Old Sep 07, 2012, 01:43 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
Mr. Kin, when do you have full composite wing for System hawk available?
I am seriously looking for next project and your hawk is one. How large wheels you can stuff into it, I got pretty uneven grassfield..
Ceeray is offline Find More Posts by Ceeray
Old Sep 07, 2012, 11:33 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Yes !i doing the composite mold now . it will very detail panel line and rivet . the first batch is econ version and next month is delux version (full composite wing ) .but fuselage is exchangeable and germany epoxy resin .
kin is offline Find More Posts by kin
Old Sep 08, 2012, 07:39 AM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
I love that. You can get the Econo version now and then buy a wing set later when they are available or say if you have a mishap you can upgrade. Very smart thinking. When will we be able to order?
swps is offline Find More Posts by swps
Old Sep 08, 2012, 11:21 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The firct batch are doing the , i thinkm this month about 15-20 possible have some . and let some out market and the same time are making the composite mold now . the full composite version maybe in October . I will make it fast , the christmas is coming !
Old Sep 10, 2012, 01:25 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Hi Kin,
Any pictures of the grey Hawk?
dave
ticketec is offline Find More Posts by ticketec
Old Sep 10, 2012, 01:51 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by ticketec View Post
Hi Kin,
dave
the fuselage is ready here grey colour , but waiting the wing ! and add some photo here and see the weight is so light in this size fuselage !
Old Sep 10, 2012, 11:02 AM
swps is offline
swps's Avatar
Joined Jun 2010
I saw that the Econo Hawks are up for purchase, $430 shipped! What 100mm systems are out there beside the Stu? My spending has been catching my wife's eye, so I need to tread lightly here...
Old Sep 10, 2012, 11:23 AM
swps is offline
swps's Avatar
Joined Jun 2010
Ok, I'm answering my own question here.
Efflux RC has one, $120, 7 Blade
http://www.effluxrc.com/100mm-EDF-un...1000-103-T.htm
Nitroplanes sells one $11, yes $11, 4 blade no specs.
http://www.nitroplanes.com/eldufanun1se.html
TamJets TJ100, $450 fan only, PNP $995
http://www.tamjets.com/original/prod...roducts_id=420
Stumax SM100-45 $450
http://www.espritmodel.com/edf-stuma...het-motor.aspx
Any others I might be missing?
Old Sep 10, 2012, 11:45 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Don't show your wife my website .and all my sent out parcel almost make the value is mix 50 usd , or replacement parts , she never know your cost !
Old Sep 11, 2012, 05:19 AM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Plastic Models
Kin,
I have 1:72 Heller JA-37. 1:100 Tamiya AJ-37 will be arriving soon. aaamodels.co.uk appears to default delivery of 1:48 ESCI/Airfix AJ-37 - a likely PayPal dispute.
I sent you a PM.
http://www.tarangus.se/2012/03/30/new-viggen-next-kit/
The above seems to be an excellent 1:48 Viggen. If this a better reference for you, I would rather wait. First quarter 2013 is not that far away, although it is after 2012 Christmas
Del
delperena is offline Find More Posts by delperena
Old Sep 11, 2012, 06:04 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
http://www.hobbyking.com/hobbyking/s...dProduct=27560
or maybe not.
anlucas is offline Find More Posts by anlucas
Old Sep 12, 2012, 07:15 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by anlucas View Post
we can see the Hobby King here china and HongKong ! They block it !
Old Sep 12, 2012, 07:19 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Really!! They block it?
Here's the info..
Alloy DPS Series 90mm 12-Blade EDF unit with 1000kv Motor - 4000watt (10s)
Specs:
EDF Rotor Diameter: 86mm
Outer Diameter: 94mm
Construction: Alloy
Weight: 657g (complete unit with 4mm connectors)
Motor Type: 4074 1000kv
Max Power: 4000w
Max Voltage: 37v (10S)
Max Amps: 99A
Max Thrust: 4.65kg
Power / Thrust Data:
Power: 8S / 29.6V
Max Watt: 2800W
Cont.Watt: 2550W
Amps: 82A
Thrust: 3.6kg
Power: 9S / 33.3V
Max Watt: 3300W
Cont.Watt: 3100W
Amps: 89A
Thrust: 4.1kg
Power: 10S / 37V
Max Watt: 4000W
Cont.Watt: 3850W
Amps: 99A
Thrust: 4.65kg
Old Sep 12, 2012, 10:26 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Here's the info..
Specs:
Construction: Alloy
Max Power: 4000w
Max Amps: 99A
Max Thrust: 4.65kg
Power: 8S / 29.6V
Max Watt: 2800W
Cont.Watt: 2550W
Amps: 82A
Thrust: 3.6kg
Power: 9S / 33.3V
Max Watt: 3300W
Cont.Watt: 3100W
Amps: 89A
Thrust: 4.1kg
Power: 10S / 37V
Max Watt: 4000W
Cont.Watt: 3850W
Amps: 99A
Thrust: 4.65kg
HK website can not open in HK and China . But thankyou this information ,so helpful !
Old Sep 12, 2012, 01:52 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
The fan has an inlet lip which may retract installation in the ducting.
J
jayb1rdz is offline Find More Posts by jayb1rdz
Cool Recived my TF model/smartmodel LYNX DC3_driver Scale Helicopters 33 Jun 29, 2010 04:49 AM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin 3D Electric Heli Flying 4 Jan 19, 2010 07:42 PM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin Electric Heli Talk 2 Jan 19, 2010 12:03 PM
