This thread is privately moderated by The_Mongrel, who may elect to delete unwanted replies.
Old Feb 14, 2010, 05:45 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
The Tricopter is born, and the Tricopter dies.
I thought I would post a blog entry - it has been a while.
I recently built a Tricopter with great success. It turned out to be a little ripper. Below are some videos of it, along with some FPV videos. Keep reading under those to hear of her demise...
This video was the first real main flight. I had already maidened it, but now I had dialled it in.
More Tricopter (2 min 18 sec)
This is just one of the many FPV flights I made on this bird.
More Tricopter FPV (3 min 24 sec)
SO... What happened to it you ask? Well it crashed, and it crashed because I bought a faulty RX off eBay!!!
You can read about it and see the pictures here...
http://www.mongrelgear.com.au/the-mo...of-a-tricopter
Cheers
The Mongrel
The_Mongrel is offline Find More Posts by The_Mongrel
Old Feb 14, 2010, 08:21 PM
rdbell is offline
Find More Posts by rdbell
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Man that is awesome! I might like to build something like that... I don't know where to start though...
rdbell is offline Find More Posts by rdbell
Old Feb 14, 2010, 08:35 PM
Joined Dec 2007
Well funny you say that!!
I am putting together an ARF kit that will probably retail around $200 USD. All you will need is to put it together and stick you RX on it.
Probably a few weeks away.
They really are great to fly.
Cheers
-J
Old Feb 14, 2010, 08:50 PM
rdbell is offline
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Well well well.. :P I was just in the tri/quad forum looking around but I started getting a headache.. Lol I was a little overwhelmed! Let me know how that ARF goes...
By the way, whats the pros/cons with tri or quad?
Old Feb 14, 2010, 09:47 PM
Joined Dec 2007
Well a Quad needs a processor board on the copter to do all of the mixing to the four motors, whereas a Tricopter does not. It uses a standard 120 degree swash setting like any normal Heli using 3 gyros for the motors and 1 for the YAW.
So no need for anything special other than a computer radio capable of 120 Heli programming.
Cheers
-J
Old Feb 14, 2010, 09:49 PM
rdbell is offline
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Hmmm... That does make a huge difference lol. Would a DX6i work for a tricopter?
Old Feb 14, 2010, 09:54 PM
Joined Dec 2007
Yep!! no problem
This from the following spektrum site.
Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal, and CCPM 120)
http://www.spektrumrc.com/Products/D...ProdID=SPM6600
Cheers
-J
Old Feb 14, 2010, 10:00 PM
rdbell is offline
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Awesome! I think a tricopter might be my next project...
Old Feb 14, 2010, 10:11 PM
rdbell is offline
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
What equipment are you using in your ARF?
Old Feb 14, 2010, 10:59 PM
Joined Dec 2007
The list of parts reads a bit like this...
Ply Main Frame
Timber Arms (I like Carbon, and can be used at customers choice)
3 X 750 KV motors
3 X Gyros
3 X ESC
1 Gyro to Tail (Yaw is controlled by tilt)
1 X Tilt Assembly for rear Motor
1 X BEC
Bit and pieces... cable ties, screws and bolts etc.
Old Feb 15, 2010, 12:56 PM
rdbell is offline
rdbell's Avatar
USA, TN, Nashville
Joined Oct 2009
Okay... So is it basically this tricopter here? I'm very interested in a kit from you... I think it'd be a lot easier than just trying to wing it by myself.
http://www.rcgroups.com/forums/showthread.php?t=1142429
Old Feb 15, 2010, 06:02 PM
Joined Dec 2007
Yes - Very similar to that one.
I should have some specs in a few days and will let you know the details
Cheers
-J
Data 3mm EPP Mini Yak has been Born tallflyer Foamies (Scratchbuilt) 37 Jan 25, 2010 02:00 PM
Discussion Confessions of a Born Again Slimer u2builder Electric Plane Talk 117 Sep 12, 2009 05:41 AM
Discussion A micro F117 is born customminatures Scratchbuilt Indoor and Micro Models 2 Aug 31, 2009 09:41 AM
