Old Mar 01, 2010, 01:34 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Yeah he has it all. My fan and motor are the ones you have been using to test fit. That's a 890Kv motor that I will change out cause that one will go to CN to test in the Turbax after I mod the front flange to fit the Turbax.
rvincent is online now Find More Posts by rvincent
Old Mar 01, 2010, 01:35 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
what about the smaller motor for the turbax?
corsair nut is online now Find More Posts by corsair nut
Old Mar 02, 2010, 06:26 PM
sparkola is offline
Find More Posts by sparkola
Sugar Grove, IL
Joined Sep 2006
Is the Dynamax and the Dyn-e-max the same thing?
sparkola is offline Find More Posts by sparkola
Old Mar 02, 2010, 07:19 PM
wocketman is offline
Find More Posts by wocketman
Lawrence, KS
Joined Apr 2003
No, The Dyn-e-max is the electric conversion of the glow Dynamax fan made by Jet Model Products in Belton, MO
wocketman is offline Find More Posts by wocketman
Old Mar 02, 2010, 07:22 PM
rvincent's Avatar
Joined Jul 2004
The same fan yes, but thats the only thing Different motors
Old Mar 02, 2010, 07:41 PM
rvincent's Avatar
Joined Jul 2004
The Dyn-E-max uses either a Neu motor or a Scorpion motor. The XPS system uses the same fan but a Littlescreamer motor. The Dyn-E-max is rated to 4500 watts and ours is rated to 10,000 watts. They both work about the same on 12S with us being about 1800 more rpm's on those 12 cells, but you can run ours up to 16 cells and 10,000 watts with over 25lbs of thrust. Both set ups will deliver around 15lbs of thrust on 12 cells and 4500 watts. Hope that helps
Old Mar 02, 2010, 08:19 PM
scalejetguy is offline
Find More Posts by scalejetguy
United States, CO, Parker
Joined Feb 2010
Falcon 120 wing stress
Hi fella's, are you beefing the wings/Fuse to handle the stress on 15 lb thrust or is it OK as is, thanks.
scalejetguy is offline Find More Posts by scalejetguy
Old Mar 02, 2010, 08:34 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
...the only guy that has a lot of EDF flying these is "Racer1"
and " Knife liddle" i would say it's ok as long as you dont honk on the elev too much .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Mar 02, 2010, 08:39 PM
rvincent's Avatar
Joined Jul 2004
Are you gonna 3D it If you fly it like a Jet it will be fine. This wing is really thick so it won't be fast anyway. Just don't yank and bank it real hard it will be good to go.
Old Mar 02, 2010, 09:43 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
To strengthen the Falcon. I suggest reinforcing the landing gear blocks, front and rear. Everthing thing else seems to be fine.
I have discovered the rear deck can be weak, It may not be on all of them.
See this link.
http://www.rcgroups.com/forums/showthread.php?t=1186501
I have a orange and black Falcon that does not have this modification with plenty of flights, but I will perform this modification on all of my new ones.
It is smooth as glass in the air. You fly it like a jet, it is all about energy management. Flaps are a must when landing. I drop them then fly with power to the ground.
Clay
racer1 is offline Find More Posts by racer1
Old Mar 03, 2010, 12:15 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I now belong to the Falcon club - needed one to determine how to make mounting tabs for the nacelle.
JimDrew is offline Find More Posts by JimDrew
Old Mar 03, 2010, 12:45 AM
rvincent's Avatar
Joined Jul 2004
Nice Jim. What colors did you get? Mines the Black and orange one.
Old Mar 03, 2010, 02:46 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Jim racer one made me a set that look like they will work ...i just dont have time right now to make a mold for c/f mounting ..to busy making Nacelle
Old Mar 03, 2010, 07:57 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Welcome Jim to the Falcon club.............let us know when the mount is ready for sale....I need one as well as your motor/fan to fit the nacelle I purchased from XPS.
This is a really fun plane to fly and I am using twin Arc 36-75-1 on my plane. Little too heavy in my opinion so I am switching over to a single fan. You will surely need flaps on landing unless you have a very long runway.
I am thinking of doing my Falcon in some Russian dress since I am changing up the fan. Think I will do something like this....just for fun. The falcon is one of those planes which will fly for a long time as they are easy to fly so a little dressup would be nice......plus I can better take a look at the glued areas in the wings once the present covering is off.
Madmax1965 is offline Find More Posts by Madmax1965
Old Mar 03, 2010, 09:15 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
I don't know if we will make the mounting plates, I was just after making a template available to our customers so they could make their own.
I have no idea what color the Falcon I am getting is!!
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
