Old Nov 13, 2012, 05:49 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
From what I hear powered dives are actually slower than glide dives.
But yea I will take it a little easier on it.
UlteriorModem is offline Find More Posts by UlteriorModem
Old Nov 13, 2012, 11:16 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
dynamic-s
ok folks, i just was referred to this thread when i was asking for data on the dynamic-s from hobby king, and it seems to be a clone of this 1.
for that, i hope am not considered intruding.
could any1 tell me if hobby king sells a motor that matches the 1 used in this plane?
thanks
phil alvirez is offline Find More Posts by phil alvirez
Old Nov 13, 2012, 11:29 PM
Joined Jul 2007
more data on the motor
Originally Posted by curly56 View Post
Thanks for the reply!
Looks like I'll be waiting for a while. Time to build something to use that motor on in the mean time.
Looks like a 480 class motor maybe good for 350 watts or so. Mine has 1150KV printed on the shrink tubing that surrounds the base of the motor leads.
hi: am trying to find a replacement motor that fits this plane. could you please tell me more about your motor? its weight, for instance? a picture? is the shaft 4mm?
thanks
Old Nov 14, 2012, 12:09 AM
Joined Jul 2007
motor for the dynamic
regarding the motor for the dynamic, searching on this thread i also found this from maca55 (post 973):
the Hobbyking version Durafly Dynamic-S (don't ask why).
For reference:
38.5mm Overall length (not including shaft)
20.5mm Can length
35mm Can diameter
920kv (stamped on to the heatshrink - only marking)
121.5g weight (incl connectors)
4mm shaft
14mm shaft length
i wish he could tell me the exact part number from hk.
Old Nov 14, 2012, 12:53 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Yeah I put it to the test a few weeks back with a GPS logger on board. I did several climb outs then rolled over into a vertical. To get max speed throttle could be punched only at the very start of the dive. If you kept the throttle on through the dive the prop created drag. From memory top speed I achieved was around 83mph from a vertical un-powered dive.
On another note I had a rare crash with this glider last week. In the past I have always flown this glider under windy 20-30kmh or more without incident. Last weekend the wind was quite lite at around 10kmh. Anyway I had it powered off into the wind going real slow. In high winds this was never a problem. I even had it moving backwards a few weeks ago in high winds. It was no go going slow with power off with this bird in low winds. I had it into the wind moving real slow, and I glanced over at a friends YAK55 which was close by when it suddenly dropped a wing and spiraled in nose first smashing the front end in. Nothing plenty of glue and a bit of patience could not fix though. Now I'm just waiting for the weekend to see if she still flies straight and true under power
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Nov 14, 2012, 02:06 AM
maca55 is offline
Find More Posts by maca55
Australia, VIC, Chadstone
Joined Dec 2011
For reference:
20.5mm Can length
35mm Can diameter
4mm shaft
14mm shaft length
These measurements were all taken from the stock motor that came with the Dynamic-S PNF. I don't believe they sell the exact same motor individually, however this motor seems to have very similar specs: http://www.hobbyking.com/hobbyking/s...dproduct=14847
maca55 is offline Find More Posts by maca55
Old Nov 14, 2012, 05:32 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
regarding the motor for the dynamic, ...i wish he could tell me the exact part number from hk.
Not saying it's always the case, but in my experience it's kinda rare for any motor on a plane sold by HK to be listed under HK's inventory unless it's shown/sold as a direct replacement part.
I believe that's because the motor used on the plane isn't HK's call at all, but is a decision made by the plane's mfr, and like as not, it's produced by one of their subsidiary companies or bought under contract to be used in the plane's production.
IOW, like General Motors isn't gonna go to Smith's Chevrolet Inc dealership in Dallas to supply the engines for the Chevies they produce in Arlington - kno'm sayin'?
'Catalog' motors are gonna cost considerably more than what can be bought en masse thru mfr contracting - prime reason for doing it that way, allowing motors that'll barely scrimp by on performance & sometimes even appearance, which helps keep final selling price down & makes the product viable for generating profit -- while on the other hand, 'catalog' motors are the product in & of themselves. Hence, coincidentally rare you'll find 'build' motors being available as 'catalog' motors, & in almost all cases the latter being considered 'upgrades', with their own profit margins built in.
My 2 !
StarHopper44 is offline Find More Posts by StarHopper44
Old Nov 14, 2012, 05:59 AM
Joined Jul 2007
absolutely
yes sir, well said. i was trying to see if this could be the case.
thanks for words of wisdom.
Old Nov 14, 2012, 06:16 AM
Joined Jul 2007
the closest
thank you sir. that's the 1 that i was considering at this thread:
http://www.rcgroups.com/forums/showt...3#post23238871
seems the closest. i already ordered and will tell here how it works.
thanks again.
Old Nov 14, 2012, 12:44 PM
OldeMan is offline
Find More Posts by OldeMan
Faster is Better
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
Stupid question time: I just received my new Dynamic-S... and I've installed a Spektrum AR6115E... which is described as a "Park Flyer" Rx. Am I inviting range issues with this plane, considering how quickly it can get "far away"?
I have an AR400, but it wouldn't allow me to do flaperons. And I have an AR8000 that seems like overkill. I'd like to use the AR6115E, but am unclear about how much range I can expect from it.
So AR6115E: Safe, or stupid, for a Dynamic-S?
OldeMan is offline Find More Posts by OldeMan
Old Nov 14, 2012, 01:12 PM
Earthbound Skyhound
Joined Jun 2011
Go here & read this entire thread.
http://www.rcgroups.com/forums/showthread.php?t=1471385
1000' range:
Have someone hold your Blaze standing beside the road, drive your car 2/10 mile away. That's 1056'. Get out, turn around, & look at -- make that, look 'towards' your plane. Operate your Tx's sticks, drive back & ask holder were the controls working.
This test should remove any doubts you might have.
Old Nov 14, 2012, 03:55 PM
OldeMan is offline
Faster is Better
OldeMan's Avatar
Joined Jul 2012
1000' range:
Two excellent suggestions. Thanks.
Old Nov 14, 2012, 04:12 PM
Earthbound Skyhound
Joined Jun 2011
And I hope the subtlety in 'look towards' didn't escape you?
Old Nov 15, 2012, 02:27 PM
Joined Jul 2007
and have you consider this 1?
http://www.hobbyking.com/hobbyking/s...or_1000kv.html
just look at the specs:
Turnigy L3730A-1000 Brushless Motor
Specifications:
Dimension: 37mm x 30mm
Weight: 112g Inc 4mm Gold Connector (130g inc all fittings)
Kv: 1000rpm/V
Voltage: 11.1v~14.8v (3s~4s)
Max Power: 580w
Max Current: 42A
No load Current: 1.6A
Diameter of shaft: 4mm
Thrust: 1700g
ESC: 60A
PRODUCT ID: 244000005
they don't tell you the prop, but shows lots of power-or could be that it is with 4 cells?
Old Nov 15, 2012, 04:31 PM
Earthbound Skyhound
Joined Jun 2011
Divide the max 580W by the max 42A current, = 13.81V.
Would have to come from the 4s.
Discussion X-models xray sport hotliner details needed. stevext Electric Sailplanes 1 Nov 03, 2014 02:34 PM
Discussion ST Models Fox EP ARTF Kn0bby Electric Sailplanes 10 Jun 29, 2011 10:42 PM
Sold ST models RTF Cessna avoidingexpert Aircraft - Electric - Airplanes (FS/W) 2 Jan 25, 2010 05:15 PM
Discussion ST Models DG1000 Elite Aerial Photography 0 Dec 20, 2009 11:07 PM
Discussion ST Models Piper Cub EP ARTF Baz Ck Electric Plane Talk 0 Sep 02, 2009 10:37 AM
