Joined Oct 2006
I just received my Blaze from Tower Hobby. One comment and a few questions. I was a little surprised to find the prop already installed. I am no expert but after experiencing the bite of a prop resulting in multiply sutures I will never assemble a plane with the prop in place. Put the prop on last!!! Now for a few questions. I have never flown or setup a V tail. If I move the rudder control stick to the left what should the the left and right rudder do? Go up or go down.I assume aileron differential is helpful and spoilerons are helpful in landing. To make myself clear: When activating spoilerons both ailerons go up. This allows for slower landings. As I recall the nose of the plane tends go up and a mix with down elevator is desired. Is this correct? I am aware the manual has nothing about differential and spoilerons but I would like to learn this aspect as I have molded hotliner that I have never flown. A few years back I was able to purchase a used hotliner at a good price. I hope the Blaze is a good plane to learn with and gives me the confidence to setup and fly the molded hotliner in the future.
tekajo, spoilerons cut lift and cause the nose to pitch down. flaperons increase lift and cause the nose to pitch up. Both increase drag. I use a small bit of down elevator for the spoilerons on my Merlin, but I've read the elevator mix different depending on the plane. Just test spoileron/elevator mixes up high to see what happens to the plane before you use them for landing.
I have a 65" Fully molded Hotliner that I have spoilerons setup on. With 45 degrees of spoileron I don't need any elevator at all. |
I plan to replace the stock ESC with a 40A Turnigy ESC. I do have a Aeronaut 10x6 and a CAM 11x7 that I plan to try. I will also get the blizzard spinner. By the way, where did you get your blaze from Ben D Wing? |
| Thread Tools | |
| Discussion ST Models Fox EP ARTF | Kn0bby | Electric Sailplanes | 10 | Jun 29, 2011 10:42 PM |
| Sold ST models RTF Cessna | avoidingexpert | Aircraft - Electric - Airplanes (FS/W) | 2 | Jan 25, 2010 05:15 PM |
| Discussion ST Models DG1000 | Elite | Aerial Photography | 0 | Dec 20, 2009 11:07 PM |
| Discussion X-models xray sport hotliner details needed. | stevext | Electric Sailplanes | 0 | Oct 12, 2009 04:05 PM |
| Discussion ST Models Piper Cub EP ARTF | Baz Ck | Electric Plane Talk | 0 | Sep 02, 2009 10:37 AM |
