Old Oct 28, 2012, 03:34 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by bri6672 View Post
Totally agree with that, but lets not put another negative factor in the already bad equation!
I've not had one CS 12 fan pop on me in flight...I've had over 200 test and flights on the 90s and 70s and over 50 on the 120...
They've been more reliable with me than more expensive products ...
There are plenty of people with similar experience and plenty of people who've seen thrown blades or popped fans with them preassmbeled by people who REALLY know what they're doing and have been doing such for a really long time...those things happen.
I'm over 130mph WOT on the falcon keeping it light and running this fan on 12s using 3300 mah nano packs... and a 3s for the smoke system
erh7771 is online now Find More Posts by erh7771
Old Oct 28, 2012, 06:30 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
I am still looking for a RTF Falcon 120, I can drive a bit to pick one up. I will be in the Phoenix area next weekend, could even drive a bit more if it's the right one!
Hossinarizona is offline Find More Posts by Hossinarizona
Old Nov 01, 2012, 08:27 AM
Fidelity101 is offline
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
There is a guy on rcuniverse selling his with an out runner engine pushing a prop. I think he was selling in on rcgroups a while ago. Anyway, looks like a nice plane and he is in CA.
Fidelity101 is offline Find More Posts by Fidelity101
Old Nov 01, 2012, 12:19 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
erh, we meet again... save me from reading 200 pages of this thread--what power setup do you have here? Do you enjoy this plane?
ysolomon is offline Find More Posts by ysolomon
Old Nov 01, 2012, 12:38 PM
Joined Nov 2005
I enjoy the heck out of it
I have a CS 12 blade 120mm fan and a 70amp HV hobbywing controller (which are spec gimped btw, those things handle some nice amps) on 12s around 90 amps WOT...
Even with almost 2lbs of smoke system and oil I can easily do loops etc..AUW around 15lbs 8oz...thrust is 14.5
So it crashes for whatever reason...it cost 150.00usd shipped to your house and you can even get the white one from Nitroplanes a couple times a year for that price.
I have the holloween one, I can see it in the air easier..
Bunch of upgrades for it, my flight cost with retracts is 450.00 using the haoye fan which doesn't sound bad either...the 128mm one and a Air Sally intake ring. with the CS fan it's 500 with the HK Scorpion motor (prolly made by same company)
If you REALLY want to make it nasty fly it with the YEP 14s controller and the CS 120mm fan at 18.5lbs of thrust and with 14lbs of AUW weight...using the aforementioned setup..for a whopping 40usd more
One of the best large jets in RC right now...
You'll have to reinforce the retract mounts...they're still using soft wood and wont last you past 50 touch downs or "agressive landings" but that's about all I really did...oh...had to reinforce the front retract area also...mostly cause of my landing style... lol
Old Nov 01, 2012, 02:27 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Do you think that an 8S or 10S (or maybe even 12S) on a 90mm system would carry this plane? Maybe a 3,000-3,500W system?
Old Nov 01, 2012, 04:13 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Please post more info about the motors you are talking about, at least the kv. Also which hobbywing esc?
SteveC68 is offline Find More Posts by SteveC68
Old Nov 01, 2012, 08:01 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
a 12 s 90 might fly it but it would have much punch ,it is a draggy airframe ,but a 120 is fine ,mine weighed 19-20 lbs and flew well on 5000 watts.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 01, 2012, 10:31 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Thanks. I thought you will tell me that two 90mm jet fans were proven to fly a 43 lb plane...
Old Nov 01, 2012, 11:35 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
no problem but you will have to get it down to 12-15lbs auw then your good to go. tam is flying two very large scale edfs on TJ90 11 and 12s setups. the latest one being his YA F86 at 18.5lbs it sports the New TJ90HP 12s 5kw and his TJ A4 at 15.24lb on a TJ90 11s both fly fantastic.
I dont really have a good perspective of how big this jet is but I'm thinkin its about the same size as my ya stingray and so I would agree with you that it might be draggy as a sport jet but compared to say a y/a F86 or the A4? I would think those would be way more draggy. still I will defer to you since you have built and flown one....wow 19lbs rodger thats seems way heavy or this thing is much bigger than I'm thinking lol......I thought erh flew his at 14lbs
jcdfrd is offline Find More Posts by jcdfrd
Old Nov 01, 2012, 11:42 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
it has a 63" wing span ....but it is a thick airfoil.hell i loved the way it flew ,i had every thing on mine struts, brakes, 6800 12s batts and the XPS /dynamax fan in one of my nacelles,cockpit pilot bust ect. it was more like 18-19 lbs ....but i was'nt really counting as it flew soo good.some kits are lighter than others...i had two and there was over a pound diff. between them out of te box.
Old Nov 01, 2012, 11:52 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
so it is a bit bigger. the stingray is 52in span. I planed on using a TJ90 in the stingray
Old Nov 02, 2012, 02:34 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
sting ray is way smaller ,i had some customers looking to put my nacelle on one and it was too big,sent them to Tam for his 90 -100 nacelle.
Old Nov 02, 2012, 02:39 AM
Joined Nov 2005
http://www.hobbyking.com/hobbyking/s...dProduct=21870
it uses a 8mm shaft turned down to 6mm, get the 8mm shaft from mc master
http://www.hobbyking.com/hobbyking/s...idProduct=9130
Prolly a bigger esc would do but I have been flying this one of over a 3 months now iirc and it hasn't skipped a beat fits perfect inside the back of the plane
Old Nov 02, 2012, 09:21 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Mine is about 18lbs with 5800 mah packs and the scorpion DynEmax. I saw Rogers's Falcon at LA jets this year and they performed about the same and were pretty close in weight.
John, not sure if you are coming to Big Jolt but I will have mine there tomorrow. Looking forward to see what you do with he Stingray!
bri6672 is offline Find More Posts by bri6672
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
