Old Feb 18, 2010, 04:17 PM
ffokazak is offline
Find More Posts by ffokazak
Vancouver BC
Joined Feb 2010
My 480 Brushless Moves in and out when throttle applied....
Is this normal?
If I hold my plane, And give it WOT, the whole motor seems to move forward.
I can pull the prop, and see the motor separate a bit.... i would say 7-10mm
Seems fishy....
ffokazak is offline Find More Posts by ffokazak
Old Feb 18, 2010, 04:56 PM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Originally Posted by ffokazak View Post
Is this normal?
Seems fishy....
7 to 10mm??
that is way too much.
Perhaps a mm at most is normal.
You should post pics of your motor.
Seems like your C clip retaining ring is missing, or depending on the way your motor is built, the collet may not be on or tight enough.
Pics!
cryhavoc38 is online now Find More Posts by cryhavoc38
Old Feb 18, 2010, 05:27 PM
ffokazak is offline
Vancouver BC
Joined Feb 2010
Oh ok, on the back of the motor there was a collet and an allen key screw, I tightened it up, and now it moves around 1-2 mm, with a kind of springy tendency.
So that sounds normal then!
thanks!~
Old Feb 18, 2010, 06:18 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Is it a CD-ROM style motor? Those usually have a narrow groove that the set screw goes in and that should prevent any movement. Also look at the back of the motor and see if the snap ring on the shaft extension in the back is flush up against the inner bearing race. there may be a thrust washer beneath the snap ring.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 21, 2010, 12:58 PM
cryhavoc38's Avatar
Joined Mar 2007
thanks!~
Yes, this is normal. The bell housing magnets are attracted to the stators inside. This springy tendancy is the magnetic field pulling the internals back.
Discussion DX7 Need help, Flaps turn on when power applied OriginalDboy Radios 5 Feb 06, 2010 11:29 PM
Discussion Why does my TX/RX not respond properly when stick moves fast? anderson12 Coaxial Helicopters 6 Nov 24, 2009 09:35 AM
Help! Glitches when throttle is applied suddenly E-flight1 Radios 3 Aug 05, 2009 06:12 PM
Help! Throttle increases when Elevator or Rudder is applied wonginator1221 Beginner Training Area (Aircraft-Electric) 5 Aug 31, 2008 08:47 PM
Throttle servo moves when elevator servo is moved chris8105 Fuel Plane Talk 22 Jan 10, 2007 02:53 PM
