Old Jan 06, 2012, 05:43 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Got My Plane
The big brown truck delivered my Falcon 120 this afternoon. I have checked the plane and the glue joints look good except one fuse former which is not glued well. As others have suggested, I will reglue all of the joints I can get to. Of note is that the model comes with steel pinned hinges (Klett clones i guess). Fuse feels fairly heavy (glass seems quite thick). It weighs 2 lbs 5 oz. Seems quite heavy in the tail/engine mount area. Plan to install the carbon rods in the aft section. Look forward to installing my converted dynamax.
Thanks to Scatsob for the heads up and the promotion code for 10% off.
Now the important stuff. I respectfully request to be admitted to the Falcon 120 club . All in favor please say yes, all opposed please say yes.
Thanks in advance for admiting me to the club .
Ed
A10pilot is offline Find More Posts by A10pilot
Old Jan 06, 2012, 05:50 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
jump in ! the more falcons the better ,but you got to post pics of your mods and setup.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 06, 2012, 06:24 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Fair enough. It looks like the plane is going to weigh north of 15 lbs. Is that about right? I have found some functional struts from my dearly departed Jet Model Products F-4 (2 OS 91's and Dynamax fans and it weighed 33 lbs) and the appropriate set of main retracts. I am thinking of putting a 10-12 lb nose gear in it (why, because I have it on hand).
I have converted two Dynamax fans. One has the Turnigy 880 KV outrunner motor (thanks for the thread Lee) and the second has a Leopard 700 KV inrunner (39mm) motor that I am trying. The Turnigy (on my test stand similar to Ron101's unit and using Eagle Tree data acquisition system) put out about 5080 watts @ 147 amps on some Turnigy 5S 5000 mah 30 c packs (10S so 2S2P) using the Turnigy Dlux 160amps ESC. Efflux without intake ring (Roger hope to have yours in hand shortly) and no tail pipe was 187 mph and thrust was 11 lbs. If what I have read is true, then I should see an increase in thrust with the intake ring. The inrunner was on the same setup and put out 3200 watts at 92 amps. When I get some more packs I will run it on 11 and 12S.
More to come later,
Ed
Old Jan 06, 2012, 08:07 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the inlet shipped the other day .those gear should work
Old Jan 06, 2012, 09:15 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Thanks Roger. What are some of these planes weighing ready to fly on 10S?
Ed
Old Jan 06, 2012, 10:19 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Working away on mine, control surfaces are hinged, I went with the CA hinges but sealed them with clear oracote to add extra strength and they are solid, I used some larger CA hinges in the elevator to be safe and It is getting sealed as well. I went with the 645mg's on the ailerons and flaps, I tore open one of the flap servos and reversed it internally to safe a channel. Rudders are hinged as well but man they do not line up that great... I am using 225mg's on the rudders (in the elevator spots) one will be reversed internally like the flaps to save a channel. I am going single elevator servo with a 170oz digital in the bottom side of the vertical stab. Pilot is on his way and I am going to start the cockpit and canopy frame this weekend. My retracts and power system are in my amd hawk but they will get pulled after a few flights to go in the falcon.
bri6672 is offline Find More Posts by bri6672
Old Jan 07, 2012, 12:01 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
im 12s 6800 mah xps fan and a a123 2300 mah rx batt ,brakes ..so im heavy at 18-20 depending on 5000 batts or 6800 batts. 10 with a lighter fan S/B 14-16 lbs
Old Jan 07, 2012, 06:00 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
My Falcon with a 100mm Turbax/Haoye hybrid with a Turnigy 4030 880kV motor running on 12S 5000 was just shy of 15lbs. That's a pretty lightweight power package, so expect 15lbs to be about minimum.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 07, 2012, 03:58 PM
bmwk1200s is offline
Find More Posts by bmwk1200s
bmwk1200s's Avatar
Joined Sep 2010
recieved cockpit pan and canopy from norray much better quality than stock and is going to look great with the pan insert and instrumentaion panel and pilot.
bmwk1200s is offline Find More Posts by bmwk1200s
Old Jan 07, 2012, 04:01 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Can you show ussome picture of the cockpit pan?
Billy I think I will be able to call you later
rvincent is offline Find More Posts by rvincent
Old Jan 07, 2012, 05:26 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
+1 on the pic of the cockpit tub, would love to see it! Wish Ray would have mentioned it, i would have gotten one with my order.
Old Jan 07, 2012, 07:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
he stop selling them for a while ...i asked when i got my canopy .so i guess i better ask again.
Old Jan 07, 2012, 07:44 PM
tom bacsanyi is online now
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
Turnigy Dlux hv160 test
I posted this in the hobbyking 160 hv thread but it may be of interest here with the cc problems.
I've got about 25 flights on my Falcon 120 with cc hv160 on 10s but it hasn't been back to cc yet so I did not try 12s. Just got a Dlux 160 and ran my 125mm fan on 12s, 44volts, 144 amps, 6300 watts for 20 seconds and it looks good. I added 4 low esc caps to the input leads as the standard caps look light to me. All temps were just warm. The scale is hard to read but was flirting with 20 lbs.
20 second run vid:
Untitled (0 min 38 sec)
tom bacsanyi is online now Find More Posts by tom bacsanyi
Old Jan 07, 2012, 08:09 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
I saw XPS' 200 amp 16s controller at the AMA expo ...look real promising ...3 more cells would bend the wings on this thing
Old Jan 07, 2012, 10:51 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Rodger Rocks!!!! Thanks man I really appreciate the fast turn around!!!!
Discussion Another Falcon 120 Twin EDF flyguide7 Electric Ducted Fan Jet Talk 7 Jun 30, 2016 04:52 AM
Discussion Falcon 120 Motor Mount racer1 Electric Ducted Fan Jet Talk 2 Feb 01, 2010 11:41 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
