Old Feb 09, 2011, 11:07 PM
RCSCALEGUY is offline
Find More Posts by RCSCALEGUY
United States, CA, Chino Hills
Joined Mar 2007
Motor, Motors???
Hey I know someone that could put that in a dynamax or a ramtec. Well not my business but if someone has one of those motors I know someone who would buy it
RCSCALEGUY is offline Find More Posts by RCSCALEGUY
Old Feb 09, 2011, 11:20 PM
flyboy1945 is offline
Find More Posts by flyboy1945
Were's the plane?
flyboy1945's Avatar
Warren,Ohio
Joined Feb 2005
Originally Posted by BILLYDSRC View Post
I put Her on the scale today She came in at a "Final Weight Of" 18lb No BATTS.. Not bad for having brakes and heavy wheels and tires,the XPS Pro Motor, ICE160 and two 1100mha A123 RX packs.. O Ya I love Hysol too
Lets see how long I can get away with it there?? We don't use that room a lot. So will see I bet 3 weeks
Bill hang your coat on it she will never know.
flyboy1945 is offline Find More Posts by flyboy1945
Old Feb 09, 2011, 11:30 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hey Jeff call me are you flying Friday? I'm still hot for a big Sea Fury Let's talk
rvincent is offline Find More Posts by rvincent
Old Feb 09, 2011, 11:59 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
yeah, thats probably most of it. never really ran that smooth before the crash though....but was pretty bad after the fix.
not sure.
Originally Posted by rvincent View Post
Well yeah after it crashed and burned where is it now?
corsair nut is online now Find More Posts by corsair nut
Old Feb 10, 2011, 12:06 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i still have it some of it was the rotor too ...so that got R&R'd too
AIR SALLY is online now Find More Posts by AIR SALLY
Old Feb 10, 2011, 12:44 AM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
Max, thanks for the info in post 1323 cheers
yakhakker is offline Find More Posts by yakhakker
Old Feb 10, 2011, 08:39 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
If you can do away with the flaps, brakes, and a couple servos.....and go 10s the plane is light and a joy to fly.......
Madmax1965 is offline Find More Posts by Madmax1965
Old Feb 10, 2011, 08:51 AM
yakhakker's Avatar
Joined Feb 2009
Max, yes I plan to keep this one as light as possible I will have a good look at it when I collect it and see what can be done from my view and report back, Cheers
Old Feb 10, 2011, 09:02 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Mine looks like it will end up at around 7kg (15.5lbs) ready to go, this with 12S 5000's feeding a 4" Haoye/Turbax/Turnigy fan combo. I also have 2 flaps, 2rudder and 2 elevator servos, and E-Flite electric retracts, I think they save me some weight compared to air units. I'm using the stock foam wheels and do not have brakes or fancy struts, only the wires included with the E-Flites.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Feb 10, 2011, 02:10 PM
yakhakker's Avatar
Joined Feb 2009
Arngneir, that figure is quite impressive,apart from what you have mentioned did you do any hacking to to get that low?
Old Feb 10, 2011, 05:36 PM
Senior Member
Molde, Norway
Joined Jan 2001
Not done anything special to remove weight, but keep in mind my fan/nacelle is much lighter than what most are using, mine weighs in at 700 gram (1.5lbs), that's where I save most of the weight compared to those running a Dynamax or similar fan setup.
Old Feb 10, 2011, 07:30 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
im making the Nacelles with lighter cloth now the last 2 nacelles were 7.6 oz. not including the hardware. and no paint ...i think my fan motor is around 3 ish pounds.
Old Feb 13, 2011, 06:19 PM
yakhakker's Avatar
Joined Feb 2009
Arngeir,what system are you running please?
Old Feb 13, 2011, 07:18 PM
Senior Member
Molde, Norway
Joined Jan 2001
4" Haoye shroud in homemade balsa nacelle, with cut-down Turbax rotor and spinner, currently with a Century 650A 800kV motor on 12S 40C 5000 Zippy, Sentilon 100HV controller. Waiting to get a Turnigy T600 880kV motor and will do a swap when I get it, the current setup is a little low on power. I'm getting 9.5lbs of thrust on just 2800W, I'm hoping the higher kV motor will up those figures a bit.
Put the plane on the scales today, RTF it is 6.8kg (15lbs)
Old Feb 14, 2011, 10:11 AM
yakhakker's Avatar
Joined Feb 2009
Interesting stuff,thanks for the info do you plan to keep the shroud at 4in with the new motor or will you up grade to a 4.5inch or bigger? cheers
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
