Old Nov 25, 2010, 06:41 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Oh very nice (and very big!).
alexandermh is offline Find More Posts by alexandermh
Old Nov 25, 2010, 06:55 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Its a shame the X-35 isn't in production and never will be again. The model Kin has is the X-35b not even near the F-35B in production. I mentioned the part of research and the easiest fix was to re do the whole front of the jet as the front intake decks are all wrong for the actual F-35 B in production. Also that as modelers we would never be able to vertically lift off so why even attempt to produce an X-35 let alone a B' model. Don't get me wrong. Kudos for the excellent workmanship, its just been done on a model not in production. Can I have the fuse's that accumulate when they don't sell?
ApexAero is offline Find More Posts by ApexAero
Old Nov 25, 2010, 10:12 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
This model is from a friend's information to products it in our factory , but this friend are plan to Vertical lift off ! that why we are do this type . so i must follow him to complete it . Maybe he can success the vertical lift off system in the future .
kin is offline Find More Posts by kin
Old Nov 25, 2010, 05:10 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
He may need one of these!
Don't forget the F-35B has a single front intake hatch that opens rearward.
Old Nov 27, 2010, 09:57 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Any word on the f-15??
sikky is offline Find More Posts by sikky
Old Nov 28, 2010, 11:14 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
It should be after the F-20 . but the f-14 twins 90mm are completed the 3-D drawing , so maybe is F-14 and than F-15 .
Old Nov 28, 2010, 11:25 AM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Finally, I've been looking a long time for a F-14 twin 90mm.
Watching with interest.
Mikael is offline Find More Posts by Mikael
Old Nov 28, 2010, 11:33 AM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
Hi Kin this 90mm twin F14 sounds interesting. Will this jet have variable sweep wings?
William
TurboFanElectric is offline Find More Posts by TurboFanElectric
Old Nov 29, 2010, 10:49 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Interesting
alpea 41 is offline Find More Posts by alpea 41
Old Nov 29, 2010, 11:58 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
William
yes! sure make it sweep wing , it is the main point of this model , if the wing not moving , i have no interesting to build a (fix) wing model F-14 ! The moving mechanic have a completed concept . so it not so diffcult .just need a little electronic thing . it is no problem for me .it must easy than my ep retractable gear .
Old Nov 29, 2010, 12:06 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
It base on a TAMIYA big scale plastic model . this model very good detail . of couse i can not make the wing airfoil from a real plane . i have use a rc model airfoil to drawing the wing section . just very little change the scale (thickless only ) . all the scale are very close full size . so it should vey nice model .it is twins fan 90mm x 2 .1650mm length .it control by the tail wing only . no need the main wing aileron .
Old Nov 29, 2010, 03:44 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
That sounds great, about time some bigger 90mm models came out, make sure you can fit plenty of battery into it
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 29, 2010, 03:57 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
And of course you will build it around your electronic retracts right?
Pepperpete is offline Find More Posts by Pepperpete
Old Nov 29, 2010, 04:11 PM
rorrock is offline
Find More Posts by rorrock
Global Hobby Store
rorrock's Avatar
Brisbane
Joined Jan 2007
Kin,
Will be intersting to see how it handles with the moving COG as the geomety of the wing changes.. This has caused delays with a foamy version that's been in the works for a while.. I beleive its been sorted now though..
Rob
rorrock is offline Find More Posts by rorrock
Old Nov 29, 2010, 04:30 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Starmax's foam F14 suffered from undersize intakes and fans too small to provide enough power for the size of the model. The swept wings only required a little mix in the elevator and the model actually flies quite well with a half decent power system.
Cool Recived my TF model/smartmodel LYNX DC3_driver Scale Helicopters 33 Jun 29, 2010 04:49 AM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin 3D Electric Heli Flying 4 Jan 19, 2010 07:42 PM
Discussion Looking for test pilot for 3-D flying with Smartmodel/TF model narrow blades kin Electric Heli Talk 2 Jan 19, 2010 12:03 PM
