Old Oct 25, 2012, 07:13 AM
maca55 is offline
Find More Posts by maca55
Australia, VIC, Chadstone
Joined Dec 2011
Originally Posted by Gerry__ View Post
M3.0x22
They are M4 on the Dynamic-S, not M3. I would have expected the Blaze to be the same.
You can get away with shorter on the front (17-19mm) and it helps avoid damage to your LiPo as you slide it in from the front.
maca55 is offline Find More Posts by maca55
Old Oct 25, 2012, 08:02 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
You might want to consider nylon fasteners too. They'll shear off in a crash w/o so much tendency to tear up your foam.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 25, 2012, 09:42 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
I quoted from the manual.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Oct 25, 2012, 10:05 AM
maca55 is offline
Joined Dec 2011
Hmmmm.. funny you mention that. I experienced the 'tear up' today at a slope trying to land in a 30 knot cross wind. It came down rather hard and the guts were literally ripped out as the wings spun round. I will upload a link to the action soon.
Old Oct 25, 2012, 11:30 AM
Earthbound Skyhound
Joined Jun 2011
Ya...it's an unfortunate nature of the beast with gliders & their long wings. You see 'em upstairs with all their grace & beauty, & don't think about how ya better not get close to the ground with wings anything but level, or things can get ugly real quick! And it's surprising how much a seemingly minor li'l cartwheel can tear up! A lesson learned the hard way, for me!
Old Oct 27, 2012, 02:49 AM
sookainian is offline
Find More Posts by sookainian
Joined Dec 2007
Can anyone please tell me the difference between Blaze and Dynamic-S ?
sookainian is offline Find More Posts by sookainian
Old Oct 27, 2012, 03:49 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
I doubt if anyone here owns both to be able to thoroughly compare, but they seem almost identical.
Old Oct 27, 2012, 04:21 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Blizzard > Blaze > Dynamic-S it appears to be a cloning evolution. The Dynamic-S is the cheapest and is hard to fault(apart from that turn left thing) so I don't see any reason why you choose the more expensive option unless the cheaper one was flawed in some way. I tossed my Dynamic-S up into a 40kmh southerly again this morning and had a great time. At one point I had it powered off into the wind and it just hovered moving backwards looking kind of strange.
Bravo47 is offline Find More Posts by Bravo47
Old Oct 27, 2012, 05:02 AM
Earthbound Skyhound
Joined Jun 2011
Goin' by my notes, the only diffs besides the decalry are:
Blaze Dyn-S
Motor: 3520 - 1130Kv 35xx - 820Kv
Prop: 10x6 Folder 12x6.5 Folder
The plastic plate that covers the V-Tail servos is different, or not present on the 'S'.
Price: $129.99 w/Free Ship (Tower) vs $118.34 + $43.33 Shipping* from Hobbit Kong USA Warehouse.
*And this bullcrap stunt of theirs cost them ANY future airplane business from me.
Phoenix 2000 from Same warehouse, bigger box, weighs 1 kilo more; shipping was $17. I even contacted their "customer service" about the obvious error, and they told me I was wrong. I showed them the invoice.....and whattaya know - suddenly my messages started bouncing.
Old Oct 27, 2012, 08:06 AM
Joined Dec 2007
Anyone notice the tail mounting is slightly different ? the dymanic-s one seems like bolt on. But the Blazz like no mount ?
Old Oct 27, 2012, 10:57 AM
Earthbound Skyhound
Joined Jun 2011
Well, that's kind've why I said .............
Oh, never mind.
Old Oct 27, 2012, 02:43 PM
Bravo47 is offline
Australia
Joined Jun 2010
We have the same issue getting stuff from the US to OZ, or even from the UK to OZ. Hobbyking is the cheapest postal option for down under as far as I know.
Old Oct 27, 2012, 03:37 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Just got gifted enough parts to put one of these together. Motor was loose. While putting it in I realized there is a high probability of the outrnner cage rubbing the wires to the ESC.
Am I just putting it in wrong? Or did I miss this as an issue.
Any photos of your motor and wiring installs is appreciated!
UlteriorModem is offline Find More Posts by UlteriorModem
Old Oct 27, 2012, 06:13 PM
Bravo47 is offline
Australia
Joined Jun 2010
Rotate your outrunner in its mount to a position so the wires come out at around 4-5 oclock should give you plenty of clearance. They rub if you mount the wiring at 6 oclock.
Mick
Old Oct 27, 2012, 07:20 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Closed Account
Joined Dec 2005
I really hate it when I get 'gifted' with crap. I would just assume they gave me junk.
None the less, something sounds fishy with your setup. There should be a wooden mounting tray just behind the motor. The motor gets mounted with the three wires coming out a about 5 o'clock. The wires then move along the right side of the fuse and come thru the horizontal slot/opening in the wood tray. This pins the wires between the wood tray and the interior side of the fuse.
If that won't work, then you could mount at 6 o'clock and pull the wires straight back and up thru the ciruclar opening in the tray. If you take this path, you will still need to hot glue/tape/something the wires to interior bottom of the fuse. White/clear silicon can also be used, works great to keep the plastic nose cone on.
Lou is offline Find More Posts by Lou
Discussion X-models xray sport hotliner details needed. stevext Electric Sailplanes 1 Nov 03, 2014 02:34 PM
Discussion ST Models Fox EP ARTF Kn0bby Electric Sailplanes 10 Jun 29, 2011 10:42 PM
Sold ST models RTF Cessna avoidingexpert Aircraft - Electric - Airplanes (FS/W) 2 Jan 25, 2010 05:15 PM
Discussion ST Models DG1000 Elite Aerial Photography 0 Dec 20, 2009 11:07 PM
Discussion ST Models Piper Cub EP ARTF Baz Ck Electric Plane Talk 0 Sep 02, 2009 10:37 AM
