Old Mar 07, 2011, 01:32 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Originally Posted by glaros View Post
Thanks for the suggestions.
I plan to replace the stock ESC with a 40A Turnigy ESC.
I do have a Aeronaut 10x6 and a CAM 11x7 that I plan to try. I will also get the blizzard spinner.
By the way, where did you get your blaze from Ben D Wing?
I bought mine from here.. http://www.inwoodmodels.com/product_...3eba3221aa82c8
You'll find that with a 11" x 7" prop that the motor will draw about 42A which is too much for the motor and it will not improve the rate of climb over the 10" x 7", but it will generate a lot more heat and slow the motor down. It's a bit like starting your car off in 3rd gear; it'll go, but the rate of acceleration is slow and it stresses the engine. By all means try the prop, but don't expect efficient performance.
Ben D Wing is offline Find More Posts by Ben D Wing
Old Mar 07, 2011, 03:00 AM
HBFP NL is offline
Find More Posts by HBFP NL
Kingdom of The Netherlands
Joined Nov 2009
The stock prop flies oke, a CamCarb same size performs better according my data logs.
I liked the change to the 10x7 very much. The speed increases a lot (horizontal and vertical). It just add some balls
I have no slopes just a field maybe thats why I like the 10x7 so much.
HBFP NL is offline Find More Posts by HBFP NL
Old Mar 07, 2011, 03:54 AM
glaros is offline
Find More Posts by glaros
glaros's Avatar
Greece
Joined Apr 2004
Thanks, I have settled to the Blizzard spinner and 10x7 prop now I just have to buy the plane
glaros is offline Find More Posts by glaros
Old Mar 07, 2011, 10:30 PM
King Pin is offline
Find More Posts by King Pin
"ya can't get hurt in the air"
King Pin's Avatar
United States, NY, Cazenovia
Joined Oct 2009
Hey HBFP NL,
Did you use the stock ESC with that 10x7? If so did you notice it getting hot at all?
Thanks, Tim
King Pin is offline Find More Posts by King Pin
Old Mar 08, 2011, 12:07 AM
HBFP NL is offline
Joined Nov 2009
I use a 40A ESC with the 10x7 as it pulls around 35A in peaks. It does not heat up that much. According my data log around 50 degrees Celcius.
I do not fly with open throttle all the time. I speed up and glide down most of the time.
Kyosho Hype WoW | OnBoard Cam (8 min 54 sec)
Old Mar 14, 2011, 06:02 AM
glaros is offline
glaros's Avatar
Greece
Joined Apr 2004
One more question before deciding where to buy the plane from:
Is there any differentiation among the ST Models, Ripmax, Wow etc versions of the plane apart from the different colored decals?
Are they all made from the same material and is this material equivalent to elapor used by Multiplex. Can you use regular CA like with elapor?
These are probable sources of the model at Europe:
Ripmax: http://www.wheelspinmodels.co.uk/air...P-ARTF__103a3/
ST models: http://www.myhobbystore.co.uk/produc...-artf-a-stm090
wow: http://www.modellhobby.de/Models/Mod...&t=3&c=31&p=31
wow: http://shop.lindinger.at/product_inf...ducts_id=85729
Old Mar 14, 2011, 07:11 PM
King Pin is offline
King Pin's Avatar
Joined Oct 2009
I believe the models are the same and regular CA works fine on the Blaze.
Old Mar 14, 2011, 07:13 PM
King Pin is offline
King Pin's Avatar
Joined Oct 2009
Has anyone tried a 10x7 with the stock ESC? Anyone?
Old Mar 15, 2011, 06:05 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
The models are indeed all the same (just the decals differ) and medium viscosity cyano is perfect for the assembly. Foam safe and epoxy type adhesives are not suitable for this type of foam.
The stock ESC and a 10" x 7" prop might work, but the quality of ST Model ESCs is not the best (same as their MX2) and for piece of mind a known quality aftermarket 40A unit is highly recommended.
Old Mar 15, 2011, 07:08 AM
HBFP NL is offline
Joined Nov 2009
The 10x7 pulls about 36Amps on my Wow.
I am sure you want a upgrade on the ESC
Old Apr 09, 2011, 09:36 AM
davehuge is offline
Find More Posts by davehuge
France, Languedoc, Villar-Saint-Anselme
Joined Apr 2011
Flight time on 2200 mAh...?
Just bought a ST Models Blaze and had first flights yesterday, great fun.
Setup is completely standard and I'm running with brand new 2200mAh Turnigy packs, I'm flying from a flat field.
So far I've limited my flight times to a conservative 6 minutes and when recharging I'm putting in appox. 750mAh.
Can anyone answer these questions...
1. Is it correct to assume that the flight has consumed 750mAh?
2. How much of the theorectical 2200mAh is it practical to use?
3. Can anyone what approx flight time I should aim for?
Any answers / advice appreciated.
Thanks, Dave.
davehuge is offline Find More Posts by davehuge
Old Apr 09, 2011, 09:48 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Thanks, Dave.
I Dave and welcome.
Here's my take:
1. Yep
2. 80%
3. All depends how much you run the motor.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Apr 09, 2011, 09:52 AM
davehuge is offline
Joined Apr 2011
Thanks for that Gerry.
So based on 80% consumption....I have 1760mAh to use.
At 6mins I'm using 750mAh...double it to 12mins = 1500mAh
Sounds good to me, I'll try it at 10 minutes this afternoon.
Thanks, Dave.
Old Apr 09, 2011, 10:24 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Thanks, Dave.
Yeah, but it all depends on how much you run the motor. I only use the motor to get up to altitude and than glide down, looking for lift all the time, of course. So you might like to look at battery consumption in terms of the amount of full throttle climbs you can get out of a pack rather than the over all flight time.
Old Apr 09, 2011, 11:54 AM
davehuge is offline
Joined Apr 2011
Yes, understood that, thanks.
The 6 mins flights consuming 750mAh were a mixture of quick climbs followed by glides with a bit of aerobatics thrown in.
Do the Lipo packs suffer from lower capacity with use, I mean the more times they are cycled?
Thanks again, Dave.
Discussion X-models xray sport hotliner details needed. stevext Electric Sailplanes 1 Nov 03, 2014 02:34 PM
Discussion ST Models Fox EP ARTF Kn0bby Electric Sailplanes 10 Jun 29, 2011 10:42 PM
Sold ST models RTF Cessna avoidingexpert Aircraft - Electric - Airplanes (FS/W) 2 Jan 25, 2010 05:15 PM
Discussion ST Models DG1000 Elite Aerial Photography 0 Dec 20, 2009 11:07 PM
Discussion ST Models Piper Cub EP ARTF Baz Ck Electric Plane Talk 0 Sep 02, 2009 10:37 AM
