Old Feb 19, 2010, 09:22 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Mod-
Nice report! I have two 2 meter motor gliders, one has full blown spoilers, the other has "spoilerons"...both require a slight spoiler-to-elevator up mix to keep the nose from dipping when deployed on approach. FYI. Possibly a good idea for the 4site as well.
It's really cool to deploy them on approach and watch the descent rate and pitch attitude adjust for a perfect spot landing.
Bud, missing-summer-soaring Bud
maukabud is offline Find More Posts by maukabud
Old Feb 20, 2010, 07:13 AM
humveeflyer is offline
Find More Posts by humveeflyer
heli addict
humveeflyer's Avatar
Ohio
Joined Nov 2003
Thanks you modfly for this thread. Is it possible to program flaps into the um p-51?
humveeflyer is offline Find More Posts by humveeflyer
Old Feb 20, 2010, 07:58 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Not without adding a second servo. The 4site has 2 aileron servos.
UNGN is offline Find More Posts by UNGN
Old Feb 20, 2010, 10:54 AM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
United States, OH, Cleveland
Joined Dec 2006
Originally Posted by maukabud View Post
Mod-
I will eventually try spoilerons to. I do not have any gliders per say but I have been using spoilerons in a few of my planes with good results. I do use a elevator mix with spoilerons as well. I talked about Flapperons\Spoilers here http://www.rcgroups.com/forums/showp...6&postcount=21
I can not wait for winter to be done!
modfly is offline Find More Posts by modfly
Old Feb 20, 2010, 11:07 AM
heli addict
Ohio
Joined Nov 2003
Thanks. I tried it this morning and found that out.
Old Feb 20, 2010, 11:13 AM
modfly is offline
modfly's Avatar
Joined Dec 2006
Yes, the dual aileron servos is a first on the 4-Site. The UM P-51 and UM Sukhoi both have single servo ailerons.
Old Feb 20, 2010, 12:04 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
Hey Mod-
I just happened to remember that John Glezellis talks about flaperon mixes he's playing with in his new F3P plane (a J2M Raiden), in an article in January Model Aviation.
I don't know if it's mentioned there, but here's a thread:
http://www.rcgroups.com/forums/showthread.php?t=1163467
Bud, admits-when-he's-wrong Bud
Old Feb 20, 2010, 12:21 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Hey Mod-
I did not see any mention of flapperons in that thread. Dual 2ch ailerons do open up more wing tuning options for sure. I think we will be seeing more on this topic in general thanks to the 4-Site.
Old Feb 20, 2010, 12:30 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Modfly, I really like your work on the application of this function on the sukhoi. I currently have nearly 150 flights on my (2) 4 sites and am not sure if the flap function is going to be stable on this plane. Proper modulation of throttle/elevator yields a nice nose high attitude and crawl speed. (harrier)
However, I am currently using a version of this function on my reactor bipe, activating by switch, a proportional flap/elevator mix..(full up elevator yeilds full down flap, and the reverse).. This doesnt really help in normal flight but REALLY comes alive with full throttle/deflection blips, making the plane loop inside or outside in place. If the 4 site has enough power and that function can be summoned, it would be interesting, as the stock plane's loops are kinda wide IMO.. (it doesnt have the throws I'm used to on elevator)
Advice.. It is hard to judge the true characteristics of the 4site in ANY wind. I AVOID flying outside for this reason. Bring her inside and you WILL be tickled! Also, Ive found because of the ultra-sensitive nature of the rudder and the constant need for its use that a fair amount of EXPO helps.
Keep up the good work! M
MikeRx is offline Find More Posts by MikeRx
modfly is offline
modfly's Avatar
Joined Dec 2006
CG setting
I also was just thinking about CG on the 4-Site and how it affects flight. Last night I could tell by the way the plane was flying that the CG is AFT. I'm not really a 3D flyer although I have a few 3D plans. I'm thinking now that moving the CG forward a bit may make the 4-Site a little more easier to fly (outside) but at the cost of some of the 3D capability. The way this plane flys reminds me of the GWS TM-350-3D. It was also hard to manage with the stock CG. After I moved the CG forward on the TM-350, the plane flew much better but then again, it may not be better from a 3D perspective.
I am going to work with the CG next as I do most of my flying outside or in the yard. This plane is very sensitive to wind and thats one drawback of a 3D plane. So it looks like I will be modding this plane for outdoor flight.
Old Feb 20, 2010, 12:42 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Originally Posted by MikeRx View Post
Modfly, I really like your work on the application of this function on the sukhoi. Keep up the good work! M
My main mod to the Sukhoi was the addition of a BL geared innrunner. I did not mod the ailerons on the Sukhoi. Reme is the one who added an extra aileron servo to his UM Sukhoi.
Old Feb 20, 2010, 12:45 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
oops thats right...
Old Feb 20, 2010, 02:54 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Minor Repairs
Well, I did a close inspection of my UM 4-Site and found some minor damage. Easy fix with white glue.
Old Mar 08, 2010, 01:41 AM
mrtea is offline
Find More Posts by mrtea
Joined Sep 2006
Flaperon Programming
Need help in programming my DX7 with AR6400L for 4-site plane. Unable to program the Flaperons function per Manual and this link http://www.rcgroups.com/forums/showp...73&postcount=7. Any help??
mrtea is offline Find More Posts by mrtea
Old Mar 08, 2010, 02:39 AM
mrtea is offline
Joined Sep 2006
I find out the hard way for the Stick Programming of the Receiver. I try many times and not work. I finally realize that you need to set the Aileron and Elevator travel rate to 100% with no D/R. If not when you move the AILE/ELEV stick all the way to the bottom left max it will not reach the max value and the programming on the Receiver will not work. Though you all might want to know.. I will try to fly sometimes this week to see how it fly since I just got it and never flown it yet.
Discussion How to install flaps on the PZ BF-109G Messerschmitt earthling1984 Electric Warbirds 4 Jan 10, 2010 09:01 PM
Discussion how to add rudder to vapor brick chem teacher2 Scratchbuilt Indoor and Micro Models 2 Jan 08, 2010 10:55 PM
Discussion Slopes & Fields, Add your club field to the site UgLyPuNk Other Websites 1 Oct 07, 2009 10:26 PM
Discussion 4 Wing Crow, how to program flaps to a slider on the 9C Howemd Radios 1 Jun 15, 2008 10:49 AM
How to have Flaperons (flaps + ailerons) with a 4 channel receiver Flying Cat High Performance 8 Jul 03, 2002 12:42 AM
