Old Nov 02, 2012, 09:23 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Why don't you post some pictures of your falcon erh.
bri6672 is offline Find More Posts by bri6672
Old Nov 02, 2012, 09:32 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
2 90mm were proven to fly a 43 lbs model. but dont expect to do any loops lol.
this airframe is way more suited for a single 120. though 2 90's would fly it quite well, and lee liddle proved
corsair nut is offline Find More Posts by corsair nut
Old Nov 02, 2012, 11:39 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Originally Posted by erh7771 View Post
http://www.hobbyking.com/hobbyking/s...dProduct=21870
it uses a 8mm shaft turned down to 6mm, get the 8mm shaft from mc master
http://www.hobbyking.com/hobbyking/s...idProduct=9130
Prolly a bigger esc would do but I have been flying this one of over a 3 months now iirc and it hasn't skipped a beat fits perfect inside the back of the plane
Why go to McMaster when HK sells the 8mm shafts?
http://www.hobbyking.com/hobbyking/s...Shaft_Set.html
SteveC68 is offline Find More Posts by SteveC68
Old Nov 02, 2012, 01:25 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Are the wings easily removable on this bird?
ysolomon is offline Find More Posts by ysolomon
Old Nov 02, 2012, 01:38 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Nope
I leave the booms elevator and 1 wing attached, this makes it fairly portable and really easy to assmble and the field. I fabed up a foam core fiberglass block that slides on to the wing tubes and velcros down the other boom.
Some guys take the wings off and leave the booms attached to each wing and install them and the horizontal stab at the field.
Mine is ready to fly in less than 5 min.
Old Nov 02, 2012, 05:02 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i basically did about the same ,i took one wing off with the boom attached,so it was 3 servo wires and air lines and 3 bolts and was ready to fly.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 02, 2012, 06:47 PM
tom bacsanyi is online now
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
Two 90's is equivalent to one 127.
tom bacsanyi is online now Find More Posts by tom bacsanyi
Old Nov 02, 2012, 07:20 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Knife was clocked at 180mph with twin 90s...
a bunch of nasty...is that vid still around?
erh7771 is online now Find More Posts by erh7771
Old Nov 03, 2012, 11:41 AM
WFTV9 is offline
Find More Posts by WFTV9
Joined May 2009
Anyone building the Falcon 120 needs to see the 6 part instructional video on Youtube.
Do a youtube search for - mvivona9.
It is the BEST one out there. Covers every aspect of the build. Sure wish I would have know about this before I built my first one.
Falcon 120 build Segment-1 of 6 (11 min 24 sec)
WFTV9 is offline Find More Posts by WFTV9
Old Nov 03, 2012, 09:44 PM
Joined Nov 2005
I'll do that, had a crazy morning with it,...at a decent sized fly in...lander retract burnt...servo burnt and smoke system wouldn't heat up properly.
Mine has been through a couple of hard touch downs but man does it get up and go when it is pressed to do so...
like this model
Old Nov 03, 2012, 11:11 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
5 flights on mine today at the Big Jolt, love the way the falcon lands, full flaps and throttle all the way to the ground. Time to jump my power system up thou... 800 series HET motor in Tams Dynamax, 18.5lbs of thrust installed, going in within a couple weeks. Going to run 12s 8000 in it, should be around 19.5lb jet with 18.5lbs of thrust.
Old Nov 03, 2012, 11:19 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
oh man i was loving your Falcon today ...they were flawless flights ,brakes worked really good . it is a sweet flyer .....i really missed mine today. great Job "B"
Old Nov 03, 2012, 11:26 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Stingray is much smaller. Here is a shot that shows the size of mine. I have the Tornado which is the same plane, just with composite booms and sheeted wing and tail. I have a k80 with 19lbs of thrust and it flys just awesome. Lands slow and will fly in the 180 range. Big thick wing and draggy arframe limits its speed somewhat. It is a real nice low hassle, worry free, jet.
Originally Posted by jcdfrd View Post
so it is a bit bigger. the stingray is 52in span. I planed on using a TJ90 in the stingray
Tumbler is online now Find More Posts by Tumbler
Old Nov 03, 2012, 11:37 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Thanks buddy, it was great seeing you and Nut today, you guys are always fun to hang with! You really need to do another Falcon..... That jet was made for you
Old Nov 18, 2012, 04:22 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Ok boys I decided to step it up a notch! For those of you that have read the whole thread you will see I have had my falcon about a year and have been flying it on the scorpion DynEmax on 12s 5800 with AUW of around 18lbs. (Struts, brakes, cockpit kit all the extras). It has always performed great and was dopplered around 135 or so. But it's just gotten boring and thou it flew nice it sort of lumbered for my taste. So today 3 flights with the Tam Dynamax conversion with the HET 800 series 685kv on 12s 8000 mah!
Old setup was about 15.5lbs of thrust installed, 115 amps 5000 watts and 25,000rpms. New setup is 19lbs of thrust installed, 135 amps 6000 watts and 27,500rpms.
The new setup adds about a lb and a half so I'm guessing its around 19.5lbs AUW but I need to weigh it to be sure.
This setup is a monster, vertical is ridiculous! We estimated a downwind pass at around 160mph ( this setup has a 225mph efflux). It is like a different jet with this setup. After 4min flights I was at only 3.85 per cell so plenty of extra flight time to be had! The acceleration is unbelievable it is off the ground in 75 feet and you can tilt it almost straight up and it climbs out fast!
On the bench we get 135-140 degrees on the back of the motor after a simulated flight, after the flights today it was only 106-109 degrees ( thou it was in the upper 60's lower 70's outside)
I am definitely no longer bored with the falcon, it is a monster with this setup and very reasonable cost wise for a quality higher powered setup.
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 12:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
