Old May 22, 2003, 04:16 PM
larry g is offline
Find More Posts by larry g
branson mo
Joined May 2003
blue core stringless wonder
i had a peck stringless wonder ff a long time back, and always remember how good it flew, got a crazy urge ta make a bigger blue core one, so hot off the bench it is...
gws a powered, 9 x 7 prop, used 300 nimh for maden..it flys greate.... i have on order some hippobatts,qualcomms so it should
be even better soon.
larry g is offline Find More Posts by larry g
Old May 22, 2003, 05:16 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Hey!!! Now that's my kind of plane ...really cool!!!
gpw is offline Find More Posts by gpw
Old May 22, 2003, 07:31 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Wow and I thought I was having flash backs or something. Looks like a fun plane.
Thatovalguy is offline Find More Posts by Thatovalguy
Old May 22, 2003, 09:11 PM
CAFplanekid is offline
Find More Posts by CAFplanekid
De-Brushed user
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
This is weird... im working on building a balsa/renolds wrap stringless at this very moment, waiting for the glue to dry (elmers) when i noticed your post. Im going to use 370 mah nimh packs, IPS power, 10/4.7 prop, and a coulple hs50 servos, once o get em in. What is your wingspan, or should i say kitespan? How much does the bare airframe weigh? Pics soon of mine, if yould like.
CAFplanekid is offline Find More Posts by CAFplanekid
Old May 22, 2003, 09:36 PM
larry g is offline
branson mo
Joined May 2003
hellow cafplanekid.....my kite span is24 inches, length cord is 22 inches, motor stick fuse is 25 inches, ill weigh it up tomorrow and post . cg is right at the front of the cut out of the kite wing.
will be looking forward ta see yours.....happy flights, larry
Old May 22, 2003, 09:43 PM
De-Brushed user
Joined Dec 2002
It just gets weirder:
my w.s. is 23.5 inches.
Heres a pic, these planes fly well enough without a pilot, hope they fly as well with one:
Old May 22, 2003, 09:44 PM
De-Brushed user
Joined Dec 2002
Im not finished yet, need more balsa:
Old May 22, 2003, 09:47 PM
De-Brushed user
Joined Dec 2002
How does yours fly? Does it fly like the original? Ive built half a dozen rubber powered versions, all of em fley great once properly trimmed. Thanks
Old May 23, 2003, 07:35 AM
larry g is offline
branson mo
Joined May 2003
yes it flys verry smooth and gental, good sunday flyer...
Old May 27, 2003, 10:06 AM
Dodo Bird is offline
Find More Posts by Dodo Bird
RI
Joined May 2003
Hey I bet even I could build one!
Larry G can I bother you for more dimensions measurements?!
Wingspan 24
motorstick 25 inches
CG right in front of wing cut out...?
I like baseball, so using a baseball diamond:
Home base is the piece the motor comes out of (it even looks like home base).
First Base is one wing tip
Second base is the stabilizer, elevator, rudder.
Third base is the other wing tip.
Pitcher's mound is the cut out in the middle...
I can pretty much figure everything out from knowing that wing tip to wing tip is 24 inches long. I just need to know how far apart the two triangles are from each other (Pitcher's mound side to side?) If you tell me the diminutions for the Pitcher's mound I can get second base, home base, and make sure I have 1 and 3rd base correctly...
Also is CG just in front of the pitcher's mound towards home base?
Dodo bird
Dodo Bird is offline Find More Posts by Dodo Bird
max blue core size dottney Foamies (Kits) 5 Feb 12, 2009 10:26 AM
Blue Core Fan Fold in CANADA Avro Foamies (Kits) 25 Oct 04, 2005 11:29 AM
Blue Core Hurricane Forms In North Central Texas Larry J Sinor Foamies (Kits) 33 Sep 27, 2002 10:55 AM
RC Stringless Wonder? BrianRickman Electric Plane Talk 0 Aug 01, 2002 12:35 PM
150% Sig Stringless Wonder Jim McPherson Scratchbuilt Indoor and Micro Models 0 Dec 07, 2001 10:41 AM
