I have experience with all of these engines. I have a stroked FS-20. This was done according to an article in MAN soon after the FS-26 was released, by using a FS-26 crank which has a larger stroke. It displaces ~.25ci. All you needed was the crank, a spacer to raise the cylinder liner (for appropriate compression ratio), and new music wire pushrods. I got it off thebay as an FS-20 but quickly realized what it was.
FS-26 has a slightly larger bore and larger stroke than FS-20. FS-30 has a larger bore than FS-26. Externally the components are very similar. The height of the crankcases varies as does the bore for the liner. The heads have different combustion chamber volumes and sealing face diameters to accommodate the liners. You could probably use a 26 or 30 head, but the carb mount bolt in the back might not line up and you will have a different CR if you don't account for CC volume. Unless the liner is scored I would use it. Check to see if the valves are leaking. A ring could be purchased from Frank Bowman. If you end up dumping the FS-20 I may be interested. You could always go this route. ![]() Greg |
Latest blog entry: A tiny diesel engine AE 0.1CC
Even the Saito FA-30S and FA-40a share at least ONE part with these OS "mills"...!
Dear Fellow Small 4-Stroke Fans:
The PIPE here...and where I've already got a Saito FA-30S "later model" four stroke (with the fully enclosed valvetrain), and hope to be able to get back to work to help get a Saito FA-40a engine for a CAD-drawn RC Scale model construction plan project I've been working on lately, I was glad to find out quite some time ago, through the help of my LHS, that the exhaust port threads on the Saito FA-30S and FA-40a are the EXACT SAME (M9 x 0.75mm pitch) threading as the "fluid-nut" style exhaust header retention nut that's used on ALL THREE of the small OS four strokes mentioned earlier in this forum thread, as my Saito FA-30S engine easily accepted the OS FS-30's exhaust gear, and "back again" between the two engines.That could mean that one might want to use a Saito FA-30S or FA-40a exhaust setup on their OS engine, and "vice versa" for the Saito "mills", as I expect to need to do for my CAD plans project, to help make a custom exhaust setup for use with either the FA-30S or FA-40a. The "involved fluid-nut-like part" that fits ALL five four-stroke engines' exhaust ports that I've brought up here is still available from Tower, at http://www3.towerhobbies.com/cgi-bin...5776&search=Go ... I may get three OR four of these before too much longer, as I WOULD have uses for all of them. It's amazing how these sorts of things work out, sometimes...even BETWEEN engines from two competing firms, which both make very nice four stroke powerplants ! Yours Sincerely, The PIPE!
Yes, I discovered that a while back when somebody asked me to make a custom exhaust for the FS-30. I happen to have the Saito FA-40 and OS FS-30 on the bench. One of the Saito elbows with the stock FS-30 manifold worked for him. I think two of the Saito elbows would allow virtually any exhaust angle one could imagine. And they are cheap.
http://www.horizonhobby.com/Products...rodID=SAI40A75 It really is too bad the engine manufacturers don't agree on things like that. It would make for plenty of aftermarket muffler product availability. Greg |
You MIGHT want to try contacting BJ's Model Engine Repair...
Dear b7gwap:
The PIPE here again...one thought on repairing/replacing that damaged FS-20 cylinder head might be to contact BJ's Model Engine Repair up here in New England about your needs...I believe I've seen that place recommended in the AMA magazine before, and it couldn't hurt to at least TRY contacting them to get something done for your FS-20, with the damaged cylinder head. Their Web address is at http://www.bj-model-engines.com/home.html , and I'm hoping that they might be willing to help you out. Hope this might be able to help... Yours Sincerely, The PIPE!
| Thread Tools | |
| Wanted WTB: OS FS26 or FS30 Surpass | sshewchuk | Aircraft - Fuel - Engines and Accessories (FS/W) | 6 | Jan 16, 2010 08:25 PM |
| Found OS FS30 four stroke needed | bubbap51 | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Apr 04, 2008 12:27 PM |
| For Sale Rare & Collectible OS FS20 | SRM | Aircraft - Fuel - Engines and Accessories (FS/W) | 3 | Oct 18, 2007 02:01 PM |
| OS FS30 with 100% Synthetic Low Viscosity Lubricant, can or can't? | sajja | Engines | 2 | Aug 25, 2005 03:38 AM |
