Old Sep 19, 2012, 09:50 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Yeah, high blade count fans where not supposed to be all that good for high speed, right?
Right
Ron101 is offline Find More Posts by Ron101
Old Sep 23, 2012, 03:30 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
New Falcon 120
Thougth I would post some photos of my newly completed Falcon 120. This plane replaces my old "stock" Falcon 120 which I lost to a midair in May 2012.
I decided to strip the covering off and I glassed the wings, tail and booms with 1/2oz cloth applied with System 3 Clear coat epoxy. I used PPG epoxy primer and all of the colors on the plane are PPG base coat/clear coat. Plane has my old Dynamax/Scoprion 4035-630 KV motor with CC 160 amps esc. Plane flies on 12s 6000 mah packs. AUW is 15 lbs 4 oz. Fan system puts out 5 kw at 117 amps. Efflux is 203 mph. Tail pipe is 12" long and exhaust diamater is 3.75". Just for fun, I added some wing fences for effect.
Hope you like it.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Sep 23, 2012, 04:49 PM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
Painting My Falcon 120
Hope you like it.
Ed
HI Ed..............Interesting, I'm doing the same right now. I just glassed the wings today. The PPG paint cost more than the Falcon did. I decided to strip mine, because I mounted my new electric retracts, and installed gear doors. I'm actually doing 2 Falcons at the same time. One is EDF, the other is turbine. I'll post some pic's when I get closer to being finished, and a video of the retracts in operation.
Larry E.
LJE4357 is offline Find More Posts by LJE4357
Old Sep 23, 2012, 09:29 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
very nice ED!
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 24, 2012, 12:59 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
That's some first class work Ed! Very Sharp
MCSGUY is offline Find More Posts by MCSGUY
Old Sep 24, 2012, 02:18 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Hope you like it.
Ed
How much time did it take you to paint it like this?
I first thought it was a turbine with a lot of packs in it
Very quailty work...
Regards
erh7771 is offline Find More Posts by erh7771
Old Sep 24, 2012, 04:07 PM
Angel RC Design is offline
Find More Posts by Angel RC Design
Angel RC Design's Avatar
United States, NJ, Weehawken
Joined Apr 2011
Any news on the Velox , I have one, but undesided yet, Remtec BS 650kv or Scr 4035 560 kv.?
Angel RC Design is offline Find More Posts by Angel RC Design
Old Sep 24, 2012, 07:34 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Guys:
Thanks for the kind words. I spent about 16 hours glassing,sanding and priming. The time for the application of the white base coat plus masking and shooting the the colors and the clear coat was about 20 hours of work (this is only the time I worked on the plane and not the time waiting for the paint to dry). I have about 3 hours masking the American Flag and about 20 minutes of painting.
Thanks again for the kind words. It is appreciated.
Ed
Old Sep 24, 2012, 07:43 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Hi Ed,
She looks great.
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 24, 2012, 08:01 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah it's awsome ...the only thing to make it better is if it had one of my nacelles on it JK LOL shamless plug i know.
Old Sep 24, 2012, 08:51 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Man I want to build a new one now!!
Ed, great job man
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Sep 25, 2012, 10:15 AM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
A/S, you ARE shameless . I would buy one if it was in the budget. If you want to "donate" one to the cause, I will put your name on the side of the nacelle (shameless begging ). Everything I used on the plane (cloth, paint and epoxy, etc.) was sutff I had on hand so I did not have to buy anything.
BillyD, build another one. I realize that the plane is only a $200 airframe but it flies so well on EDF and if you strangthen the airframe as others have done, there is no reason it will not last a long time. My thoughts are that I spend some money and time upfront and then I have a relatively inexpensive plane that should last a while.
Ed
Old Sep 26, 2012, 02:22 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
I'm putting the servos in, should be done in a day or so. I just got Rodgers nacelle in for the Stumax option. (Shameless compliment: Truly Exceptional Fit and Finish Rodger)
I'll video the run up and thrust tests on the bench comparing the Stumax and Schubi on 12S. I also hope to be able to get the maiden on video.
Old Sep 26, 2012, 07:57 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Sweet deal Joe cant wait to see all that hard work flying
Old Oct 17, 2012, 04:35 AM
MADISONMaster is offline
Find More Posts by MADISONMaster
MADISONMaster's Avatar
France, Burgandy, Dijon
Joined Jun 2010
falcon 120 MODS ?
Hello!
i receved my falcon 120...
You who are experts , I need advice..
What are all the mods on the falcon 120 (to put a JetCat P-100 RX for me (power reduce)) ?
I have the ROBART Retract Main and Nose and 635 & 639 HDRS -(83mm Main wheel & 63 mm for the nose without break)-BEHOTEC Wheels & Trailing leg, ROBART Large Deluxe VR Air Kit -
The airplane only - weight : without wheels and legs -3.5Kg
thank you
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Today 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
