Old Jan 11, 2012, 04:31 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
Rudder Servos
Air Sally, racer 1, knifeliddle, etc., what torque servos are you guys using on the rudder?
Ed
A10pilot is offline Find More Posts by A10pilot
Old Jan 11, 2012, 05:02 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I used a set of HS82MG They work great for me
Ed
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Jan 11, 2012, 05:07 PM
wclays is offline
Find More Posts by wclays
Joined Nov 2006
Ed
I used Futba S3002, since they fit the slots. I believe a Hitec 225HG is the same size.
PS S3002's are no longer made, but I am sure there must be a sub.
Clay
wclays is offline Find More Posts by wclays
Old Jan 11, 2012, 05:29 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Guys, thanks very much. I will use similar sized/torque servos.
Ed
Old Jan 11, 2012, 06:29 PM
bmwk1200s is offline
Find More Posts by bmwk1200s
bmwk1200s's Avatar
Joined Sep 2010
what length servo extentions are you guys using for the rudder servos and elevator servo,also where did you direct your motor wires out of the nacelle to the ESC (probably will mount mine on side of carbon motor mount like Roger did) and where did you bring the esc wires into the fuse....Roger if you make servo covers you've got my order if its as good as your nacelle then i'm in for the covers....ran my motor up yesterday at my friends house he only had 6s 5000 20c batts (they were fully charged though but have had 200 odd flights on them) and made 3900 watts 95 amps .... cant wait to see what this ( little screamer dynamax fan air sally nacelle) will do with my (6s 5000 45c batts 2 flights only)....also want to mention that I did not have my thrust tube on during this test haven't installed it yet.
bmwk1200s is offline Find More Posts by bmwk1200s
Old Jan 11, 2012, 06:32 PM
bmwk1200s's Avatar
Joined Sep 2010
What would the difference in the numbers be if I ran 6s 5000 45c or running xps 6800 6s 65c?
Old Jan 11, 2012, 07:18 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
in the bottom of the nacelle there is a naca type scoop i ran my motor wires out of that .the batt wires to the esc located on the side of the C/F mount .those wire come out the back of the fuse and go over to the esc .i have a small wire harness clamp just infront of the fan to make sure the wire dont get eat'n by the fan . the CC dasta log on mine with the XPs pro motor and 6800 65c batts is a peak number of 121 amps,and just over 5200 watts ...those are peak numbers settle to 116 amps and 4900-5000 watts.that is with a 3.5" tail pipe .i think it is a tad more and plane is faster at 3 3/8" tail pipe.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 11, 2012, 07:37 PM
bmwk1200s's Avatar
Joined Sep 2010
Thanks Roger if it's not too much hassle post some pics of your wiring entering/ coming out of the fuse
Gary
Old Jan 11, 2012, 07:39 PM
bmwk1200s's Avatar
Joined Sep 2010
Moving ahead,servos for ailerons,flaps complete and operating good,now for the elevator and rudders
Old Jan 11, 2012, 08:29 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Here are pics of the nacelle and ESC.
Gary
Old Jan 11, 2012, 09:48 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
get a coat hanger ...this is the hardest part of the build the holes for the Servo wires is smsll and the connectors get hung up trying to fish it through. make sure any extention plugs are tape or have those neat little connector locks on them.pics would have to wait till tomarrow ,im at work
Old Jan 12, 2012, 07:33 AM
bmwk1200s's Avatar
Joined Sep 2010
ok thanks guys
Old Jan 12, 2012, 07:35 AM
bmwk1200s's Avatar
Joined Sep 2010
Billy what did you use to anchor down your esc
Old Jan 12, 2012, 01:49 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i have used silicon ,some use hot glue (i would'nt ) and mine is velcroed to the C/F mount.
Old Jan 12, 2012, 02:10 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I used Hot glue to just hold it in place and then used silicon to do all the real work of holding it in The data of the ICE160 said the ESC never got over 115 on the hottest day of summer
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 02, 2010 12:41 AM
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 2 Sep 06, 2009 01:08 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 09:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 10:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 10:09 PM
