Old Feb 15, 2010, 08:18 PM
MercerMaggot is offline
Find More Posts by MercerMaggot
Canberra Australia
Joined Jun 2009
Saito FG-14 Carby
Does anyone know if the carby for this gas engine is the same carby as for the Saito FG-20?
I'm trying to get a replacement carby for the Saito 14cc, but am having no luck with the Australian distributer for Saito. I've been waiting nearly 3 months now.
I understand that the carby's for the Saito 20cc are being swapped by the US distributer for a new one in the US, and I want to look at getting hold of one of these if they are the same as on the smaller engine. I understand that they were problematic for the 20cc in that the fuel pump was a bit weak, but that they should be OK for the smaller 14cc engine.
MercerMaggot is offline Find More Posts by MercerMaggot
Old Feb 16, 2010, 02:04 AM
b7gwap is offline
Find More Posts by b7gwap
It's Prime Time for Slime Time
b7gwap's Avatar
Joined May 2004
Not sure on the size, but they are simply a pump carb for glow powered Saitos, so make sure you drain every last drop of petrol out of it every time you fly or bye bye diaphragm.
b7gwap is offline Find More Posts by b7gwap
Old Feb 16, 2010, 11:29 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Horizon doesn't have a parts listing for the FG-14 yet. The manuals doesn't do any good because it doesn't differentiate between the FG-14 and FG-20.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Feb 16, 2010, 11:36 AM
b7gwap is offline
b7gwap's Avatar
Joined May 2004
Greg
And the manual for my 20 is the same as the 36, which has a legitimate carb on it, a Walbro.
Old Feb 16, 2010, 11:56 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I don't understand your comment about leaving gas in the carb. The carb is made for gasoline not methanol.
Greg
Old Feb 16, 2010, 02:14 PM
Canberra Australia
Joined Jun 2009
Thanks for the advice. There is a new manual for the Saito gas engines on the Horizone Hobby site, but it's hard to know what parts are common to what engine from the exploded views/parts list.
Old Feb 16, 2010, 03:18 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Right, you won't know until the parts list for each engine is available. They use the same dash number but the prefix will tell you if it's the same part or not.
Greg
Old Feb 16, 2010, 08:23 PM
b7gwap is offline
b7gwap's Avatar
Joined May 2004
Greg
The instructions state explicitly that your fuel pump diaphragm will be deteriorated and eventually destroyed if you leave any fuel in it.
Discussion Saito Fg-20 Gas Engine viperjody Engines 7 Feb 23, 2010 08:15 AM
Discussion Saito FG-20 Gas Engine sarg96 Engines 3 Feb 10, 2010 09:28 PM
Sold Saito FG-20 Gasoline Four-Stroke Engine Dynomike Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 15, 2009 05:58 PM
Discussion Saito FG-14 Best aircraft size? MercerMaggot Engines 3 Nov 03, 2009 02:37 PM
Sold NIB Saito FG-36 $490 shipped whitewater Aircraft - Fuel - Engines and Accessories (FS/W) 6 Nov 01, 2009 11:44 AM
