Old Nov 18, 2012, 04:49 PM
Frankensteen is offline
Find More Posts by Frankensteen
Die Meistertinkerer
Frankensteen's Avatar
United States, GA, Columbus
Joined Jan 2006
Awesome!!! Still enjoying my DynEmax Falcon but this has me salivating!
Frankensteen is offline Find More Posts by Frankensteen
Old Nov 18, 2012, 05:21 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Very cool!
ysolomon is offline Find More Posts by ysolomon
Old Nov 18, 2012, 05:34 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Cool Bri,
sounds fun.... what 8000 mah packs are you running and how are they holding up for you?
I'm looking to grab a set of 6s 25c 8000 mah nano techs to test in my jet legend hawk... don't know if you have the zippy, nano or something else
thanks
Ron101 is offline Find More Posts by Ron101
Old Nov 18, 2012, 06:31 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Ron I have the 25c nanotechs, I know you are not big on them but they are working great, I'm testing them in this setup before I put them in my YA f-15 ARF with the DS-94 HST. They are holding at 3.43 per cell under serious load and late into an aggressive flight.
I'd love to see what numbers you get with these packs on your 1915 Dynamax! I was hesitant on the HET but I like that it is about 1/2 longer than the 1915 and it has sleeved magnets, I don't know enough about Steve' design on the 1915 but I have heard sleeving the magnets helps when you start hitting higher rpms like I'm doing with this setup.
bri6672 is offline Find More Posts by bri6672
Old Nov 18, 2012, 06:34 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
way to go "B" ...be careful on those high speed passesmake sure your covering is staying together
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 18, 2012, 06:52 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Hahah, Roger this thing is crazy powerful now!! There is another Falcon at our field with a 16lb turbine on it and mine now performs every bit as good as that one, this fan is really throwing around the airframe, the controls are even starting to feel a bit touchy
Old Nov 18, 2012, 09:16 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
Right on bud... that sounds pretty darn good. The price it just to hard to beat
I figure if I break them in, and treat them well the should do fine for me....
I wouldn't mine having a falcon to toy with.... but to many projects
thanks for the info... I feel a set coming in my future very soon
Old Nov 18, 2012, 09:31 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Right on Ron! I baby them, 5 break in runs at 50 amps, always store them after a flying day, never leave them fully charged for more than 2-3 hours, never take them below 3.7, these things are what make the cheaper packs last and work.
Yeah I hear you on projects my garage is freaking nuts right now with 4 120 size jets in the build que and I just got a 40% comp arf extra I'm trying to dial in, conflicted on what to bring to the field each weekend is a good problem to have!
Old Nov 18, 2012, 09:41 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah i miss my "falcoon " it has such a nice presents in the air ,and has to be the best flying plane i've ever had ,and it was even pretty easy for me to land,and with 5000+ watts on tap puts on a great show,and the sound of the dynamax in one of my nacelles was really cool .there were a couple for sale in the classifieds
Old Nov 18, 2012, 10:14 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by bri6672 View Post
Ok boys I decided to step it up a notch! For those of you that have read the whole thread you will see I have had my falcon about a year and have been flying it on the scorpion DynEmax on 12s 5800 with AUW of around 18lbs. (Struts, brakes, cockpit kit all the extras). It has always performed great and was dopplered around 135 or so. But it's just gotten boring and thou it flew nice it sort of lumbered for my taste. So today 3 flights with the Tam Dynamax conversion with the HET 800 series 685kv on 12s 8000 mah!
Old setup was about 15.5lbs of thrust installed, 115 amps 5000 watts and 25,000rpms. New setup is 19lbs of thrust installed, 135 amps 6000 watts and 27,500rpms.
The new setup adds about a lb and a half so I'm guessing its around 19.5lbs AUW but I need to weigh it to be sure.
This setup is a monster, vertical is ridiculous! We estimated a downwind pass at around 160mph ( this setup has a 225mph efflux). It is like a different jet with this setup. After 4min flights I was at only 3.85 per cell so plenty of extra flight time to be had! The acceleration is unbelievable it is off the ground in 75 feet and you can tilt it almost straight up and it climbs out fast!
On the bench we get 135-140 degrees on the back of the motor after a simulated flight, after the flights today it was only 106-109 degrees ( thou it was in the upper 60's lower 70's outside)
I am definitely no longer bored with the falcon, it is a monster with this setup and very reasonable cost wise for a quality higher powered setup.
Is that 19lbs installed in the AS nacelle with a thrust tube?
regards
erh7771 is online now Find More Posts by erh7771
Old Nov 18, 2012, 10:15 PM
Joined Nov 2005
There's one on RC for 200 with a cc 120 esc and a big screamer prop version...you prolly could talk him in to selling it or hire a courier to take it to a mail office
Old Nov 18, 2012, 10:28 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
regards
Yes on the test stand with his inlet ring, 135 amps peak settles in at 130 amps and 18.5 lbs of thrust, it churns out 21000 rpms at only 50 amps at half throttle and runs silky smooth.
The sound is much better than my scorpion DynEmax, this one is louder so it's easier to hear when you get her out there a ways. The DynEmax was to quiet in AS's nacelle but she will make some noise in the dirty ducting of my YA f-18 single!
Old Nov 18, 2012, 10:30 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Wait till you see it on 6000 watts !
Time you bite the bullet and get a new one. You know General Hobby will have them on sale this Xmas! Make it happen AS!
Old Nov 18, 2012, 11:54 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I have one NIB.
It's for sale.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 19, 2012, 10:53 AM
Air-Jon is offline
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
I was there for the 6000 watt Falcon rebirth. The difference was pronounced! I don't think I have ever seen Brian so stoked...and he is always a pretty up guy!! i will be putting this combo in my future big jet. Takeoff distance on the Falcon was halfed!
Air-Jon is offline Find More Posts by Air-Jon
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 12:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
