Old Jun 09, 2012, 12:44 PM
tom bacsanyi is online now
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
Solution to big battery supply
I'm surprised that nobody mentions paralleling smaller packs. Since day one, I have been running 12s 2650's paralleled to 12s 3300's. The pic is of the Citation
and that was reduced to 10s as it was a bit much. There are a lot of advantages:
1. double #12 or #13 is copper equivalent #9 or #10 respectively.Easy wiring!
2. almost twice the cooling area.
3. more flexibility in location for cg.
4. easier no spark solutions.
As a somewhat seperate subject, I still use anderson power poles on all my batteries. No special jumpers, cables, everything fits everything. you do need to be carefull!
You may want to go to post 67 here:
http://www.rcgroups.com/forums/showt...5#post19126091.
tom bacsanyi is online now Find More Posts by tom bacsanyi
Old Jun 09, 2012, 02:28 PM
Hossinarizona is online now
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Originally Posted by Fidelity101 View Post
I've got one very similar with CS fan, spring air retracts, robart struts, cc160a esc, all hitec servos, air Sally nacelle stiffeners and mounts.
If you want to travel to NY, I'll sell you mine for $850.
I built it but havent gotten to the field once to even try it out.
PM sent....
Hossinarizona is online now Find More Posts by Hossinarizona
Old Jun 09, 2012, 02:37 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Another advantage Tom, is that you have the smaller packs for smaller applications when you need them (and you have A LOT of them)
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 09, 2012, 07:50 PM
Frankensteen is offline
Find More Posts by Frankensteen
Die Meistertinkerer
Frankensteen's Avatar
United States, GA, Columbus
Joined Jan 2006
Originally Posted by bri6672 View Post
I've used them, they handle the power no problem. They are quite strong despite a 25c rating..
Sweet-They'll get me started...Got the big Georgia Falcon home. Its in need of pretty substantial cosmetic and other work inside and out, but worth the price. Going with a different color/ graphics scheme as well. Will post before and after pics.
Frankensteen is offline Find More Posts by Frankensteen
Old Jun 09, 2012, 07:54 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
does it have the C/F stiffeners on the bottom of the fuse ? i hope so .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 09, 2012, 08:12 PM
Die Meistertinkerer
Joined Jan 2006
Roger, it has the CF stiffeners, and the fan install looks good, but I'll pour over it. It did fly, I saw the maiden on a cell phone video. I'm certain I'll be here much, asking silly questions in due course...
Old Jun 09, 2012, 08:15 PM
Die Meistertinkerer
Joined Jan 2006
Tempted to swap fans and put this one in my replacement F9F plastic Panther, and put the 5612 in the Falcon, tho I suspect I'd need a smaller nacelle.
Old Jun 09, 2012, 08:37 PM
Fidelity101 is online now
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
A few pictures of my Falcon. I still haven't gotten a chance to get a flight in yet.
I admit that I need to find a better handle to pull back on the metal latch...that Popsicle stick just looks out of place. The batteries lay overtop of the metal hatch, which is fixed to that block of wood. The metal latch lever is blocked by the top of the battery tray, so I needed a way to pull on the latch without much effort. The popsicle stick works pretty well until I find something that looks a little nicer.
Fidelity101 is online now Find More Posts by Fidelity101
Old Jun 09, 2012, 10:17 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
welcome both of you to the Falcon club ! there lots of guys here to help.
Old Jun 10, 2012, 05:37 AM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
5612 would fit fine in the Air Sally nacelle, all you need to do is to make a short inlet adapter to fit the slightly smaller fan ID.
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Old Jun 12, 2012, 01:30 PM
dpowellmeii is offline
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
Does anyone know what the falcon 120 airframe only weighs?
D
dpowellmeii is offline Find More Posts by dpowellmeii
Old Jun 12, 2012, 02:06 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
D
5lbs without canopy iinm
erh7771 is online now Find More Posts by erh7771
Old Jun 12, 2012, 11:26 PM
Madison, MS
Joined Oct 2006
D
Old Jun 13, 2012, 07:52 PM
Die Meistertinkerer
Joined Jan 2006
Thanks!
Old Jun 13, 2012, 07:56 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i've been able to fit a lot of fan into the nacelle it takes some work but can be done ...the latest fan to get installed is a shubie HST94 i'll try to post a pic tonite ...i got it mounted ,just need to do some body work ,and paint it ...of course it looks so good in there you hate to put the lid on
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 12:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
