This one has removable polyhedral balsa wings with blunt tips and does not have the fine pointed tip the original has. I found this one on the Hobby Lobby site, close appearance but foam and not quite right. I tried to browse through the NE Sailplanes site but the photos were not loading for some reason. The only Discus on their site certainly is not right. |
I took the elevator apart. With a bit of judicious bending and smoothing of the aluminum rocker that holds the elevator I managed to free it up and it's working OK now. Not a lot of movement but I assume since it's the whole surface moving I don't need much. Getting that pivot screw tuned right is critical as you suggested.
Have done a lot of (Google) searching with various combination of Discus +RC +sailplane +Asia +China. Looked at a lot of Discus sailplanes but most are larger and none are this particular model. Wingspan on this is about 5 feet. |
Got it out for a maiden yesterday-just a few simple tosses. Flies/floats pretty good. Does not like a sharp turn-stalls and goes right on the wing tip. Spent some time with the iron putting in some washout. One wing was level and the other had a tad of wash in. Hopefully this will improve.
Continue to search for ID without success. Anyone? |
That is as close as I've gotten:
Mini Discus Looks about right but is foam. Babel Fish won't translate Czech so I went through the categories as best I could. One other balsa plane looked similar but was larger and had ailerons. |
| Thread Tools | |
| Wanted Kits! What do you have? For OS.25 | samolot | Aircraft - Fuel - Airplanes (FS/W) | 9 | Feb 12, 2010 04:53 PM |
| Discussion What size motor do I have? | longeze | NeuMotors | 1 | Jan 28, 2010 05:56 PM |
| Discussion What to do with all the heavy balsa I have | cougdave | The Builders Workshop | 10 | Jan 19, 2010 10:23 PM |
| Discussion MSR mix problems...what do I have wrong? | boss99er | Micro Helis | 2 | Jan 11, 2010 11:01 PM |
| Discussion What's it worth? What do I have? Should I keep or sell? Vintage 80s Kyosho/Tamiya | dan50 | Off-road Cars | 18 | Dec 30, 2009 04:24 PM |
