Old Feb 14, 2010, 10:57 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
sweet i got your nacelle you got my fan
AIR SALLY is online now Find More Posts by AIR SALLY
Old Feb 14, 2010, 11:54 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
logging on, looks good on the full Falcon airframe too.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Feb 15, 2010, 11:28 AM
Jim Swanson is offline
Find More Posts by Jim Swanson
Joined Jan 2010
How difficult would it be to put the fan inside the fuselage?
Air intake and thrust tube would be an obvious challenge.
Just a random thought.
jim
Jim Swanson is offline Find More Posts by Jim Swanson
Old Feb 15, 2010, 05:08 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
there is no way to put a 5" fan inside the fuse this plane is set up to have the motor mounted on the mount section at the rear of the plane. stock they are set up for a 120 glow motor and prop.
Old Feb 16, 2010, 08:37 AM
rccrazee is offline
Find More Posts by rccrazee
Airshow Joe
rccrazee's Avatar
N.W. Detroit Suburbs
Joined Feb 2009
I just picked up a DS-94 and need a nacelle for my Falcon!
rccrazee is offline Find More Posts by rccrazee
Old Feb 16, 2010, 10:51 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
What is the O.D. of the shroud? my nacell fits a dynamax ...@127 mm i think. i might be able to make a different piece for the inlet ring mold that would fit ,
Old Feb 16, 2010, 02:14 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
What servos are you guys using in the rear of this plane for elevators and rudders?
rvincent is online now Find More Posts by rvincent
Old Feb 16, 2010, 02:32 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
I am using Futaba S9650 Digital Mini Servo with two ball bearings for the elevator servos...........63 oz-in (4.5 kg/cm) @ 6.0V each.
Madmax1965 is offline Find More Posts by Madmax1965
Old Feb 16, 2010, 02:34 PM
rvincent's Avatar
Joined Jul 2004
What's the torque rating on those Max? And are they Metal gears?
Old Feb 16, 2010, 02:37 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Bob here you go:
http://www3.towerhobbies.com/cgi-bin...?&I=LXDTB4&P=M
I have small Jr MN-48 servos on rudder..........48 oz/in @ 4.8V
Spektrum DS821 on flaps. 72 oz/in @ 4.8v, 88 oz/in @6v
Tower TS-150 digital metal gear on ailerons......... 193 oz-in @ 6 volts
Old Feb 17, 2010, 03:39 PM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
I decided to try a different tack on the nacalle mount. The outside of the nacalle matches in size a piece of Sch. 40 6" pipe, so I used that as an inside mould for a fiberglass base. So far the plane fully equipped except for power system and batteries is 10.95#. Ailerons, flaps, elevator( 2 servo), Robart retracts with 1/2" struts, brakes etc. The nacalle with fan and motor and mount is 2.90#. Using a Scorpion/ Dynamax conversion probably on 12S XPS 35c batteries and CC HV 110 esc.
PlumberJohn is offline Find More Posts by PlumberJohn
Old Feb 17, 2010, 05:15 PM
rvincent's Avatar
Joined Jul 2004
It looks great John, but I worry that there might not be enough to hold on the plane? These thing really pull And to think it's only on there with a couple of screws in the center would make me worry about torsional stress in flight?
Old Feb 17, 2010, 09:09 PM
John Green
Joined Dec 2007
I plan on bolting it down through the engine mount block from the underside. I plan on filling the wedge space below the cylinder of the nacelle with a nice fillet, so it will have about 12sq. in of bearing area to bolt through. I plan on running a tube or two through the fillet to thread the motor wires from the ESC in the fuse back to the motor to keep them mostly hidden. The fiberglass mount so far would hold up to a 120 two stroke being bolted to it and run, so all together it appears to be a strong mount with a more elegant shape, maybe.
Old Feb 17, 2010, 09:13 PM
rvincent's Avatar
Joined Jul 2004
Nice
Old Feb 19, 2010, 01:17 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
John great idea ...im might try something like that ..also but an external doubler on the side of the fuse back there by the motor mount. Racer 1 has seen cracks back there .when i get home from Hawai'i i'll post pics .
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 12:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
