Old Feb 15, 2010, 05:24 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Making an adapter to charge e-cig batteries from my Duo2
Heya, Id like to build an adapter to charge my e-cig batteries from my hyperion 610i duo 2, Im wanting to charge between 1 and 3 1S batteries at once at 1C+ rates, not unlike an adapter to charge multiple 1S micro lipos
The stock wallwart charger says its 4.7V at 370ma output, but it takes 4-5 hours to charge one battery, so it cant be a constant 370ma.
Each battery is somewhere around 370mah 4.7V LiIon, and has a screw in style plug. Ill pull apart the cartridges to get female plugs to use, but am not entirely sure how I need to wire it up.
Anyone cleverer than me wanna draw a simple wiring diagram for me?
jackosmeister is online now Find More Posts by jackosmeister
Old Feb 15, 2010, 07:38 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
That would be parallel charging. If you look at a 1S 1P here:
http://scriptasylum.com/rc_speed/_lipo.html
You would have several of those. And you want to connect all of the red battery connectors together and also connect all of the black battery connectors together. That will put all the cells in parallel.
Then connect the charger's output leads to the batteries and it will charge all the packs at the same time. All packs will be charged to the same voltage and it is best if they are all of the same size and at about the same state of discharge.
Set the charging rate to be the sum total of the capacity of all of the packs connected. If you are charging three 100 mAh packs, a 300 mAh rate would be a 1C charge.
Here is a good thread on parallel charging here if you want more info:
http://www.rcgroups.com/forums/showthread.php?t=932319
To make your own adapter for parallel charging you want something like this:
http://www.rctoys.com/rc-toys-and-pa...RS-WIRING.html
That would charge two batteries with Dean's Ultra connectors, you would need one with your connectors and for as many batteries as you want to charge simultaneously.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 15, 2010, 08:44 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
I don't think too many of us have experience with e-cigarette batteries...if that is indeed what you are talking about.
Could you post a picture of the battery?
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Feb 15, 2010, 09:00 AM
Jack
USA, ME, Ellsworth
Joined May 2008
http://en.wikipedia.org/wiki/Electro...nd_electronics
Smoking is stupid. I know because I used to smoke. But it appears that smokers are pretty much too stupid to be interested in the details of their batteries too.
All I can tell is that it is a Li-Ion battery with a screw on connector, there must be two contacts or at least another point of contact at the threaded end of the battery.
Might the batteries be good for indoor micros?
Jack
Old Feb 15, 2010, 02:23 PM
Auckland NZ
Joined Aug 2007
Awesome thanks!, for some reason I was thinking I need to hook em up in series, and the balance connection was confusing me, it was 1am Parallel makes it much easier.
jackerbes, yes it is stupid, but thats not what I asked, and no im not stupid but thanks for your opinion! Batteries arent really suitable for micros, they are pretty heavy.
Hughes 500 bob - pics. The threaded section is insulated from the centre of it, easy enough to make something up.
Old Feb 15, 2010, 02:25 PM
Southeast PA
Joined Jun 2007
Yeah ... Indoor electric micros with a smoke trail. LOL
I applaud you for making the effort to quit .... what ever it takes!!
Bob
Old Feb 15, 2010, 02:57 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Boy, pretty loose with the stupid label, aren't you?
Bill
ebill3 is offline Find More Posts by ebill3
Old Feb 15, 2010, 05:30 PM
Jack
USA, ME, Ellsworth
Joined May 2008
"..and no im not stupid but thanks for your opinion!..."
My apologies for that, that certainly read different than I intended. I was trying to comment on the paucity of info about the batteries I could find on the net.
Bill,
That was a mistake, I've fixed it.
Jack
Question 18650 Batteries - can I charge them with say my Cellpro 4s? deswong Batteries and Chargers 3 Sep 17, 2009 09:29 PM
Help! Need Help Making An Adapter hcsk8ter Batteries and Chargers 5 Mar 31, 2009 12:46 AM
Discussion Where can I get an adapter to charge my Apex battery with a DN charger? grampi Batteries and Chargers 1 Mar 30, 2007 03:39 PM
Is it safe to charge from a car cig lighter? Jim_W Batteries and Chargers 7 May 08, 2005 11:12 AM
Know any cheap ways to charge Preserver from cig lighter? ecpreston Batteries and Chargers 1 Feb 09, 2005 01:26 PM
