We also are testing the 685 kv HET 700 series motor in Tams Dynamax conversion (used for 19 series motors) it is looking pretty good at about 140 amps and holding a solid 18 plus lbs of thrust. We are seeing temps in the 130's on the back of the motor which should be ok but only time will tell if it holds up. For Stu's setup I would like to see what motor and amps we are talking about. I trust his fans but not necessarily the motor being used.. |
Joined Jun 2011
this is my falcon w/ Dynamax running at 15s/8Ah
My XPS Dynamax on 15S was around 210A, Jim Drew was telling me it should be much lower as I remember they qouted 150A on 15S, sorry Jim but that's
. I am using 8000mAh (2P 4000mAh) Dropping a cell got me down to 170A and my controller and the motor was much happier then. But there's no point in running this much power in a Falcon, I'd be worried about breaking the thing...Besides what does the plane weigh with all that onboard, it must be a lot? |
Clamp on amp meter is a must. Ideally you want to put the fan on a test stand with an inlet lip and thrust tube and you can fine tune everything before it goes in the aircraft.
On 15s I would upen up the thust tube to 3.5" or maybe more and that might bring the amps down a bit. |
| Thread Tools | |
| Discussion Falcon 120 Motor Mount | racer1 | Electric Ducted Fan Jet Talk | 2 | Feb 01, 2010 11:41 PM |
| Discussion Another Falcon 120 Twin EDF | flyguide7 | Electric Ducted Fan Jet Talk | 2 | Sep 06, 2009 12:08 PM |
| Discussion Falcon 120 EDF Conversion | flyguide7 | Electric Ducted Fan Jet Talk | 6 | Nov 28, 2008 08:04 AM |
| Video Falcon 120 flying wing conversion with a pusher prop | Knife Liddle | Electric Plane Talk | 2 | Nov 11, 2008 09:55 AM |
| Sold Nitroplanes Falcon 120 flying wing conversion | Knife Liddle | Aircraft - Electric - Jets (FS/W) | 0 | Nov 09, 2008 09:09 PM |
