Old Jun 20, 2012, 08:32 PM
Frankensteen is offline
Find More Posts by Frankensteen
Die Meistertinkerer
Frankensteen's Avatar
United States, GA, Columbus
Joined Jan 2006
Originally Posted by Chuchuf View Post
This plane flew 5 times. I know that for a fact because I was the one flying it (I'm not the builder, just flew it) 4 min each time. Lands great and tracked like a pattern plane. In fact it doesn't even need flaps for the landing.
I'm definately not saying that the eFlight gear will hold up over time the way they are stock (and I questioned him using them many times) as my landings were for the most part greasers.
All 5 times I took off and landed on grass and it handled it just fine.
So before you make a statement insinuating that the seller told you something false on a public forum, I suggest you get your facts straight.
I know the seller and although he isn't an experienced builder yet, I don't believe he would not have told you the truth.
Terry
PM sent.
Frankensteen is offline Find More Posts by Frankensteen
Old Jun 23, 2012, 06:58 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Originally Posted by Arngeir Blakseth View Post
As far as I know Tam only makes upgrade parts for the smaller E-Flite models, not the 60-120's.
I bought a set which has metal frames. He customed fitted the struts and trailing links to suit already cut wheel wells.
As you know, Tam has has new CNC machining capability. Give him a call. He might have the larger units too.
Phil
PhilLin is offline Find More Posts by PhilLin
Old Jun 23, 2012, 07:20 PM
mnavarro is online now
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
I run on landing gear with plastic trunions rated for 5 kilos and I have never broken a trunion. The key is to have the pin/strut bend before anything fails. On ocassion the plastic plate securing the gear breaks and I have to put a new one on. My landing gear solution is clearly not the best, but it's a lot cheaper and easier to fix than the eflite 60-120 retracts.
mnavarro is online now Find More Posts by mnavarro
Old Jun 27, 2012, 11:37 AM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Originally Posted by Extreme_RC View Post
Interesting you would post about that setup Arngier, I am waiting on the first batch of new 50mm inrunners for my Alloy ramtec fan. Motor is basically the same dimensions as a 1917-1Y, 8 pole and 600Kv. On old 5000mah 30c packs I was seeing 108 Amps and 7kg thrust on the stand with the AS inlet lip. I would expect 120A or so and 7.5kg thrust with strong new packs like yours. Would really like to hear yours running in the nacelle, I am thinking about putting this new setup into the trim-air Sabre I have sitting in storage
Any news regarding this motor?
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Old Jun 29, 2012, 08:48 PM
Die Meistertinkerer
Joined Jan 2006
Got my used Falcon refurbished and ready to go! Just need a day below 95 degrees to fly!
I worked up some fun fantasy racer graphics (printed by Kirby's Graphics), new norray canopy, kitbashed a new cockpit and made ABS main wheel well area panels.Will use two TP 5s saddle packs and 2s booster, and will stick with the E Flite retracts until they give out.
I really like the look!
Old Jun 29, 2012, 11:15 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice job thats crazy ! great grapics.....good luck with her
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 30, 2012, 05:18 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Really nice.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Jun 30, 2012, 09:56 AM
Die Meistertinkerer
Joined Jan 2006
Thanks guys-I appreciate the kind words!
Old Jun 30, 2012, 11:35 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
VERY nice, this bird is the best deal in jets no doubt
erh7771 is offline Find More Posts by erh7771
Old Jun 30, 2012, 11:59 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
one of the best flyers too ! come on guys my molds are collecting dust
Old Jun 30, 2012, 12:07 PM
Joined Oct 2010
You should look into making canopies, retract covers too
Old Jun 30, 2012, 12:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
will i dont want to mess with the fine job noray is doing with his canopies. i have thought about some servo cover to claen up the plane a bit .for gear doors i just cut some abs plastic sheet and silicon them to my struts.
Old Jun 30, 2012, 12:39 PM
RAPPTORS is offline
Find More Posts by RAPPTORS
United States, FL, West Palm Beach
Joined Jun 2004
How much for dynamax nacell ??
RAPPTORS is offline Find More Posts by RAPPTORS
Old Jun 30, 2012, 05:47 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Rapp PM sent
Old Jul 02, 2012, 10:47 AM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I fill ya Roger We have all Air Sally's works of art in-stock too
The XPS pro motor system will be here very soon
Thanks Billy D
http://ohiousarc.com/cart/nacelle-fo...36e2d5323cdd62
BILLYDSRC is offline Find More Posts by BILLYDSRC
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
