 2100g empty.
I still vote for smaller (about 1/12 or 1/11) as this would make it more proverful on a 90mm EDF. It really needs a bit more thrust then weight to fly good.
henke is online now Find More Posts by henke
Old Oct 08, 2012, 02:29 AM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Kin
Give me a week!!!
I´ve found this today.
http://www.aviationmegastore.com/saa...d=0&art=107101
Old Oct 08, 2012, 02:35 AM
henke is online now
henke's Avatar
Joined Jan 2001
Originally Posted by ticketec View Post
1/8 is the normal/standard size for the smaller turbine models. I.e F-16's, F-15, F-86 etc. but I do agree with you that deltas do require quite a fair bit of power to get flying the same as a non-delta type wing layout.
What are the JA-37 sizes in 1/9?
dave
Viggen is F18 sized but differ alot as it's a delta and needs alot of power to fly.
"The worlds only supersonic biplane"
Old Oct 08, 2012, 02:45 AM
henke is online now
henke's Avatar
Joined Jan 2001
Hi,
Lenght: 164.3cm
Wingspan: 106cm
Height: 59cm
Your 1/12 seem to do great on an avarage 90mm setup. What was the AUW?
JA 37 3 (2 min 41 sec)
Old Oct 08, 2012, 03:18 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Give me a week!!!
You'll be waiting a while for that one. I believe it's not due to be released until early next year.
But if it's any consolation, their previous release was very well accepted but the plastic modelling community.
Dave
ticketec is offline Find More Posts by ticketec
Old Oct 08, 2012, 03:32 AM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
http://www.youtube.com/watch?v=hYc3MFuEwsk
About 2.8 kg. It was marginal in power... 1:12 is too small to fit the retracts. It is just not enough space.
Sincerely Marcus
Old Oct 08, 2012, 04:17 AM
marell01 is offline
marell01's Avatar
Sweden
Joined May 2006
Here's a picture of some a/c in the Viggen family.
First JA, then a green AJ, and last the Recce SF version.
Description:
The different fin is clearly seen here between the grey JA and the green AJ. JA is also longer!
Description:
This is what the nose of the SF looks like. It has a lot of cameras inside.
Description:
Finally the difference in ailerons where JA version has 2 more pneumatic servos more on each side, and more weapon pylons.
Description:
One last picture to show ya all this amazing aircraft. JA37 version!
Description:
Sincerely Marcus
Old Oct 08, 2012, 05:34 AM
henke is online now
henke's Avatar
Joined Jan 2001
Sincerely Marcus
Viggen has a very special landing gear which probably needs to be engineeerd to fit the model regardless of size. How ever larger is more easy as you say.
Old Oct 08, 2012, 06:22 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
What Kin is doing is keeping the planes light...I would be skeptical if I didn't JUST maiden a 65" all composite\ built up wing Airliner that weighed 6lbs empty....7.3lbs AUW.
If Kin can keep it around 5KG then there are some reliable 90mm power systems that will fly it that will cost in the 100usd range (motor, esc, fan)
If not then I think TAM has some vids floating around of his A-4 being flown at a pretty good clip (150mph) with a 90mm and some really good eflux numbers but the power is in the 4kw range...
Haoye has their 114 and 127 that weight 20oz and put around 14lbs of thrust with certain motors....it can be made light no doubt
erh7771 is offline Find More Posts by erh7771
Old Oct 08, 2012, 07:28 AM
ticketec is offline
Brisbane, Australia
Kin,
Is that the A330 you used to make??
dave
Old Oct 08, 2012, 08:12 AM
henke is online now
henke's Avatar
Joined Jan 2001
I would love a light airframe of caurse, but there are some diffrence in light and magic
For me the actual size doen't matter but for selling alot of airplanes I think smaller is better.
But again, I'm not the one decideing, just chimeing in with my thoughts.
(I know about the Haoye 127, an amp hog. 10S 6000mAh required to howl a 11lb plane the way I think the Viggen should move. http://tinyurl.com/8h8gcyn)
Old Oct 08, 2012, 09:01 AM
erh7771 is offline
Joined Nov 2005
I get similar numbers to Dynamax on the 127mm...14.5lbs of thrust at 4400 watts..90amps on 12s...
Matched to the right motor the fan is just fine....
I used the scorpion 560kv 4035 motor
If the fans exhaust is choked down too much blades stall big time
Cool Recived my TF model/smartmodel LYNX DC3_driver Scale Helicopters 33 Jun 29, 2010 04:49 AM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin 3D Electric Heli Flying 4 Jan 19, 2010 07:42 PM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin Electric Heli Talk 2 Jan 19, 2010 12:03 PM
