You have edited most of your posts in that thread, but some are still there in quotes. At that time you seemed not to have a clue how to solve his problem. Now today you start a thread on almost the same topic. And now you deny even looking at the thread or the posts ![]() But whatever, you have done a lot of work on these micros and posted a lot of good tips. I will just end by saying that in general it is polite to acknowledge where your ideas came from, or at the very least not get nasty when you get a polite reminder. (And you sort of need two people because it is hard to hold the transmitter, the sticks and the plane and plug in the battery with only two hands.) Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
And you editing a post an hour after I respond does not make my response "null and void". Just like in the other thread you can't turn back time and undo things you say. As far as going to PM, why would I do that? Zero to be gained there I am sure. Nothing more needs to be said on either side. Have fun ![]() Pat |
Flaps and Flapperons, control surfaces arch downward as does the elevator control surface if mixing is used. Spoilerons, control surfaces arch upward and can be used with a "up elevator" mix. Spoilerons are completely different than flapperons The upward arch of the Spoilerons and elevator if mixing is used keep the root wing from stalling first and thus prevents "Tip Stall". However, any plane will stall no matter what if the speed gets too slow. I do not use Spoilerons for "spot landing" as they do in gliders but rather like flaps with the nose pitched up. This works well on Warbirds and planes with half wing length ailerons but it a little different than the traditional glider use of Spoilerons. |
I guess I don't think in terms of which way the control surfaces move with respect to one another when flaps or spoilerons are deployed....The video I posted shows flaps with a elevator mix. Yes its true that both control surfaces move in the same direction with respect to one another but I think its better to give a technical explanation that leaves no doubt as to what is going on and here it is.. When flaps (flapperons in this case) are deployed, a down elevator control surface movement also occurs due to mixing. This keeps the nose level. Otherwise the plane will pitch nose up when Flaps are deployed. Here is the Flapperon video with elevator mixing once again..
you mean like you move the aileron stick left both ailerons go up if you go right they both go down? or otherway around? Ugh.... what did you do ? maybe you have the programing in the radio reversed? on that other channel? i do not own a dx6i so guessing. |
These instructions apply to the Dx6i only. |
United States, IN, Indianapolis
Joined Nov 2008
did you get it figgured out yet bud? if not, i think you need to go into the reversing menu on tx and reverse ailerons. my plane did the same thing until i reversed the aileron setting i think. i'm at work and don't have it here, i will check tonite when i get home if you don't get it figured out.
I'm gonna reset mine to default and redo it and this time I will write down every step. Please be patient. |
| Thread Tools | |
| Discussion How to install flaps on the PZ BF-109G Messerschmitt | earthling1984 | Electric Warbirds | 4 | Jan 10, 2010 09:01 PM |
| Discussion how to add rudder to vapor brick | chem teacher2 | Indoor and Micro Models | 2 | Jan 08, 2010 10:55 PM |
| Discussion Slopes & Fields, Add your club field to the site | UgLyPuNk | Other Websites | 1 | Oct 07, 2009 10:26 PM |
| Discussion 4 Wing Crow, how to program flaps to a slider on the 9C | Howemd | Radios | 1 | Jun 15, 2008 10:49 AM |
| How to have Flaperons (flaps + ailerons) with a 4 channel receiver | Flying Cat | High Performance | 8 | Jul 03, 2002 12:42 AM |
