Old Aug 08, 2012, 03:02 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Kin,
I am really looking forward to seeing your new range and owning some of your models, particularly the F-20.
I'm not a huge warbird fan but I really do love the P-40. HK has a 1700mm foam version that is stunning but crippled by bad component that crippled demand. Still the airframe is beautiful. I hope that an all composite version comes to your stable soon.
J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Aug 08, 2012, 11:57 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by erh7771 View Post
Do you have an estimate of it's empty weight?
Good job Kin
The fuselage net weight (no wooden former included) , it should be 1.4-1.6kg (no painting included) , i think after former install and paint is about 2.2kg within . because it is simple inside the fuselage and not much former need . just nose gear mount ,fan mounting and tail wing a little small piece thing , so not possible over 2 kg ! .so the flying weight with a fan and 8s battery is roughly 4kg total , So a good quality fan are also at least 4 kg now in market . the wing have 3cm longer each side .and width a little bit in the wing cord , if you are not check deatil , you can not feel the size different . so the weight and power ratio is very happy flying i sure .
kin is offline Find More Posts by kin
Old Aug 08, 2012, 12:07 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Yes ! wrong typing . it is Saab 39 Gripen Sorry ! need to tell guys (My english is very bad ) .
Old Aug 09, 2012, 12:48 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Hey Kin,
Do you have any pictures of the econo wing, or the model assembled?
And are you planning on supplying the models painted or in gel coat?
dave
ticketec is offline Find More Posts by ticketec
Old Aug 09, 2012, 05:20 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by ticketec View Post
Hey Kin,
dave
the wing are cutting the foam and prepare the balsa sheet now , i will post it soon . gel coat kit is not problem , it is cheaper than the econ version . in fact the gel coat kit can see my quality and the real net weight , customer will feel quality much better ! (Some factory afraid sell it in gel coat kit because it show their quality , But it never sell to china here ! but you need to paint it yourself , Ha!Ha!
Old Aug 09, 2012, 01:05 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The F-20 start now ! i will post each step and let you down count the proccess .
Old Aug 09, 2012, 05:24 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
When do you plan to use epoxy resin and vaccum bag your work with peel ply to make it lighter?
Friberglass is ok but polyester resin has got to go...
ApexAero is offline Find More Posts by ApexAero
Old Aug 09, 2012, 11:18 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
the Vacum bag is usually working here and hollow mold matel is Rochacell .so this is the best material we are using in every models . So we make the models very light . R&G is our material supplier .
Old Aug 11, 2012, 05:55 AM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Dear Kin,
I am looking forward to your new models .I hope to see other offerings like the P40 .
I know many models from China struggle with the type of fiberglass /composite material used and in the end "tin can" =part flex or are very soft without multiple formers.
Some examples , Wills Hobbies offered many 66" and larger warbirds , many were very very soft and needed much work to be a safe model .
CMP-China Model products was better but still used the less desirable fiberglass in the fuselage componants and the last was ESM -they were the best in there class .
I was wondering if you can review what type of composite methods and meterials you will be using .
Thank you Sir
LDM
Ldm is online now Find More Posts by Ldm
Old Aug 11, 2012, 05:56 AM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Apoligize , I need to subscribe to this thread
Old Aug 11, 2012, 11:14 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
No problem ! you are weclome .i am the one use germany epoxy resin factory here china .I need the quality first ! some other factory is polyester resin , it is so big different quality . I just believe epoxy and hollow mold . but i will make the econ version for my models ,that is balsa wing . let it lower the cost for this soft market . and let lower cost for the customer and dealer .
Old Aug 14, 2012, 12:19 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
the cockpit completed . The pilot control panel is base included . just add the reject seat later , but it is the hard work . i will let it later . just finish the wing soon . the surface rivet hope you can see . it is very small . need look close , i just make the photo by the I phone ., so the photo not detail enough ! Sorry
Old Aug 14, 2012, 01:43 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
It's good enough Kin,
Great work. J
Old Aug 14, 2012, 04:15 AM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Nice work Kin !
Old Aug 14, 2012, 12:53 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Some photo soon!
Cool Recived my TF model/smartmodel LYNX DC3_driver Scale Helicopters 33 Jun 29, 2010 04:49 AM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin 3D Electric Heli Flying 4 Jan 19, 2010 07:42 PM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin Electric Heli Talk 2 Jan 19, 2010 12:03 PM
