Old Feb 20, 2010, 10:59 AM
spacephrawg is offline
Find More Posts by spacephrawg
Naval gazing
United States, MA, Boston
Joined May 2008
Whats the dif between an AX SCX10 TR and an SCX10?
Is there any difference?
spacephrawg is offline Find More Posts by spacephrawg
Old Feb 20, 2010, 01:37 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Doesnt the TR come with a roll cage, bumpers and LED lights...................
scorpion1 is offline Find More Posts by scorpion1
Old Feb 20, 2010, 03:12 PM
nick84 is offline
Find More Posts by nick84
tater salad
nick84's Avatar
United States, IN, Mishawaka
Joined Jul 2008
the scx10 is more for the scale looks. with the rigid steel C-channel chassis.
nick84 is offline Find More Posts by nick84
Old Feb 21, 2010, 09:44 AM
Naval gazing
Joined May 2008
I thought they both had the rigid C-channel chassis. I posed the question on an RC crawlers forum and the first reply told me that they're basically the same thing but the TR only needs a charger and batteries to run, hence "TR" or "Trail Ready". Whereas the other requires you to contribute your own electronics and motor.
I have other questions regarding this thing. Should I start another thread for it or is this one OK?
Old Feb 21, 2010, 11:48 AM
jettrooper02 is offline
Find More Posts by jettrooper02
jettrooper02's Avatar
USA, WA, Bonney Lake
Joined Aug 2008
the only difference is the reply you got in the crawler forum, the tr version has electronics so you only need betteries and the rest don't. one version of the truck is only available as a trail ready car, and the rest there is one that's both and one that's only available as a kit.
jettrooper02 is offline Find More Posts by jettrooper02
Old Feb 21, 2010, 10:11 PM
Naval gazing
Joined May 2008
A stupid question: are these 1:8th or 1:10th? I keep getting conflicting info on this. Sometimes the scale is indicated by the size of the tire: 1:9. Its very confusing.
Old Feb 21, 2010, 10:33 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
1:10............
"This is the 1/10 scale, radio controlled, electric powered,
SCX10 Rock Crawler Truck kit from Axial Racing.
FEATURES: Chassis: Rigid steel C-channel, tapered for increased articulation
and added realism
Drive: Four wheel shaft drive
Shocks: Oil filled, with dual rate springs and oil reservoir
Tires: Pro-Line Flat Iron, (PROC1166) 1.9" (48.3mm) inner diameter
1.5" (38mm) wide with foam inserts
Wheels: Beadlock chrome 1.9" (48.3mm) diameter, 0.87" (22mm) wide
Ball Bearings: Full set enclosed
Spur Gear: Plastic 48 pitch, 87 tooth
Pinion Gear: Steel 48 pitch, 14 tooth
Old Feb 21, 2010, 10:48 PM
Naval gazing
Joined May 2008
Sorry for my high density. I have three smaller RC n00bs in orbit around me.
Old Feb 21, 2010, 10:55 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Originally Posted by spacephrawg View Post
sorry for my high density. i have three smaller rc n00bs in orbit around me.
lol..........
Old Feb 22, 2010, 09:11 AM
cableman is offline
Find More Posts by cableman
Long island
Joined May 2009
The scx10 kit has better metal links and no electronics, where as the TR has more plastic parts but is a rtr. I have the kit, its 1/10th but not a big truck.
cableman is offline Find More Posts by cableman
Old Feb 22, 2010, 01:40 PM
Naval gazing
Joined May 2008
I have this sneaking suspicion that it would cost me more to get the kit and put in my own stuff. If i got the RTR i would definitely improve the rear linkage and get a metal gear servo, but would it come out to the same? I already have a pair of bottom of the line AM 2ch radios which serve me just fine I think.
Probably whatever I do I'd put a better body on it.
Old Feb 22, 2010, 08:11 PM
Naval gazing
Joined May 2008
Which parts are plastic on the TR that aren't on the normal kit?
Old Feb 23, 2010, 05:49 AM
cableman is offline
Long island
Joined May 2009
All the link lenths, steering, upper and lower suspension links
some pic's from rccrawler
Its really nice looking though, i would get the honcho now!
Old Feb 23, 2010, 01:22 PM
Naval gazing
Joined May 2008
The TR kit is growing on me actually. I would gladly get metal bits to spruce it up though.
It would appear that this guy took the scale-ness of it a bit further:
http://www.scale4x4rc.org/forums/sho...ighlight=scx10
What draws me to this thing is a combination of affinity for the Landrover, budgetary considerations, and the combination of Lexan and injection molded bodywork.
a guy on the boating forum said he got a TR and has driven it really hard for over like 2 months and hasn't had any problems with it yet.
My dream setup would be to have a body that looks a bit more scale, but i can't afford that. Once in a while I see people use the lexan bodies as the basis for some very scale-looking constructions that give the injection molded things a run for their money. I'm not set up for that just yet.
Or if I really want a scale look, should I just go with a CC01 and be done with it?
I'd like the finished model to look like something you'd see driving around town rather than a jacked up rock-crawling monster that would make consumer reports cringe. nevermind that the model is supposed to be a rock crawler. I'm an aesthetics man after all.
What do you guys advise?
Old Aug 02, 2010, 08:12 PM
qandaenergy is offline
Find More Posts by qandaenergy
qandaenergy's Avatar
San Clemente CA
Joined Mar 2009
Hello,
I am looking to get one of these trucks in the near future. My problem is that I really want to build it but I want to get everything I need in one package deal. Is that possible or do I have to make a choice? I'll tell you that if a choice has to be made, I will probably go with the kit. I love the building aspect.
In the case that I get the kit to build, I need all the electronics. Can I do this on the cheaper side? I am completely new to this so please forgive my ignorance. I just found that the Trail Ready version has more plastic parts than the kit but with the electronics and radio gear it is only 30 dollars more. I am hoping to spend $350.00 or less if possible. Thanks.
Sean
qandaenergy is offline Find More Posts by qandaenergy
Discussion whats the dif between the AR6100 and the 6000? kushal_22 Electric Plane Talk 3 Apr 24, 2007 02:45 PM
Question Whats the performance dif between APC E & APC SF? dst Power Systems 10 Jan 04, 2006 10:29 PM
Question Dif between 10x5E & 10x4.7SF w 20-22L Hacker? dst Power Systems 0 Jan 03, 2006 12:17 AM
what's the dif between - and + shift?? nakman8 Radios 33 Jul 15, 2005 03:58 AM
Piccolo type? whats the difference between an Eco & fun? twinstarchris Micro Helis 17 Jan 02, 2004 06:00 PM
