Old Jul 02, 2012, 01:09 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
WOW Roger that is a work of art!!! I can't wait to here that fan in your Nacelle
Originally Posted by AIR SALLY View Post
here you go Joe hope you like it
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Jul 02, 2012, 01:11 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i wish it was mine yeah on 14s this is going to sing
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jul 02, 2012, 01:50 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
What did you use as thrust tube?
It's got sparkles on it...looks nice
tia
erh7771 is offline Find More Posts by erh7771
Old Jul 02, 2012, 02:27 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
That's that west coast sparkly mylar plastic
tia
Old Jul 02, 2012, 02:41 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
black metal fLAKE paint
Old Jul 02, 2012, 10:03 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
I freaking LOVE it! Thank you Rodger. The shade of gray is a stone cold match for the Velox scheme and the metal flake on the thrust tube is a nice touch. You need to come up with an Air Sally decal that I can run on the plane. Just send me a photo and I'll print it out in color and lay it up under a clear adhesive sheet. Thanks again
MCSGUY is offline Find More Posts by MCSGUY
Old Jul 07, 2012, 04:34 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Well Killed my Falcon today ...vaporized it not much left ...had a run-a-way alieron servo or a RX lock out ...again ...i knew i should have swapped the RX out just to be sure..well it was sweet while it lasted ...not sure if i will do another one ,i have some more projects that need work
Old Jul 07, 2012, 04:39 PM
JetCatJimmy is offline
Find More Posts by JetCatJimmy
Phoenix, AZ
Joined Mar 2007
Sorry to hear about the loss! If you're thinking of replacing it, I've got a nearly complete one in the classifieds here if you're interested AS.
Let me know.
JetCatJimmy is offline Find More Posts by JetCatJimmy
Old Jul 07, 2012, 05:41 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Roger so sorry to hear that man!!! Step away for awhile and maybe do another one down the road.
bri6672 is offline Find More Posts by bri6672
Old Jul 07, 2012, 10:09 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
im done for now the loss of fan ,the esc most likely is banged up and 300 bucks worth of batts ...i think i'll stick to 8s 90mm stuff for a while.
Old Jul 08, 2012, 01:58 AM
jefffassbinder is offline
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Sorry to Hear Rodger
Well, I know that bird was a great flying airplane. I hope that you can put the pieces back together and start again. I don't know about your electronics but if they are in good shape then maybe you can get another airframe.
Hope you can get flying again soon. Also if you have some questionable RX's you might want to get some flat foam airplanes and use them as test beds to make sure that your RX's are working as they should. If the do fail it won't hurt as bad and you will have piece of mind knowing your gear is solid.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Jul 10, 2012, 02:53 PM
mnavarro is offline
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
Lost my falcon today. Prop came off during high speed pass, thought I still had prop and enough to land her on the runway when it became clear there was no power, though motor was turning. Hit tree. Everything for the most part is salvageable, though one of the wings suffered damage and the fuselage needs a lot of repair. I'm thinking of just buying another airframe.
I learned a valuable lesson; whenever there's an issue immediately land it, even if downwind. My mistake is I thought I still had some power.
mnavarro is offline Find More Posts by mnavarro
Old Jul 10, 2012, 03:09 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Bummer "M" i feel your pain ...stripped mine out yesterday and not much left ,the fan needs a new rotor and shroud not sure about the motor.....i need to contact xps and see if they have parts to repair it . bad couple of days for the Falcon boys.
Old Jul 10, 2012, 03:22 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Sorry for your loss Rodger, I certainly know how you feel, I lost one of mine to the trees Saturday so it's still fresh.
I got the Schubi back today, that Nacelle is awesome! Thanks for doing such a great job!
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
