Old Feb 19, 2010, 09:42 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
Originally Posted by AIR SALLY View Post
John great idea ...im might try something like that ..also but an external doubler on the side of the fuse back there by the motor mount. Racer 1 has seen cracks back there .when i get home from Hawai'i i'll post pics .
You mean like these.
I have it fixed. It is much stronger than before.
Clay
racer1 is offline Find More Posts by racer1
Old Feb 20, 2010, 08:01 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Clay can you explain how you fixed the Falcon motor mount plate? I haven't seen any problem in mine yet but I would rather fix it before rather than afterward.
Madmax1965 is offline Find More Posts by Madmax1965
Old Feb 21, 2010, 10:30 AM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
I used hollow 1/4 carbon fiber rod. I drilled a 3/8 hole thru the rear of the mount into the last two formers. Insert the rods (let them stick out past the end and cut them off later)
Then I mixed up cabosil and resin, till it was like icing. I put that into a pastery bag and put it everwhere on the rods (sanded the rods, inside of fuse and cleaned with acetone). I used a acid brush on a stick to make sure that it was all around the rods in the back.
Since this one was broken. I put a layer glass on joints on the out side.
Hope this helps.
Clay
Old Feb 21, 2010, 12:08 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
O.K. got it...........I think I will carbon rod my Falcon beofre any trouble. I still have the twin Arcs on mine and there is lots of pressure put on that area.
Old Feb 21, 2010, 02:40 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
guys you would be smart to do as Clay has said ....we are using this plane for a little diff. purpose than it was designed .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 21, 2010, 03:44 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
In my small 90mm one I just surfboarded the motor deck. since the glass is already there for encasement, I just filled it with expanding foam. Now its bulletproof.
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 22, 2010, 08:04 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Maybe a combination of foam and carbonfibre rods with the rods incased in foam....should work. The fiberglass would have support to keep it from cracking and finally coming loose.
Old Feb 25, 2010, 11:33 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
pj
how goes the nacelle mounting ?
Old Feb 27, 2010, 03:30 PM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
Finished up last night and hope to maiden tomorrow if the weather permits. Don't know yet if it will fit in the truck in one piece! Managed to hide the wiring under the nacalle through the angled fillets. I just have to add a few more screws to the 3,6,9 o'clock positions for more strength, but even with only four installed the plane can be picked up and manhandled by the nacalle. COOL.
PlumberJohn is offline Find More Posts by PlumberJohn
Old Feb 27, 2010, 04:47 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
That looks really good John...........I will take one.
Just ordered my nacelle from XPS today....they don't have the motors and fans from what I can glean from the XPS site....figured I better go ahead and purchase the nacelle while they are in stock. Cost around $150.00 with shipping.
Old Feb 27, 2010, 05:07 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks great john ..tsunami watching right now it Oahu. really weird to see that much water moving out and inhope we can get home tomorrow.
Old Feb 27, 2010, 05:11 PM
John Green
Joined Dec 2007
I'm working my way up. This one has an old Dynamax KB82 fan I cut down and uses a Scorpiom 560kv. I have a 630kv I can put in to try next. Trying to do all this as much as possible from parts on hand. The nacalle looks natural in this install--- and it's cheap!!
Old Mar 01, 2010, 11:59 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
OK im home safe and sound from Hawaii ....got to lax and had a dead Batt in the car...go figure ..Thanks to an ELKS club member for giving me a jump at 10:00pm in lot "C". so i need to get hot on this Falcon.
Old Mar 01, 2010, 12:31 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Welcome home eh! Get crackin!
rvincent is online now Find More Posts by rvincent
Old Mar 01, 2010, 01:16 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i would but no fan or your fuse ? i guess C/N has all the stuff...hey Burt bring all my shill home ie, batts ,retract valve,fan ,Falcon fuse and any thing else you barrowed..sheese i need another week off just to get going again.
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 12:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
