Old Feb 04, 2011, 07:48 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by rcplaneflierguy View Post
Ok I fallowed the instructions and it still doesn't work. When I flip the flap switch the ailerons go in different directions. If I reverce the aileron it flips the controls, and if I reverce the aux1/flap it does nothing!
You got the Aux/flap turned on?
livonia bob is offline Find More Posts by livonia bob
Old Feb 04, 2011, 03:13 PM
rcplaneflierguy is offline
Find More Posts by rcplaneflierguy
rcplaneflierguy
rcplaneflierguy's Avatar
USA
Joined Feb 2011
i got it, for some reason mode 2 was turned off? I re-programmed it and now they work pefect. thanks guy
rcplaneflierguy is offline Find More Posts by rcplaneflierguy
Old Feb 19, 2011, 04:31 PM
jacktheman is offline
Find More Posts by jacktheman
Ontario, canada
Joined Feb 2011
New UM4Site owner
First verify that the ailerons work properly. Next toggle the aileron mode to 2ch ailerons.
How do I do this step ?
jacktheman is offline Find More Posts by jacktheman
Old Feb 19, 2011, 04:55 PM
delaner is offline
Find More Posts by delaner
USA, CA, Redondo Beach
Joined Nov 2010
You have to "reprogram" the mode of the receiver. This involves turning the receiver and transmitter on and off with your control sticks in specific locations. You should probably download your receivers manual on-line to verify the instructions specifically for your receiver and transmitter. =)
It's actually not that hard - just takes a second. Just read the directions carefully!
delaner is offline Find More Posts by delaner
Old Feb 19, 2011, 06:17 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
AR6400 bible
http://www.astramodel.cz/manualy/spe...R6400L_man.pdf
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Dec 27, 2013, 10:24 AM
ripcurl777 is offline
Find More Posts by ripcurl777
Joined Feb 2013
i did a video about this Setup. but especially for the fact that this is not working with AS3X Systems, Caus when you switch your 2nd Aileron to channel 6, AS3X is only working on the Aileron on Channel 2 so no AS3X on Channel 6 wich can cause a crash!!
How to "add" Flaperons to Ultra Micro Planes like sBach 342 and Mosquito (4 min 59 sec)
ripcurl777 is offline Find More Posts by ripcurl777
Discussion How to install flaps on the PZ BF-109G Messerschmitt earthling1984 Electric Warbirds 4 Jan 10, 2010 09:01 PM
Discussion how to add rudder to vapor brick chem teacher2 Scratchbuilt Indoor and Micro Models 2 Jan 08, 2010 10:55 PM
Discussion Slopes & Fields, Add your club field to the site UgLyPuNk Other Websites 1 Oct 07, 2009 10:26 PM
Discussion 4 Wing Crow, how to program flaps to a slider on the 9C Howemd Radios 1 Jun 15, 2008 10:49 AM
How to have Flaperons (flaps + ailerons) with a 4 channel receiver Flying Cat High Performance 8 Jul 03, 2002 12:42 AM
