Old May 22, 2003, 04:59 AM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Foam Safe Paint - Createx
I've been using Createx paint on my foam airplanes and wanted to let everyone know that it works great and does not damage foam. The paint is water-based, designed to be airbrushed and will stick on just about anything. It comes in 76 different colors including opaques, transparent, pearl, iridescent, fluorescent and chameleon (changes color depending on what angle it's viewed at). The opaques and fluorescent colors can be brushed on, but airbrushing is much better. You can get a retarder which will slow down the drying time in hot and/or humid areas, a clear-coat (most of the colors dry with a flat finish) and a flexirizer (makes the paint flexible so it won't crack and peel when sprayed onto something...well, flexible). By the way; for those of you who also run R/C cars, this is the same paint that Parma International sells under the Faskolor name to paint clear Lexan bodies - except it's cheaper to buy it under it's original name plus it is available in larger bottles. Createx is available at many artist and crafts stores.
babblefish is offline Find More Posts by babblefish
Foam Safe Paint? glenclif Parkflyers 5 Jan 04, 2007 01:51 PM
Foam safe paint for cub from tower Silent Electric Plane Talk 13 Dec 13, 2005 06:43 AM
Foam Safe Paint Riz UH60 Foamies (Kits) 0 Apr 30, 2005 04:49 PM
Nelson Foam Safe Paint Todd Long Foamies (Kits) 0 Mar 13, 2004 01:37 PM
Foam Safe Paint mrtim Foamies (Kits) 3 Jun 26, 2002 05:16 PM
