Old Feb 19, 2010, 12:02 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Data
Whats on your Work Bench!
Ok so your going to build a foamy and the million dollar question is what tools are needed to build a kits.
Well here is where you can post what works for you.
Ok so I will assume you are looking for the tools to build a epp type plane
Here is the basic stuff that I would have on hand to build a epp kit.
1 roll straping tape
1. box #11 x-acto blades
1. medal straight edge (18-24 inch)
sharpie pens for color
5 minute epoxy" If you like"
hot glue gun with low temp sticks my glue of choice
a medal squre to make sure all parts are aquare and straight
wax paper is good to have so you dont get glue on your table
foam safe CA glue + Kicker
a bag of throw away lighters for heating shrink tubing"if you dont own a heat gun"
3mm77 contact spray
roll of blue painters tape is allways good
Part 2 is a list of items RC related to build a basic foam plane.
1. sheet 18 x 36 1.3# 9mm epp white foam.
2. 40" x 3mm carbon rods or tubes
3. gram servos (I used bluebirds from a old slofly I had) or tower pro 5-9 gram
1 1300kv blue wonder outrunner type motor
1. gws 8040 hd prop
1. prop saver + bands
1 set Dubro micro pushrods (20-30") version
2 sets dubro quick connects
1. motor mount" The kind I offer"
2. sets dubro micro horns
1. sheet of lightply 16th inch thick
1. 9-10 amp brushless esc
battery used is 7.4 volt to 11.1 volt 3 cell 300-600 mah is what I use.
1 small 4 channel receiver (I use the gws 4 channel)
1 transmitter I would recomend a basic computer radio you will thank me later)
1 lipo battery charger
tallflyer is offline Find More Posts by tallflyer
Discussion Work Bench help rzs_racing Sailplane Talk 26 Jan 27, 2010 06:22 PM
Discussion Whats on your bench? Ranfred Radius The Builders Workshop 28 Feb 24, 2009 10:42 PM
Discussion Let's See Your Work Bench!!! DaDesign Foamies (Scratchbuilt) 12 Feb 06, 2009 11:51 PM
Discussion What does your work bench look like? macboffin UAV - Unmanned Aerial Vehicles 65 Sep 03, 2007 01:54 PM
whats on your bench? Tawg Slope 126 May 15, 2007 06:34 AM
